BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Mporium BMW
      03-02-2021, 12:33 PM   #67
Assimilator1
Assimilator1's Avatar
594
Drives: BMW M3 e92 08 & 330d e90 10
2010 BMW 330d  [8.00]
2008 BMW M3  [0.00]
Below freezing is nothing for most cars with sensible oil grade + clearances, more of a problem for the S65 though. No need to increase the risk (even if only slightly) with a 15w cold grade, especially when 5w/50 is available.
DrFerry6730.00
      03-02-2021, 01:49 PM   #68
gilberjj
108
Drives: E92 M3
My thinking on this is simple. I buy the best oil money can buy because this car is not a DD for me. I only change the oil once a year.
I've run Redline in other vehicles in the past and I've never had a reason to doubt it's quality.
Troy Jeup recommends Redline 5w50, and he's built more S85 and S65 motors than anyone else in the USA. Good enough for me. https://www.m3post.com/forums/showthread.php?t=1592340
From my research, there are plenty of good grade III, IV and V base stock oils. But true full-synthetic, grade V ester formulas are the best oils without any compromises (redline and motul). Expensive, but so is a motor...
Appreciate 3
DrFerry6730.00
G80indy1714.00
      03-03-2021, 11:31 AM   #69
edycol
Drives: 2011 328i xDrive
As long as you keep your OCI in check. Esters are oxidizing much faster. Forget time interval, watch your mileage. IMO, anything pass 5K on Redline is gambling with oxidation.
      03-03-2021, 03:26 PM   #70
Lucas CR
Drives: M3 E92
anyway, which oil filter? as recomended there:
https://www.m3post.com/forums/showthread.php?t=1343867
OEM oil filter kit (with seals and copper crush washers) = Mahle OX254D3 (also packaged and sold as Hastings LF667)
and air filter = Mahle (or Clevite) LX1590
plus cabin filters = Corteco MicronAir CC1377 (80001029)
      03-03-2021, 04:35 PM   #71
Bartledoo
Driver
Bartledoo's Avatar
2692
Drives: 2011 E90 M3 6MT
Troy Jeup also has the weirdest set of text messages publicly displayed on google lol.
E90M 6MT Slicktop Single Humper in need of a diet
      03-03-2021, 05:21 PM   #72
EDWYER
Yoda of mods
EDWYER's Avatar
1676
Drives: X5 RWD
2015 X5 RWD  [0.00]
2016 BMW M2  [10.00]
This is true. Some real horror stories.
      03-04-2021, 05:05 AM   #73
G80indy
Save the Manuals
G80indy's Avatar
Drives: Z3, E46, G80
I can't say enough about how Redline HPMO keeps mine clean
(2000 z3)
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT
2000 Z3 Conforti, 5MT
      04-02-2021, 02:11 AM   #74
leftfootbr8king
leftfootbr8king's Avatar
570
Drives: E92 M3
Does anyone have any experience with Fuchs titan race pro s? They've got a 10w60 full ester oil, and I've been running it for over a year now, with a decent handful of track days mixed in with once a week driving just to keep fluids moving and seals wet.
      04-02-2021, 04:42 AM   #75
kyrix1st
kyrix1st's Avatar
2367
Drives: G87 M2; E92M3 MT&DCT; M3 euro
2004 BMW Z4  [0.00]
Could you do a VOA/UOA on that oil? I used it back in JP before but really curious to see what additives it uses.
Pass me if you can.
      04-02-2021, 09:57 PM   #76
edycol
Fuchs is largest industrial lubricant manufacturer in Germany. Their product will be of good quality.
From their MSDS I can see maybe 5-10% Esters, the rest combination of PAO and Group III. IMO, average, probably step below Castrol, Motul or Mobil1.
      04-03-2021, 09:31 AM   #77
leftfootbr8king
570
Drives: E92 M3
Are you looking at msds for Fuchs titan oil in general, or the 10w60 race oil? There's a difference.
The 10w60 is a group 5 base stock, the likes of redline and millers. In Europe this oil seems to be preferred by many in our s65's over even Miller's nanodrive.
      04-03-2021, 01:47 PM   #78
edycol
Yep, I am looking at 10W60.
First of all, MSDS will not give you the full base stock story. MSDS is required only to list harmful compounds. If the compound is not harmful, it is not listed.
From MSDS, PDS numbers, that oil has 5-10% esters. That is it. Pour point is very high for Ester-based oil.
Does not mean it is bad oil, but personally, I would go Motul, Mobil1 or Castrol.
      04-03-2021, 05:27 PM   #79
kyrix1st
kyrix1st's Avatar
2367
2004 BMW Z4  [0.00]
Fuchs titan 10w60 is not the same as race pro s 10w60. One is API SN and the other is SL/SJ likely due to elevated ZDDP levels.
Pass me if you can.
      04-03-2021, 09:45 PM   #80
leftfootbr8king
570
Drives: E92 M3
I'm running the race pro s, that comes in around 1200ppm ZDDP.
      04-03-2021, 11:49 PM   #81
edycol
If API has a limit on 10W60, but it could be.
API limits specific grades. For example until API SP, W40 oils had a limit at 1,200. Now they are at 800ppm probably bcs. timing chain test.
      05-30-2021, 12:12 PM   #82
Lucas CR
Drives: M3 E92
guys, question
motor oil Im changing each 5k miles, even previous owner keep BMW interval 15k. Im using Castrol 10W60, as recommended (even believe on the market are better oils).
But what about air and cabin filter?
With oil change I replace also the air filter (Mahle LX1590), previous owner made it 1,5 year a go -5k miles. But the origin filter looks ok, so I belive the change wasnt necessary. Im driving in normal climate, no sands, no dirty roads, no mud, no drive in snow... So its change w oil necessary? I guess in 2 years or 15k miles it should be ok, what you think?
W cabin filters the same story, origin looks clean...
      06-03-2021, 02:29 PM   #83
Assimilator1
594
2008 BMW M3  [0.00]
No you don't need to change with every oil change in normal conditions, especially not with just 5k/yr, even if you did 15k miles per year the air filter should be good for 30k (I think that's BMW's standard interval??). With that and the pollen filter, just change it when it's starting to get dirty (with more leeway on the pollen filter).
Oh, pollen filters can be more affected by parking under trees than mileage
      08-19-2021, 05:20 PM   #84
G80indy
Save the Manuals
G80indy's Avatar
Yep
Went 4+ years with Redline fill and low miles. Blackstone showed it was strong in TBN.
I have zero concerns about Redline in truly extended time OCIs.
2023 G80 6MT, CCBs
      08-20-2021, 06:42 PM   #85
edycol
Yep
Extended OCI is not RedLine cup of tea. It is not TBN, it is TAN.
      08-21-2021, 03:11 PM   #86
G80indy
Save the Manuals
G80indy's Avatar
Yep
You speculate. Redline is an optimal blend of Group 4&5. Do you speak as if it's all Group 5?
Show me a BSOA where Redline was in the red on TAN.
I have no concern with extended time/ low mile OCIs
2023 G80 6MT, CCBs
      08-21-2021, 03:46 PM   #87
edycol
Yep
The acidity level of brand new Redline oil is at level of some oils after 7k use.
You have MSDS provided by Redline where you have ester content. In Performance series it is almost 80%. If you don't have TAN in your UOA you are assuming at best what is going on. Regardless whether TBN is enough or not, TAN and TBN under no circumstances should overlap or TAN exceed TBN.
      08-22-2021, 11:12 AM   #88
G80indy
Save the Manuals
G80indy's Avatar
Yep
https://bobistheoilguy.com/forums/th...t-info.114241/
After 5 years TBN was 7.7
I sleep like a baby
2023 G80 6MT, CCBs
m3post
