06-26-2018, 08:58 AM | #1 |
TH320i
23
Rep 41
N20 22psi Peak boost.... Is it too much??
Well guys, Exactly what the post says.... am i in danger of seriously damaging my engine internals?
22psi peak boost. 100 degree average intake temps.... What do you guys think? Cheers!!!
2012 BMW 320i - Catless DP - Full 3" exhaust system - Cold Air Intake - S55plugs - GFB DV+ - ProjectA Stage 2 Remap (270 hp on E20).
06-26-2018, 09:03 AM | #2 |
Rep 3,680
You should be OK there, assuming the rest of your tune is good. The limit for the turbo is 23psi or thereabouts, the limit of the engine depends on power as a whole, rather than just boost.
Instagram: rjd_f30 | Current: EBII 2013 335i 6MT RWD & Sprint Blue 2008 Audi RS4 | Retired: 2013 328i, 2000 XTerra, 2022 Civic Si |
06-26-2018, 09:49 AM | #3 |
1032
Rep 2,382
I'd like to say the limit is about 24psi. Most people that have blown a ring has been due to overboosting to about 25 psi. That being said, the max I'd ever recommend someone hitting is 23psi and if within your control, smoothen the powerband some so that's not an instantaneous torque peak like the 328i normally does. For the rod bolts, that's almost always a track thing, so unless you go with a bigger turbo, ethanol, and so on to push higher than like 330whp+, you should be fine for non-track racing. I ran 23psi for quite some time but my turbo did start to go at about 85k miles; however, I cannot assert that it went due to the 23psi.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
CalCarNut1061.50 |
06-26-2018, 09:55 PM | #4 | |
10
Rep 65
Thanks |
06-26-2018, 11:31 PM | #5 |
1032
Rep 2,382
Yes, it was the stock turbo.
06-26-2018, 11:54 PM | #6 |
Nemo banks
65
Rep 253
FBO N20, G-Plus Oil Cooler , Injen Cold Air Intake, MST turbo inlet, AFE Charge Pipe, BMS Oil Catch Can, Forged Motorsport Blow of Vavle, Wanger FMIC, Circuit Werkes Catless Downpipe, Full Straight 3inch exhuast. Stage 2 Active Auto Werke.
06-27-2018, 12:09 AM | #7 |
1032
Rep 2,382
06-27-2018, 09:58 PM | #8 |
TH320i
23
Rep 41
Thank you guys !!! Tune is good and smooth.. I am running ethanol e20 fuel but still on stock turbo, more of a anti knock safety measure as it gets hot over here in Thailand in traffic intake temps are close to 140 degrees.
06-27-2018, 10:08 PM | #9 |
Rep 3,680
Sounds like you could use an intercooler, 140 is insane for normal driving!
06-28-2018, 03:25 PM | #11 |
24528
Rep 191,521
No way to tell for sure without datalogs ...22 PSI is aggressive for a stock N20/N26
06-28-2018, 09:27 PM | #12 | |
Rep 3,680
Also +1 for logs, that's the best way for us to tell if the car is healthy without being there.
06-29-2018, 08:51 AM | #13 | |
1032
Rep 2,382
Aekdbrich174.00 |
06-29-2018, 01:55 PM | #14 |
24528
Rep 191,521
I was referring to bone stock, missed the mods in the signature
M2_MEDUSA669.50 |
07-02-2018, 12:36 PM | #15 |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
Agree on the smoothing the power out. When my car was flashed, Matt asked me where I wanted it to come in. Seems like many like it right off the line. Mine is set to spread it out over off idle to midrange so it doesn't shock the drivetrain off the line.
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
07-02-2018, 07:40 PM | #16 |
TH320i
23
Rep 41
Logging... my issue is i only have a Carly adaptor and the logs on that app are crap.... Might get DashCMD and see if the logging on that is any better.
07-02-2018, 08:26 PM | #17 |
80
Rep 307
There are so many details that need to be addressed though. There’s no set number for how much boost because things like DA, fuel, or elevation play a part in how much you can run. The quality of the tune is much more important.
rjd_F302001.50 |
07-03-2018, 09:09 AM | #18 |
1032
Rep 2,382
Oh definitely, but the magic number always seems to be 25 and up for those with blown rings.
07-05-2018, 02:28 AM | #19 |
TH320i
23
Rep 41
Talked to my Tuner and will be getting a 1.4 bar map which is around 20psi, hopefully it will be safer and wont blow anything.
07-09-2018, 08:59 AM | #21 |
1032
Rep 2,382
Your logs will tell you what you're hitting. But it appears that map two is +6PSI for EWG (22PSI absolute for PWG), which means you should be around the 23PSI range.
07-11-2018, 05:35 AM | #22 |
TH320i
23
Rep 41
Hi Guys... So the problems just keep coming hahah. I think i have a faulty Vanos system ... ive been looking at RealOEM and cant seem to figure out what part to get replaced...
https://www.realoem.com/bmw/enUS/sho...diagId=11_4765 Is there only one that needs replacing ? I thought there is supposed to be 2 one for intake one for exhaust??
320, boost, n20, peak, psi |
