08-11-2023, 10:27 AM | #23 | |
Rep 619
I love my Apex wheels, you didn’t see many sets - although sadly everyone mistakes them for 763m replicas!! |
danb19791904.50 |
08-11-2023, 11:03 AM | #25 |
1905
Rep 2,093
Haha that's fine, you know different
08-11-2023, 06:24 PM | #26 |
Rep 1,017
The stoppiest diesel in the world Proper brake porn that
I love the look of the front calipers pushed right out like that. The rears look small by comparison I suppose the question is, how do you know if you have the F8x master cylinder and 185mm handbrake? Is there a part number on your MC for cross referencing? Has the turn-in changed at all with such vast discs? They're kind of like big old flywheels at each front corner now! |
danb19791904.50 |
08-12-2023, 05:43 AM | #27 | |
Rep 619
The fronts have been on for 4 years now, so I haven’t really got any memory of how it drove before - but handling feels spot on with these. Obviously it’s a heavier set up than the stock blue Brembo’s, however I have very light forged wheels - so it probably balances things out quite nicely in terms of overall unsprung weight. My main goal was the aesthetics to be honest of having a ridiculously large brake set up! |
danb19791904.50 |
08-13-2023, 03:53 AM | #29 | |
1905
Rep 2,093
https://www.realoem.com/bmw/enUS/sho...diagId=34_1972 If you've got them on your 330D, it'll be the same
08-18-2023, 07:48 AM | #31 | |
Rep 1,017
My 2016 330D does indeed have the same Master Cylinder as the LCI M3 - P/N 34337849879. Same 185mm handbrake as well. That's as good a reason as any! Half the appeal of monster stoppers is how good they look behind some nice wheels, plus brakes that big potentially implies something equally tasty under the bonnet |
08-18-2023, 07:50 AM | #32 | |
Rep 1,017
RealOEM can be a bit hit and miss sometimes I've found. Probably because the catalogue is 4 years old? |
danb19791904.50 |
08-18-2023, 07:52 AM | #33 | |
1905
Rep 2,093
If you decipher your VIN via Mdecoder etc; you know what your car has fitted from factory then; just ensure that your parts on RealOEM match the spec if your cars VIN etc I'd thought about the F80 arms for my F31 when I do the suspension refresh; but after lots of reading (and pages showing the faff you have to go through with spacer washers and other stuff etc); I'll be sticking with OEM spec and spend more on the actual suspension (probably coilovers) etc... And I REALLY need to stop looking at Apex wheels
08-18-2023, 08:07 AM | #34 | |
Rep 1,017
Ah right, so the F80 subframe is different then.....of course it is Yeah they are very nice. America always gets all the good stuff. All we get over here are those miserable bastards over at Compomotive. |
danb19791904.50 |
08-18-2023, 09:53 AM | #35 | |
1905
Rep 2,093
Quite happy to keep it OEM TBH; lowering a touch on coilovers will offer a bit more camber than normal; my pal said that should be more than enough to dial in a fast road set up, as the OEM camber is minimal at best!
08-19-2023, 06:17 AM | #36 |
Rep 1,017
I suppose if you were committed, would the F80 subframe accomodate a diesel engine?
It's alloy I believe, so a useful weight saving over the F3x steel jobbie. Yeah the stock camber is pathetic, barely any at all, but that's only the static camber. Low static camber is better for reducing steering twitchiness. There's a ton of dynamic camber thanks to the big boy 7+ degrees caster When the warranty is up, I think just a set of Ohlins coilovers is enough to completely transform feel and handling. Don't need much more than that tbh on a daily road car. Sorry for the thread derail |
danb19791904.50 |
08-21-2023, 03:29 PM | #37 | |
Rep 619
08-29-2023, 06:32 PM | #38 | |
Rep 1,353
