XI clunking?
02-02-2016, 01:19 AM | #1 |
20
Rep 76
XI clunking?
Hello, all.
Vehicle: 2006 BMW 325xi 6spd 165,000 miles So I have an annoying clunking in the drivetrain when I turn [does it more when I turn right but it does it when I turn left also] at about 20-50% of lock while under ~30% throttle. It feels like the car is skipping a gear or something. This does not happen when I give it more throttle. If the vehicle is rolling in neutral and I put in same amount of steering lock and give it throttle, something feels like it's bouncing around underneath. I disconnected the front driveshaft and in turn 'solved' the issue. Albeit driving without a front driveshaft is very much a temporary situation, I will continue to do so until I correctly identify the issue. I have: changed front passenger-side axle which I believed to be bad [no difference] changed front passenger-side engine mount [no difference] checked for excessive play in mounts [does not seem to be the case] Could it be the transfer case? If so, why would it do it only when the front driveshaft is connected and not when it doesn't load front wheels? Could it be the front diff? I hope someone can shed some light on this as it would be very much appreciated. |
02-02-2016, 07:55 AM | #2 |
tuned n dropped 335xi
Rep 332
I have had to replace my transfer case in the past, there is a small PLASTIC gear in the xcase motor that engages and disengages the front wheels, and it wears down. There are some quicker fixes if that is all, unfortunately mine was a full replacement.
If you disengage the drive shaft and the problem goes away, that is very similar to what I was experiencing and how the dealer narrowed down the issue for my car. Possibly when turning, your left/right wheels demand more power from the AWD and thus more of a clunking noise? Could also be your CV joints, that was my first thouht until you said you replaced the side axels.
335xi - BMS DCI - VRSF DP's - JB4 Tune - KW v1 -
02-02-2016, 08:18 AM | #3 |
48
Rep 374
If its worse turning right its actually probably coming from the drivers side axle since it is under more load. I would start there for sure. Definitely sounds like a CV joint, odd about the "bouncing" feeling when in neutral though....could be a larger issue
02-02-2016, 09:23 AM | #5 |
Rep 449
This actually sounds like "torque bind" to me where the transfer case clutches are getting more force from the actuator then they should so the transfer case is not allowing the wheel on the outside of the turn to rotate freely at a faster speed. I had a similar problem so I setup the BMW DIS software that allows you to reset the transfer case adaptions (I did this after I changed the TC oil). DIS is the only software that will do this and was a real pain to get going and use.
This made a big improvement but I still have a small shudder in the front end only when accelerating and turning left at slow speeds and only when the car is cold. If I hold the steering wheel in one spot say at 90% of max turn in a parking lot and give it some gas I will get this shudder. Does it with and without the transfer case actuator fuse pulled so I'm lost.
335i FBO,Meth,JB4,Sutphin flash,LSD,GCLites 11.25@127.4 on NT05R
335xi FBO,Meth,JB4,Sutphin flash,VTT stage1 11.38 1/4 - 7.30 1/8th - 3.35 0 to 60 @ 0C |
02-02-2016, 10:07 AM | #6 |
48
Rep 374
02-02-2016, 01:03 PM | #7 |
Rep 1,059
02-02-2016, 01:17 PM | #8 | |
48
Rep 374
As far as testing the joint, you can get under the car where you have access to the shaft and inspect the boot for any tears or dry rot, and grab the shaft near the knuckle and see if there is any excessive play in the joint that could cause binding. The popping, clunking, noise you are hearing is binding in the joint. Hope this helps. |
02-02-2016, 03:18 PM | #9 | ||||
20
Rep 76
It's not very difficult. I'm currently working on putting a video together for a DIY. Very straight forward. |
02-02-2016, 06:34 PM | #10 |
Rep 605
Your xi is mechanical, and not xdrive? What does that even mean? Theyre both one and the same.
If your transfer case has a motor on it with wiring and harnesses, then there is software involved, hence not completely "mechanical". |
02-03-2016, 04:54 PM | #11 | |
20
Rep 76
oops? |
02-04-2016, 02:28 PM | #12 |
Rep 646
Drives: 2008 E92 335XI Coupe
you should not be going to that mechanic anymore.
2008 E92 335XI, Space Gray on Coral/Fox Red Hybrid M3 seats, Premium, Cold Weather, Comfort Access, iPod.
Mods: Fox Red M3 seats up front, KW V1, ER CP + TIAL BOV. |
AWD Addict304.00 |
02-08-2016, 11:24 AM | #14 |
26
Rep 116
I had clunks - light bucking when turning, say after a stop sign. My Indy changed the transfer case fluid and reset adaptations on the transfer case. Completely eliminated the issue. Maybe worth a shot. This is on an 07 335xi 6MT with 114k miles.
02-18-2016, 03:32 PM | #15 | |
Rep 947
Because the worm gear on these models is metal.... The plastic worm gear was on earlier X3/X5 models. |
bshambam197.50 |
02-18-2016, 04:09 PM | #16 | ||
20
Rep 76
If so, I would like to politely ask where you got that information from? BMW E90 TC Actuator Part #: 27107546671 BMW E83 TC Actuator Part #: 27107566296 Those are the ACTUATOR part numbers for X3's & E90's and they clearly do not match and I'm almost inclined to believe you... |
02-19-2016, 08:46 AM | #17 | |
Rep 947
If I had a photo I would post it but I have dissembled a couple TC actuators here at the shop I work for and E9x have been metal worm gears. This is an article referring to the X3/X5 chassis with plastic worm gear. http://hubpages.com/autos/BMW-Transf...roblem-And-Fix Here's a thread about the E9x TC actuator motor: http://www.e90post.com/forums/showthread.php?p=12962481 And in post #151, a member confirms the worm gear is metal....picture links are broken though. http://www.e90post.com/forums/showpo...&postcount=151 |
05-04-2022, 11:40 AM | #18 |
Rep 2
I have the same problem when I remove the front driveshaft it goes away my front axels have been replaced also could it be the transfer case actuator? I need help
05-11-2022, 07:50 AM | #20 | |
1009
Rep 2,109
05-11-2022, 07:52 AM | #21 | |
20
Rep 76
