2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications maybe vacuum leak
      04-21-2024, 12:09 AM   #1
jdelpup
jdelpup's Avatar
Drives: 2013 BMW 535i stg2+
2013 BMW 535ix  [8.00]
maybe vacuum leak
2013 535i downpipe, stg2+, charge pipe, fmic
had a bad o2 sensor then got it fixed. it was running good. cel came on and i got similar symptoms to the bad o2 sensor. no stalling but whenever i brake and come to a stop the car rumbles and sounds like it is about to stall but it doesn’t. if i’m parked it will occasionally rumble (i think misfire) but it doesn’t stall. driving is fine everything is just when rpm’s are low. the codes i attached are the ones i got when i ran them initially. i checked my maf and vacuum lines and cleared the codes. they went away but came back shortly later this time just with a fuel mixture too lean code. cel is on now and it is just lean code when i scan it. any ideas?
      04-21-2024, 01:09 PM   #2
95blkmax
Drives: '11 535 M-Sport
I suggest a smoke test as a starting point.
I'm on the YouTubez now!! Check it out -> https://www.youtube.com/@turbospool
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24
      04-21-2024, 03:32 PM   #3
poverty.f10
DIY Mechanic
poverty.f10's Avatar
Drives: 2012 BMW 535i xDrive
How much rpms is it dipping?
You can live in a car but you can’t race a house.
      04-21-2024, 03:38 PM   #4
jdelpup
jdelpup's Avatar
it drops to around 500 probably when i brake and it rumbles and misfires for a second but then goes back to normal idle
5post
