BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 2012 BMW 335i F30: Still the Benchmark @ 0-60mph - 4.7 sec (Motor Trend Video)
Extreme Powerhouse
      02-28-2012, 03:30 AM   #89
clarence
Drives: F30 328i M-Sport
Originally Posted by Robin Hood View Post
Some people are looking for arguments to unjustify the 4.7 accelleration time it seems. FIY German carmag Auto Motor und Sport did 0-100kmh(62mph) in 5.1 seconds(335i A sportline)
That's cos mags from USA seem to consistently achieve much quicker times than mags from Europe. Just like the argument between consistently fast times achieved by Autozeitung compared with others such as AMS or Auto Bild.
As u said, AMS did a 5.1, so I trust AMS more as their approach is more methodical.
      02-28-2012, 03:38 AM   #90
clarence
Originally Posted by Danforz View Post
Wait a minute, he launched the car from 2000rpm? The car doesn't have a launch mode... that's not good for it is it?
Launch mode or not it's still the same thing. If u're going to hurt the components then they're going to be hurt.
Launching a autobox car with 2k rpm is much kinder than dropping the clutch for a manual car at 2k rpm (some cars might stall if only 2k rpm). That's cos all u're doing to the auto is to heat up the fluids inside the torque converter. As long as u let the fluid cool down in between each run, u won't do much harm (unless of course u launch the car like that every day).
      02-28-2012, 03:41 AM   #91
clarence
Originally Posted by Sumithb13 View Post
Did you not watch the video? He launched it from a dead stop.
The run shown on the clip may not be the actual run used for timing.
      02-28-2012, 03:48 AM   #92
clarence
Originally Posted by fusion01 View Post
Most likely a 0.8 sec difference between the new 335i and 328i, not that great but it does matter to some
Official figures is 0.6s difference, the margin increases the faster u go due to stronger top-end on the N55. On the other hand there may be no margin at all if it's 0-60 or 0-80 due to traction issues.
If this 4.7s is recorded w/rollout then it's consistent with 328i as the other test (328i) did a 5.5s with rollout (i.e. 0.7s difference between the 2).
As said previously, if u always do Autobahn speeds then 335i it is, otherwise anything below 180-200km/h the 328i is more than enough.
      02-28-2012, 06:26 AM   #93
Ron Scott
Drives: 2013 335 M Sport
Still can't get my head around buying a new 4-cyl engine in a bimmer.
      02-28-2012, 07:29 AM   #94
Blubaron79
Blubaron79's Avatar
Drives: 2021 M340i xDrive
Guessing the x-drive will be even slightly quicker.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive
      02-28-2012, 07:35 AM   #95
shockin330i
shockin330i's Avatar
798
Drives: 2016 ZCP M3
The term more than enough is based on personal preference. To me more is never enough....
ERnie
2016 BSM/f80/ZCP
      02-28-2012, 08:27 AM   #96
Michael Schott
343
Drives: 2017 VW GTI Sport
So then the car doesn't really go 0-60 in 4.7... he simply manipulated it, in a manner which cannot be consistently recreated, to do so.
I just don't get it. I was hoping this would be the video to settle but alas, no. These car companies are either using roll outs or some strange launch control instead of just giving the consumer actual 0-60 times. Its as if they're trying to get the most controversial number, not the most accurate.
0-60 tests are designed to get the best results not the most repeatable results or the results you and I would get. They find the optimal revs that won't spin the tires and with an AT brake torque to that point and dump the brake and mash the throttle at the same time. With a MT they find the right revs, dump the clutch and mash the throttle. They also often correct for humidity and elevation.
We spend a lot of time here gnashing our teeth over 0-60 times but what's relevant for most of us in the real world is the feel we get in the seat of our pants. Nothing more.
      02-28-2012, 08:28 AM   #97
Michael Schott
343
Maybe. Better traction but more weight.
      02-28-2012, 08:30 AM   #98
Robin_NL
S0THPAW
Robin_NL's Avatar
8717
Drives: HS M2 Competition
Exactly! And I find my F30 way faster than my ex F10(both N55), maybe it's the MT box and off course the weight.
Did 200kmh already(125mph) an hour ago(no or almost no traffic) in 6th from 80mph---> 125. It's quick.
It's so much more torquey than that F10. Wow.
      02-28-2012, 08:45 AM   #99
ATX78703
Drives: 2014 335i
Originally Posted by justinnum1 View Post
N54 is slightly more powerful than the N55 tho, especially the really early ones like 2007 N54 was probably 340horses,
N55 should consistenly get 5.0 tho, maybe even 4.8-4.9 if you get those 19"
On a related note, it is totally LAME that you have to get the 19"s to get the staggered 255s in the rear. I mean I have staggered 255s in the rear on 17"s right now!
2014 335i RWD: ZMM, ZDA, ZDH, ZPP, ZTP, 2NH, 2TB, 5DL; Z4A MPPK; AW ext / VB int
      02-28-2012, 09:18 AM   #100
justinnum1
Drives: 2018 330i Msport 6mt
+1. but those 19" also add a good amount of weight where you dont want it...
F30 330i Alpine white/Coral red Msport 6MT
      02-28-2012, 09:22 AM   #101
Red Bread
Drives: Smog machines
On the roof? You're doing it wrong.
I have two thoughts on the 225 rears.
1) Many folks that really care will be going with aftermarket wheels anyway.
2) If the damn car had an LSD, 225's might actually be enough
      02-28-2012, 09:24 AM   #102
justinnum1
      02-28-2012, 09:28 AM   #103
ATX78703
Drives: 2014 335i
Agreed. 0-60 launch techniques should be reproducible by different drivers, but the times will always differ. Waiting till wheelspin passes and the car grips and starts moving will give you a faster time than when you actually mash the throttle.
      02-28-2012, 09:39 AM   #104
emtrey
emtrey's Avatar
92
Drives: 16 M235IX, 06 Carrera S, 335i
Perfectly said
agree.well stated. Its all about how it "feels". After reading all the quoted times on the 335, I was not sure what to expect w/ the F30 335.
To me, it felt great. Perhaps it is not as empirically "fast" as my current 135 but that 8 sp ZF box really is a game changer. To me the 335 had the 50-80 mph response of the 135 DCT car I test drove. Gave it an inch of throttle ( it appeared to downshift 2 gears) and that was all I needed to make my decision.
0-60 times a a snapshot reference. Its not a range you drive the car in most of the time. The 328 is plenty quick the 335 is just quicker and smoother.
      02-28-2012, 09:46 AM   #105
catalyst
Drives: X1
I have to say, this video gets me excited for a possible power "bump" with the F32 next summer (2013). Crossing my fingers that something comes along....as I'll be returning my E92 335i at that point.
I would really enjoy a 340i or some equivalent
      02-28-2012, 09:59 AM   #106
clarence
Why not? Most of BMW's motor racing heritage (& success) come from 4 cyl motors. Whether it's the dominant F2 motor, to the most powerful ever F1 engine (according to BMW Motorsport's then boss, it's so powerful it can destroy the test bench), to the all conquering S14 engine, they're all based on the M10 4-cyl block. In recent years, BMW won successive WTCC titles with the N45 engine.
      02-28-2012, 10:06 AM   #107
clarence
It will, traction is a big issue.
528iX N20
535i N55
Just compare the 0-50km/h & 0-80km/h times, plus the 528iX is heavier than the 535i.
      02-28-2012, 10:43 AM   #108
1BMW335
Drives: 2014 F10 M5 CP
Can't speak for all car magazines but here are Car and Driver's test procedures:
http://www.caranddriver.com/features...-c-d-test-cars
They do not roll the car. 0-60 is from a dead stop. Same with Inside Line for 0-60 times:
http://www.insideline.com/features/h...nd-trucks.html
Road & Track does a 1 foot roll but they subtract the time for that 1'. Not sure about Motor Trend.
+1
      02-28-2012, 11:13 AM   #109
ARam
ARam's Avatar
61
Drives: 2016 BMW X5M
Originally Posted by kamigawa120
I own a 35i x3 it's 0-60 is 5.5 secs. I would believe that the 335i could read 0-60 secs in 4.7 since it's almost a 1000lbs lighter and lower thus reducing wind resistance.
Kamigawa - I also agree with you! I have a X6 3.5 bigger than your X3 and on manual I manage 5.8-5.9sec on manual.
      02-28-2012, 11:19 AM   #110
Q4P
Q4P's Avatar
Drives: Too Much
Are you really comparing a car that weighs 500 lbs less in terms of performance? LOL The knowledge on this forum amazes me at times.
As far as 0-60 times are concerned, different situations will get different results which is why 0-60 times are not a good way to judge performance. Any sort of incline change, tire change, traction issue, style of launching and temperature will all have to do with 0-60 times. Trap speeds at the end of the 1/4 mile are the only relevant ways in comparing 2 vehicles performance in that regard, the 335i is 5-6 MPH faster than a 328i (which is a huge difference).
2jZ + RB26 + 4G63 + LS9 + N54 =
2012 3 series review, 2012 3 series reviews, 2012 335i review, 2012 335i reviews, 2012 335i track video, 2012 f30 review, 2012 f30 reviews, 3 series f30, 3 series f30 forum, 3 series f30 review, 3 series f30 reviews, 3 series forum, 3 series reviews, 3-series review, 335i 0-60, 335i 0-60mph, 335i f30, 335i f30 review, 335i f30 video, 335i quarter mile, 335i review, 335i reviews, bmw 3 series first drive, bmw 3 series forum, bmw 3-series f30, bmw 335i review, bmw 335i reviews, bmw f30, bmw f30 3 series forum, bmw f30 3 series review, bmw f30 3-series, bmw f30 forum, bmw f30 review, f30 0-60, f30 0-60mph, f30 3 series review, f30 3 series reviews, f30 3 series track video, f30 3-series, f30 3-series forum, f30 328i, f30 328i quarter mile, f30 335i 0-60, f30 335i 0-60mph, f30 335i review, f30 335i track video, f30 335i video, f30 forum, f30 forums, f30 review
