11-02-2016, 04:26 PM | #1 |
Luke Wright
166
Rep 252
Apex ARC-8 agressive fitment
APEX offers an 18 x 9.5 et35 wheel, but does not list it on their website as compatible for the f30. I've seen multiple members on the forum who run this wheel width and offset with no problems in the rear. How come no one runs arc-8's in this sizing?
I'm wondering because I was going to buy a set of ARC-8s in 18 x 8.5s et38 up front with a 12mm spacer and 18 x 9.5s et35 in the rear. I would run a square setup but I want the extra width in the rear. I want to have the same setup as the f30 in the pictures below except replace the 8.5 et38 + 18mm in the rear with a 9.5 et35. Sorry about the long question but your help would be greatly appreciated Last edited by lukeiswright; 11-02-2016 at 05:35 PM.. |
11-03-2016, 06:25 PM | #5 |
38
Rep 191
Drives: 2013 BMW 335i M-Sport
What tire/size and any spacers involved?
I run 18x9 ET42 on all four corners and require a at least a 5 mm spacer (I run a 10mm Burger)for the 255/40 Pilot AS3+ to clear the strut. Same wheel with a 235/40 dunlop direzza fits fine without spacers. Another member is running 255/40 Pilot Super Sports with no spacers. I will say, the AS3+ is a beefy tire.
2013 335i M-Sport 8spA
2011 M-B GLK350 2000 Dodge Ram 2500 QC 4x4 CTD |
11-03-2016, 07:08 PM | #7 |
Luke Wright
166
Rep 252
One last question.. What tire size would be ideal for the 18 x 9.5 in the rear? I was thinking either 255/40, 265/35, or 275/35. I would be running a 235/40 up front
11-03-2016, 08:25 PM | #8 | |
38
Rep 191
275/35-18 should work just fine out back... MEATY!
11-04-2016, 01:35 AM | #9 | |
40
Rep 168
which are 225/45 front and 255/40 rear.. with no spacers
rswitch ..
fhlh37.50 |
11-04-2016, 03:49 PM | #10 |
Rep 586
My f30 has camber plates on front plus the 15mm spacers.
Wheels: four 17x9.5 35et Tires: Nitto nt01 275/40/17 Had these wheels for two years now, balances well, zero issues.
G05 - M Performance roof spoiler
fhlh37.50 50shadesofhockenheim2164.00 David0ff1060.50 Taskmaster2470.00 Logicoeur993.50 WrxToBeamerGuy498.00 |
11-07-2016, 12:02 PM | #13 |
Rep 396
Drives: 2014 335i M Sport, 2004 .:R32T
sub'd for more info. I have been thinking about doing a 18x9.5 square setup all around on my F30. Ideally would like to run that width with maybe 265 or 275 size tires all around. I have 19x9.5 on the rear for mine now with 275s and I like that look. Just want to downsize to 18s for some more meat and rim protection.
11-07-2016, 01:31 PM | #14 |
43
Rep 170
That looks beastly. Nice work and solid fitment.
2022 - X5 45e M-Sport, MGM over tartufo
2009 - 335i 6mt, Monaco over saddle (past) 2015 - 335i M-Sport, Estoril over black (past) 2005 - 330i ZHP, Mystic Blue over black (past) |
11-08-2016, 11:35 AM | #15 | |
Luke Wright
166
Rep 252
There seem to be three options 1. Buy a square set of 9.5 wides + coilovers/camber plates + spacers and pray they fit 2. Buy a square set of 9 wides and have to go down to in tire size. Plus you'll lose the "face 3" concavity of the 9.5s 3. Buy a staggered set up with 9.5 in rear and 8.5/9 in front. You'll be able to have the concavity and width in the back plus the clearence in the front. However, you'll be sacrificing the reduction in oversteer and the longevity of your tires. I'll most likely be going with option 3 as I don't want to risk buying wheels that don't fit. Just my two cents |
11-08-2016, 11:38 AM | #16 | |
Rep 396
11-08-2016, 12:32 PM | #17 |
Luke Wright
166
Rep 252
Yeah it's kind of a bummer but oh well. I was thinking I would run a 235/40 front with 275/35 rear or a 245/40 front with a 285/35 rear. I would like to run the 245/285 combo because that would be the closest to stock tire height but I'm not sure if the rear 285 would even fit. Gonna have to do more research
11-08-2016, 01:36 PM | #18 | |
Rep 396
11-10-2016, 03:34 PM | #19 |
38
Rep 191
ok, I know have a question. Why wouldn't the arc-8 18x9 ET30 work all for corners without spacers? I currently run the 18x9 et42 with a 10mm spacer up front , so effectively that's et32 and a 12mm in the back for et30. I'd really like to run without spacers if possible, so that's why I'm asking
11-10-2016, 07:39 PM | #20 | |
Luke Wright
166
Rep 252
