The big part out you were waiting for e92 335i LCI - mashimarho
07-31-2016, 06:09 PM | #1 |
2111
Rep 13,877
Drives: E92 M3 & F80 M3 & G82 M4
EDIT: Local + stock Space Gray parts will get priority and a discount. I forgot to account for the cost to respray..
Date is set for September 2, 2016. Hello fellow Canadian e9x members! I'm in the northern Seattle area very close to Surrey, BC. These prices are in USD. I've got quite a few things going on that leads me to parting out soon. I'm not sure what car is coming up, or what I'll be doing after the part out, but the car will be for sale in the next coming year. I post in the regional areas, because I prefer not to ship a lot of these. Priorities also go to those who have stock items to trade on top. If you have space gray stocks, knock off another $50 for a discount! F80 style front bumper + custom lip painted black. Bumper is made of polyurethane (same OEM material). It is not painted. Only the fangs were painted black. I had it wrapped. Not cheap. I've had it fitted to the car, and it's absolutely fantastic. I will be including the basics that came with the bumper when I bought it. The lip is a small gouge on the front center from low roller shots. Stock M sport bumper only + $700 Vorsteiner GTS3 style steel hood The hood has been also prepped to fit the car, and fits fantastic. Not painted, again primered and prepped for paint. I had the vents painted gloss black. I am missing the front vents and had one replaced with a black sheet to fill it. You can just replace it, I didn't because of the part out. It's a head turner and very aggressive! I will include the roundel, if you include yours. Stock hood + $500 M3 style side skirts + carbon fiber splitters This item should fit any e92 (make sure you do your research). Again, fits well with my e92. I had these wrapped as well. The splitters are aggressive. The corners have small cracks from road debris- fairly unnoticeable. The carbon fiber splitters usually retail $600 alone. Stock M sport side skirts + $550 E92 LCI headlights. Black out and Umnitza Orion V4 rings. These were finished professionally by Bav_Gruppe. The service and craftmanship was top notch. They make a huge difference. I will share you his contact as well for support. They wire directly to an existing fuse, and they turn on and off with the car. Paid about $900 for the service and modification + shipping. Stock e92 LCI headlights + $650 Duke Dynamics CSL Trunk with CF exposed. Fits fantastic. Painted space gray and wrapped currently on top. Edge and plate area has CF exposed. Stock trunk + $400 Matte black grill 8/10 condition (small knicks here 'n there) Stock + $20 BMW ///M Aluminum pedals (all transmissions) A bit worn, but make a huge difference. $25 Brand new black Pedals (all transmissions) $75 (in picture for display, was not installed) Yellow tow strap $60 Project Kics R40 neochrome lugs $150 #Tee carbon fiber side fin diffuser $100 BMW Performance exhaust I have cyba quad tips welded on (Will require quad diffuser) Sounds great. Nothing wrong with it. Stock Exhaust + $550 Duke Dynamics Quad diffuser carbon fiber Fits great (9/10) condition is great 9/10 (small hairline cracks on edges). Stock M sport diffuser + $450 BMS JB4 + Flex fuel and USB $400 BMS catless 3.5 DP Stock + $200 BMS Cold air intake Stock intake filter and cap + $150 Yellow Cyba scoops $25 Evolution Racewerk chargepipe no bung - black Stock + $150 VRSF 5" intercooler Stock + $200 Stoptech 6/4 piston BBK Calipers were painted yellow to match my TE37 SL. The caliper condition is 8.5/10. Obviously, small debris will get in the wheel well. The aero rotors are slotted and have plenty of life. I may even have an extra pair of slotted rotors that were used for track. The pads are fair, and have some seasons left. These will fit AWD & RWD! I have replaced the brake lines. Stock brakes + $1500. Air suspension + management & accessories Airlift front set up and custom bracket to go lowwwww. MK4 bags fitted to bracket. Fortune Auto rear aka broadway suspension. Airlift Autopilot V2. 5 gallon tank. All lines and remote. Will include extra front set up from fortune auto that I swapped out. Do not need stock suspension. Just $3000 OBO for everything. BBS LM championship edition with Michelin $3500 Forgestar F14 SDC with Nitto and TPMS $2100 BMW Performance steering wheel - yellow stripe I had the stripe repainted (I didn't do the best job, but it does the job) The alcantara is in fantastic condition Stock M sport wheel + $300 F30 BMW Performance shift knob and alcantara F30 boot I hated the e90 performance knob, so went to the F30 style. I had to retrofit it. I did a 7/10 job Stock M sport knob and boot + $200 F30 style BMW Performance ebrake and alcantara F30 boot Same thing here. Wanted the F30 style. Did a 8/10 job Stock M sport ebrake and boot + $200 Splatter paint trim. I painted it and did splatter paint. 10/10 quality. The center trim has a spot for a radar I cut out. I can include it, if you have the V1, for an extra cost, or if you have one already, great. See below Stock trim (not light wood) + $25 (just cost of paint).
08-01-2016, 05:44 PM | #7 |
2111
Rep 13,877
Trying not to, since I won't have a steering wheel.
Also, trying to stay as local as possibly for the time being.
08-02-2016, 08:31 AM | #12 |
137
Rep 2,517
Drives: '11 335xi e92 M-Pak
Too bad you're not close to the GTA.
08-02-2016, 04:00 PM | #14 |
Slow.
3782
Rep 7,152
Drives: Single Turbo N54 on Meth!
I'll take the black pedals. How do you like them vs. stock? Wish you were closer I would take the hood and trunk.
Good luck on your next project.
08-02-2016, 07:28 PM | #16 |
Slow.
3782
Rep 7,152
if you have another set of stop tech rotors can you please let me know?
that bbk is a steal. makes me want to ship you my stock brakes and just resell it for another grand or more...
08-02-2016, 09:41 PM | #18 |
curtisR
13
Rep 57
PM sent for BBK,
please reply, very interested.
Montego Blue 335i 6MT- FBO with RB turbo's and meth
Alpine white 335IS DCT- FBO with meth |
08-03-2016, 12:13 AM | #19 |
Rep 38
Can you post some pics of the front bumper and hood in their current state? Also, what are the sizes on Forgestar wheels and would you be interested in a trade for 313's?
