Oil cooler added - no more derate!
08-15-2016, 09:12 PM | #1 |
32
Rep 73
I'm not new to track events but new to tracking a BMW e90 n52. I was fighting an unknown power derate issue after about 10 minutes into a track session. The car never threw a code just pulled about 25% power.
I started watching temps with my Carly and found oil getting to nearly 300f on track, 245f just driving around in the summer, and could get to almost 260f just pushing it on the street I switched to a n55 ofh, stett oil cooler adapter, 215f thermostat from innovative, and a Setrab oil cooler front mounted in the lower grill opening. Built all the lines from summit racing and all the mounts from Home Depot Racing Department. The setup looks slick. I think this is superior to using a prefab side mount kit for the turbo cars. No sacrifice to the fresh air vents for the wheel wells. Oil gets hot enough to boil off the water What a difference!!!! 215f all day on the street. I never got the oil temps to stabilize on track, they keep climbing but MUCH slower than without it. highest I saw on track was 266 at the end of a 30 minute session of flogging. Never pulled power once. I'm not planning on endurance racing the car just hpde so I'm calling this done. I see this as an absolute necessity for anyone who plans on tracking a n52 although probably overkill for a street car. Any way hopes this helps others possibly fighting the same issue |
08-15-2016, 09:19 PM | #2 | |
Rep 3,778
Drives: '11 328i '19 M6
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
Taskmaster2470.00 |
08-15-2016, 09:39 PM | #3 |
Rep 1,286
I had the same issues and this was my solution.
http://www.evolutionracewerks.com/node/132 At least through the summer, I'm running the BMS thermostat bypass valve. My pre oil cooler normal street oil temperature was 250 to 255 degrees. Now my normal street oil temperature is 230 degrees on the street and 220 on the highway. I too saw 300 degree oil temperature on the track and 280 after the oil cooler, but prior to the BMS thermostat bypass valve.
2012 Jet Black 328i Coupe / ESS Tuning Gen. 2 Supercharger / Evolution Racewerks Oil Cooler / BMS Oil Catch Can / BMW Performance Exhaust with Dinan Y Pipe / Eibach Pro Kit Springs / Koni FSD Shocks / MFactory LSD & Differential Bushings / Performance Rear Trailing Arms / BMW Performance Strut Brace / Stop Tech Slotted Rotors / Hawk HPS 5.0 / SS Brake Lines / Brass Guide Pins / M3 Front Control Arms, 28 MM FSB, Engine Cowl, and DCT Paddle Shifters / Michelin PSS / APEX ARC-8
Taskmaster2470.00 |
08-15-2016, 09:51 PM | #4 |
Rep 4,531
Wow, well done.
Given ST in autocross has given an allowance for larger oil coolers, this might need to be a necessity. Is actual size larger I'm assuming? |
08-16-2016, 07:06 AM | #5 |
32
Rep 73
Setrab is a series 9 16 row. Fittings are all 10an. Probably should have went to the next step up on width but not enough height room to easily step to the 25 row
08-16-2016, 07:08 AM | #6 |
32
Rep 73
Cooler pic. Gets slammed with air in this location. No affect on radiator performance. Car stayed under 190F coolant temp during 30 min sessions at 80f ambient
08-16-2016, 07:42 AM | #8 | |
32
Rep 73
Not sure I'd spend the money for autocross. You're most likely not going to get the oil hot enough on a 60 sec course with cool down time between runs. I could run 10 minutes before it would get hot enough to pull power |
08-16-2016, 07:49 AM | #9 | |
Rep 4,531
Also, We have events called ProSolo, which the car is basically up and running for 15-20 minutes (most of the time it's in staging lanes) but could be a possibility where it can be an issue. You said you can pull oil temp directly from Carly via OBD2? I guess I should start tracking temps. |
08-16-2016, 08:15 AM | #10 | |
32
Rep 73
Yes you can track oil temp with mycarly via obd2. Not the smartest move to try and read coolant, air intake and oil temp off an iPhone with your foot to the floor in 4th at 120mph between corners, but it's all I could come up with to diagnose my issue and see how things improved. |
08-16-2016, 08:19 AM | #11 | |
Rep 4,531
Which brings me up the question, how are you running 190F coolant temps? I had to take my car out for a spin yesterday (Trying to get drive cycles to pass emissions) and through Torque I was sitting steady at 220F on the freeway. It was 80F, but awfully humid (70%+). Intake temps tracked with OAT. |
08-16-2016, 08:31 AM | #12 | |
32
Rep 73
08-16-2016, 08:34 AM | #13 |
Rep 3,778
This is what I've seen on track, too. Temp rises on cooldown lap and continues back to the paddock although it doesn't get much above 215F, or so.
08-16-2016, 10:51 AM | #14 |
103
Rep 385
This made me LOL!
Your setup looks legit and by your assessment, works just as well This is exactly what happens.
2012 E91 MSPORT • ST COILOVERS • TSW BATHURST |
08-16-2016, 10:54 AM | #15 |
103
Rep 385
Quick question, why did you opt to use the stett adapter vs the OEM setup?
08-16-2016, 02:25 PM | #16 | |
32
Rep 73
Since I was starting from scratch, the plate only $60 compared to whatever the oem setup costs And I wanted a thermostat that opened at a lower temp than stock. Last edited by Neversatisfied1; 08-16-2016 at 02:45 PM.. |
08-16-2016, 02:50 PM | #17 | |
103
Rep 385
Did you add in some additional filtration (highlighted in attached pic)? How much increased capacity did you figure this setup added to your oiling system?
08-16-2016, 03:02 PM | #18 |
32
Rep 73
That's the Improved racing thermostat
E91 M Sport103.00 |
08-16-2016, 03:13 PM | #19 | |
Rep 1,286
E91 M Sport103.00 |
08-16-2016, 05:40 PM | #20 |
Rep 7,215
I'll have to post up the map for power reduction vs oil temp. Just because it's interesting and relevant to this discussion.
I believe there is a threshold for an MIL at a certain temp, or at least a warning message on the dash, but it's a really high value. |
08-27-2016, 09:26 AM | #21 | |
Rep 9,004
tetsuo111 Also, any pictures of the finished product OP? Is you car an Auto or manual? |
