Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Some wiring diagrams for the members
      11-11-2017, 10:24 PM   #89
ctuna
Drives: 325xi 06 wagon MT
Makoa6
Your on the wrong sub forum this is for the stereo and entertainment
section. You want to be on the general or motor sub forum.
I would suggest you get a Bimmergeeks diag cable and download and set up ista D and P as well as the Inpa coding.diagnostic and coding suite .
The following links will be some help.
Ista is like an diag and shop manual
Ista is the program that BMW used in there shops
for most of the life of the e90.
https://www.newtis.info/tisv2/a/en/
electical e90 pdf
http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja
http://www.google.com/url?sa=t&rct=j...85464276,d.cGU
http://www.e90post.com/forums/forumdisplay.php?f=16
http://www.e90post.com/forums/forumdisplay.php?f=378
Might be the HPFP problem mentioned so much.
You need a BMW specific scanning system to get
all the codes .(Such as Ista d)
general forum
http://www.e90post.com/forums/forumdisplay.php?f=2
http://www.e90post.com/forums/showthread.php?t=333519
Mahlo.
      01-19-2018, 02:29 PM   #90
qcutta
Drives: 328 i e90
Originally Posted by bluelake View Post
Here are some diagrams and pictures that might help people in their future installs.
First I took a look at the wiring harness by the amp (std. US-spec "Hi-Fi" stereo, non-L7). Wow! What a tangle.
So I pried them apart to figure it out.
Then, to avoid confusion I made this wiring diagram on the computer.
Then I decided to make one to help out the Logic 7 folks.
If I got anything wrong, please let me know and I'll revise. I was working off some forum thread info for the L-7, since I don't have such a system. Cheers and good luck.
I have a loud horn that im trying to Install into my 328i.. I’m trying to figure out which wires are my front left speaker because my wiring color in my car is a little bit different.
      05-14-2018, 07:24 PM   #91
smacame
Drives: '09 E92 335i
Just wanted to drop a quick thank you here, these were great to have during my e92 upgrades over the last few weeks.
      07-25-2018, 03:49 PM   #92
Le7316
Drives: 2007 E92 335i
Did you tap directly to stock sub ( Left + Right ) for our RCA ?
      08-28-2018, 05:28 PM   #93
quoting
Drives: 08 328i
Thanks, this helped
      03-06-2019, 09:20 AM   #94
diazjuan1998
Drives: 2011 335 I M Sport 13:59 Quart
Incredible Amount Of Accurate Information!!!
THANK YOU!!
      04-07-2019, 01:40 PM   #95
Thechosen1
Drives: 2014 bmw 328i msport
2014 328i msport
Originally Posted by enforcerman View Post
I used this very post to tap into wires. Needs a sticky.
were you able to use this diagram for your 2014 msport?, just curious on what wire you used for the remote turn on, and if the colors were the same? thanks
      08-22-2020, 05:40 PM   #96
icarus20
Drives: 2011 BMW 335i
Hi everyone,
New to the forums. And BMW for that matter. Hope this is the right place to post, since it appears I can't make a new topic yet...
I'm working on replacing my factory stereo and stuck on one factor. Every install video I have seen (as well as the instructions in the box) say that I should have 1 antenna cable running into my factory stereo, but I have two. One that has a mostly purple cap and one that has a mostly black cap. Any idea which is the proper antenna cable I want to connect to my new stereo?
Thanks in advance for the help!
      11-13-2021, 11:43 PM   #97
DeobandiPrince
14
Drives: 2009 328i Manual
So a couple weeks ago I hit a massive pot hole and my rear right strut came into my trunk area. I unfortunately had to drive my car to work until parts came in and my amp harness looks like this after the top mount chewed through the harness.
I'm planning on soldering the wires back to together but unsure of what gauge wires I need for the amp harness. I assume I have to use the exact same gauge wires so if someone could point me in the right direction, that would be great.
I should add that I have the Hi-Fi system.
      11-14-2021, 11:48 AM   #98
ctuna
Why not strip them back a little then attach them.
      11-20-2021, 11:51 PM   #99
DeobandiPrince
14
Not sure tbh. I just assumed because some of the ends are pretty rough, I'd loose some length when stripping wires. But now that you mention it, I'll give it a shot over Thanksgiving break.
      09-10-2023, 06:59 AM   #100
MCCoding
Programmer and occasional 2 stepper with the ting
Drives: E90 N47N, E92 M57, E71 M57
Why is there not a diagram for the basic sound system?
Door speakers WITH underseat subwoofers but without the amp in the trunk and no wiring etc
What are the speaker wire colours for that?
Would the colours match with the same system for an e70 or e71?
      09-18-2023, 04:56 AM   #101
Dark Vader
Drives: 2010 BMW E60, 2002 E46 Convert
I have a 2010 E60 535i with Hifi (USA)
My front and rear speakers are powered from the head unit and the underseat subs are powered by a small amplifier in the trunk (boot) on the left side (tweeters in front sail panels, mids in doors, speakers in rear deck, underseat 8” ‘subs’)
I’ve tapped into the low level wires in the harness and made RCAs to provide signal to a new subwoofer amplifier…
But I would like to see a wiring diagram for this setup so I can tell which wires are which for future reference… (found the low level left and right, and the turn on lead which were all I needed at the time)
I want to eventually amplify the rest of the system and I’m looking for an ‘easy’ route even if it’s a small 4ch 75 x 4… and I wouldn’t mind giving some more power to the underseat ‘subs’ and running them as a true midbass driver
Thx!!!
      09-21-2023, 06:51 PM   #102
ctuna
Hi fi diagram
http://www.e90post.com/forums/attach...1&d=1209780865
BMW stereo types
http://www.e90post.com/forums/showthread.php?t=352586
http://www.e90post.com/forums/attach...2&d=1266451970
http://www.e90post.com/forums/attach...2&d=1260829447
http://bmwcoders.com/forum/3-er-8/bm...1-e92-e93-291/
http://technicpnp.com/menuDiagrams/d...e90_92_93.html
http://www.musicarnw.com/page-2/
http://www.e90post.com/forums/attach...3&d=1169133185
http://www.e90post.com/forums/attach...1&d=1209780605
http://www.e90post.com/forums/showthread.php?t=641323
http://www.e90post.com/forums/attach...4&d=1278871872
http://www.e90post.com/forums/showthread.php?t=343673
https://www.bimmerfest.com/threads/e...n-752.1275694/
base system wiring pre/post 3/09
https://www.google.com/url?sa=t&rct=...tDpLJPcGkw_ui_
Base System Guide
http://www.e90post.com/forums/attach...5&d=1493273253
I have posted this over hundred times now.
Assuming you have the Hi Fi option 676 there are a lot of threads saying how to do this.
subwoofer threads
Are you sure you have Hi Fi because US 2010's did not have Hi Fi there where no tweeters in the front doors and there was head unit power only .
See base system explanations. (at least in the 3 series. )
They either had the ampless system in the 2010 or the Logic 7 pay for it system.
http://www.e90post.com/forums/showpo...2&postcount=66
http://www.e90post.com/forums/showth...t=Ultimate+Sub
http://www.e90post.com/forums/showth...ight=subwoofer
      09-21-2023, 09:32 PM   #103
Dark Vader
Hi fi diagram
[url]
My System has the tweeters in the sail panels, midranges in the doors, speakers in the rear deck (sounds like just mids) 8" under-seat subs, and an amp in the trunk that powers the subs.. I've tapped into the low-level wires going into the amp and the turn-on lead and fed a separate amp with signal, and turn on from those wires....
This layout is similar to mine, but the amp is a silver colored small amp in the rear driver's side (left side) of the trunk/boot
I'm just trying to figure out if the amp is JUST a sub amp, or if it's more... I was told at one point that the interior speakers are powered off the head unit, and the subs are powered off the amp, but I'm trying to verify... if it's more, it'll make it easy to power the system with a better 6-ch amp in the trunk and maybe a DSP unit... if the amp is JUST for the subs, I'm going to have to fish wires throughout the car to add an amp
HiFi
The HiFi system was standard in US-spec cars until MY 2010 (when it was replaced in some cars with base Stereo) and again starting in mid-2011. There are tweeters and an amp, but no graphic equalizer settings in the head unit’s user menu. The amplifier has analog inputs. Pre-2010 HiFi amps are large black modules. 2010 and later HiFi amps in E9x vehicles can be small metallic-colored modules.
2006-2009 E90 sedans
Later 2011 E90 sedans
2006-2011 E91 wagons
2007-2009 E92 coupes
Later 2011 E92 coupes
2008-2011 E93 convertibles
2008-2009 E82 coupes
Later 2011 E82 coupes
2008-2011 E87 convertibles
2004-2010 E83 SAV
2006-2009 E70 X5 (includes center channel)
Later 2011 E70 X5 (includes center channel)
Later 2008-2010 E60 sedans
(Note: early E60 sedans have an unusual hybrid system called “HiFi” – please contact us for information about these vehicles).
      09-21-2023, 10:11 PM   #104
ctuna
BMW's did not come stock with true Subs' the under seats are midranges.
All the knowledge here is 99 percent based on E9x's .
And there where no BMW sub amps in the e9x .
Run mdecoder.com on your vin option number 676 = Hi Fi
option 677 or 688= Logic 7 if these numbers do not appear it means
base system . There is also a system above Logic 7 called Individual audio
I think it's 752 or something in the 7xx range there is a thread on it toward
the end of the list.
The graphic equalizer was only in the Logic 7 system for e9x .
The Hi Fi amp went from black to silver after they reinstated it
for the e9x . I have no idea what they did with the 5 series.
May the Farce be with you.
      09-22-2023, 06:11 AM   #105
Dark Vader
Ran mdecoder…. Results are as follows
Multimedia
S639 Preparation F Mobile Phone Cpl. USA/CDN
S645 BMW US Radio
S663 Radio BMW Professional
S676 HiFi Speaker System
S693 Preparation BMW Satellite Radio
S697 Area-Code 1 For DVD
S6FL USB/Audio Interface
      09-22-2023, 11:14 AM   #106
ctuna
Then you can assume it has the 676 Hi Fi wiring .
That diagram should be it and I don't imagine they would change
the color coding .
      09-22-2023, 12:15 PM   #107
Dark Vader
the color coding .
Thanks!!
My question still remains though… do I have the 6-channel amp, or is the amp only powering the underseat woofers with the head unit powering the mids and highs
I’ve been getting mixed messages
I posted my question in the E60 forum DAYS ago, but no one is responding… I’m posting here because at least it’s active here
      09-22-2023, 02:00 PM   #108
ctuna
yes it's 6 channel amp at least in the e90 and below. They don't generally redesign
the stereo system for every car . They use the same one for each series up to the
upper ones and sometimes even there. That is why the same option numbers come
up in VO from the mdecoder search.
You could put the model number or part number for the amp into a search on the open internet and you would be able to verify that .
If you need absolute further proof . Disconnect the amp connector an use the wiring
diagram at the beginning of this thread and use an ohmmeter to verify the wire runs
to the speaker.
      09-24-2023, 07:41 AM   #109
Dark Vader
If you need absolute further proof . Disconnect amp connector an use the wiring diagram at the beginning of this thread and use an ohmmeter to verify the wire runs
to the speaker.
Well…, just so you know… I found out my answer last night… it’s a two channel Harmon/Becker amp (40 x 2) powering the underseat woofers, and the rest of the speakers are powered by the head unit
Not that it necessarily applies to the E90 but BMW obviously DOES change up
Meh
Thx anyway… back to the drawing board
      09-24-2023, 12:50 PM   #110
ctuna
Have you looked into which years this schematic covers?
Around 2005 and 2006 they had a distributed system like this
in the Logic 7 cars and then it changed to the same one the
across all series .
You should go to the e60 stereo forum.(If there is one)
Or do searches under E60 stereo
https://5series.net/forums/e60-e61-p...nstall-124141/
