07-11-2017, 06:48 PM | #1 |
23
Rep 112
Sport plus coding not 2TB
I'm sure how to code for sport plus is somewhere out there, but there are so many threads that only talk about 2TB. For now I'm wondering what codes to actually change to get sport plus. I'm using the Bimmercode app because it has an expert mode that seems pretty good and the developer said that coding for sport plus is possible but not 2TB.
Also is there a thread out there that talks about all the expert coding with Bimmercode, maybe a cheat sheet? |
07-11-2017, 07:58 PM | #2 | |
Rep 689
Drives: 22 TR X3MC
Sport+ mode ICM/3000 ICMKOD_B_SPORTLENKUNG nicht_aktiv ===> aktiv KOMBI/3000 FDS_MENUE_TEXT_1/2/3/4 menue_4 ===> menue_3 KOMBI/3000 FDS_MENUE_SIGNAL_1/2/3/4 menue_4 ===> menue_3 Make sure you change the values for all 4 menus Sport Automatic Transmission EGS/3000 Applikation -> Sportschalter_alt -> aktiv EGS/3000 Applikation -> Sportschalter -> aktiv EGS/3000 Applikation -> LC -> aktiv
2022 X3M Comp
2013 335i xDrive (Sold) |
07-12-2017, 02:29 AM | #4 |
Rep 5
07-12-2017, 10:58 AM | #5 |
23
Rep 112
Yea I figured as much, I was messing around like an hour ago and couldn't expert code the ICM. Thanks for the code anyways, have it on a piece of paper in my car for when the app update comes it.
07-12-2017, 03:05 PM | #6 | ||
Rep 689
Drives: 22 TR X3MC
2022 X3M Comp
07-12-2017, 09:19 PM | #7 |
23
Rep 112
Bimmercode is really simple to use and the features I wanted were super easy to code, literally just toggle a switch and code. I might use esys but I actually have to learn then.
07-13-2017, 01:43 AM | #8 |
Rep 5
05-10-2018, 05:00 PM | #9 | ||
20
Rep 59
05-11-2018, 11:28 AM | #11 |
Rep 5,776
08-20-2018, 10:41 PM | #12 |
Rep 4
Is the process for enabling Sport+ the same on the F10?
I have set ICM/3000 ICMKOD_B_SPORTLENKUNG to verbaut and set all the eight menu entries to menue_3. I see Sport+ in the menu when I hit the rocker switch, but I cannot select it. SAT is enabled and seems to be working as expected. |
11-02-2018, 06:28 AM | #13 | |
Rep 1
Noob here. I have a 2013 335i Luxury Line, looking to get the Sport Auto Transmission shifting. How is the 2TB different than doing an auto trans flash like XHP flashtool? Called a local Indy Mechanic here in MN and they said that changing the VO codes is not recommended and that any subsequent update would result in the VO codes going back to stock, so this would require re-doing. Can someone break down the difference between changing VO codes vs. a flash? Appreciate it! |
bimmercode, coding, f30 2013, sport+ |
