Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > CIC/NBT FSC Generator - Windows/Linux/OSX
      01-02-2018, 12:51 PM   #1
Jagaer
430
Drives: 2011 E91 328xi 6MT
This is (hopefully) a more user-friendly CIC/NBT FSC Key Generator for Windows, Linux and OSX based off of the work of the original FSC Key Generator and Intel123's certificate Patcher.
Input Files
  • The Key Generator will auto-detect and accept either Base64 (Text) or binary FSC file inputs, as well as the file type (1B or NBT). (You can over-ride the detection setting, using the "CIC/NBT" radio buttons).
Support Files
  • The Key Generator will download and use the most recent copy of the BMW "Lookup.xml" file for key generation parameters. In Linux and Windows, this file is stored in the same directory as the Key Generator. For OSX, it is stored in ~/Downloads/
  • The RSAKeys.txt file keeps a copy all submitted RSA keys. The Generator will download and use the most recent copy of the file. In Linux and Windows, this file is stored in the same directory as the Key Generator. For OSX, it is stored in ~/Downloads/
Unsupported Feature
  • It appears that the key stored in the "FSC" file pulled from the car is not necessarily unique to the car, but may be shared across multiple cars built within a short time window.
As an example:
Code:
FSC Date	VIN Build Date			Days Difference
200910211749	Thursday, October 22, 2009	-1
201001271515	Thursday, January 28, 2010	-1
201004011026	Monday, April 04, 2011		-3
201006071536	Tuesday, June 08, 2010		-1
201107121301	Wednesday, July 13, 2011	-1
201110310756	Wednesday, November 02, 2011	-3
201201111004	Thursday, January 12, 2012	-1
201203301822	Monday, April 02, 2012		-4
201204181719	Wednesday, April 18, 2012	0
201205242316	Friday, May 25, 2012		-1
201210010521	Tuesday, October 02, 2012	-1
201210010703	Tuesday, October 02, 2012	-1
201210241654	Thursday, October 25, 2012	-1
201211081709	Friday, November 09, 2012	-1
201305140635	Wednesday, May 15, 2013		-1
201308142104	Friday, August 16, 2013		-2
201403071931	Monday, March 10, 2014		-3
201404091427	Thursday, April 10, 2014	-1
201404300545	Friday, May 02, 2014		-3
201406241001	Tuesday, June 24, 2014		0
201406241307	Tuesday, June 24, 2014		0
201409161938	Wednesday, September 17, 2014	-1
If you would like to help out, and have pulled your FSC file, please send me a copy. I will not include or publish any car-specific information, but will add the FSC file date and RSA key to the RSAKeys.txt file. Hopefully if enough are gathered, some people will be able to create an FSC for their car, without having to pull any files.
  • Windows: https://ufile.io/zkhli175
    Windows users must extract the file to a writeable directory (Desktop, Downloads, etc...), not run it from the zipped file. The generator needs to download support files (Lookup.xml and RSAKeys.txt) in order for it to run correctly.
  • Linux: https://ufile.io/wf40lkit
    Linux users must extract the file to a writeable directory (~/) and will need both QT5 and OpenSSL installed.
  • Linux Console: https://ufile.io/tb2tia4k
    Linux users must extract the file to a writeable directory (~/) and will need both QT5 and OpenSSL installed. Network not required.
    Code:
    Usage:  ./BMW_CIC_FSC_Generator_Console FILE.fsc TYPE [TYPE] YEAR [YEAR]
                    Example ./BMW_CIC_FSC_Generator_Console FILE.fsc 0x28 0x0A
            FILE.fsc - 319 byte hex OR BASE64 encoded version of hex
            TYPE     - 1 or 2 bytes representing the map type
                       If TYPE is two bytes, YEAR must be two bytes
            YEAR     - 1 or 2 bytes representing the map year
                       If YEAR is two bytes, TYPE must be two bytes
Code:
Version History
v1.91
  Feature: Option to attempt to repair corrupt 1B file
  Bugfix:  Download/Rename Lookup.xml
  Misc:    Add "Select Option" to dropdowns, since I'm tired of answering "Click 'Premium'. Select 'Premium', then the next dropdown will become enabled"
v1.9 - Add support for F0 Files.  NBT EVO Headunits which use NEXT style maps.
v1.02 - Allow Numerical First Digit for VIN.  Bug Identification & Explanation provided by txomin in post 71
v1.01 - Unhide "Lifetime" Checkbox
v1.0  - Initial Release
      01-03-2018, 12:28 AM   #2
Dtype
36
Drives: BMW F30 320d
Thanks!
OSX version not working
      01-05-2018, 06:51 PM   #3
opjose
opjose's Avatar
242
Drives: 335xi
Windows version works great!
      01-05-2018, 07:06 PM   #4
Jagaer
430
OSX Version has been updated, and confirmed working.
      01-05-2018, 07:08 PM   #5
Aus335iguy
Aus335iguy's Avatar
Australia
650
Drives: 2009 e92 335i MSport DCT
2009 BMW 335i  [10.00]
Does this do connected drive fsc as well?
When you doppelkaplung you doppel your fun.
      01-20-2018, 06:55 PM   #6
stote
stote's Avatar
Drives: 335D Touring
Will try later but seems easier
      01-21-2018, 09:12 PM   #7
Johnny Boost
324
Drives: '21 M850i GC
This is great! Can anyone confirm that the "by date" option works?
Thanks
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3
Michelin PSS | M3 Control Arms
LUX v4 LEDs | Shadowline Grills | Lip Spoiler
      01-22-2018, 04:16 PM   #8
Simania_NL
Drives: BMW 535iX
To which e-mail adress can I sent the files? Got several (CIC and NBT).
Thanks for the great work BTW!
Jagaer430.00
      01-23-2018, 10:08 AM   #9
Jagaer
430
Simania_NL Thanks for the kind words.
If the files can be sent to files (at) cicfsc . com , the RSAKeys.txt will be able to be updated.
Johnny Boost From what I can tell, BMW only generates new keys every few days. What that means is, "by date" works, but only if your vehicle build date matches one of the dates in the lookup table. Right now, there are only ~25 dates in the lookup table, and the lookup table spans 2009-2014.
This means you are more likely not to have a match, than to have one. However, it is worth a try, since it doesn't take much time at all to lookup your VIN build date online and see if it matches one available in the generator.
      01-25-2018, 01:26 PM   #10
6ixSpd
Save the manuals!
6ixSpd's Avatar
6035
Drives: '16 M3, '23 718 Spyder
Fantastic! In an ideal world, we would do it by VIN but I doubt that's going to be possible freely on these forums.
'16 M3 | '23 718 Spyder
Past: E92 M3, F87 M2, E39 M5, etc
      01-30-2018, 08:05 PM   #11
opjose
opjose's Avatar
242
Drives: 335xi
It works with this: http://www.e90post.com/forums/showthread.php?t=1461515
To make the whole process painless and cable free!
Just insert the USB drive, get your 1B file automatically...
Very NICE!
      02-11-2018, 04:43 AM   #12
hsm74
Drives: bmw e90 3.20i
Hello there. I am writing from Turkey. vehicle 2006 model e90 3.20i. I made the tool retrofit CIC afterwards. I got my 1b file from my cab. but the map code I created with this program does not accept the medium. I am using 2017 turkey premium map right now. 2018 PREMIUM TURKEY does not accept the code tool for the map..you will be a helper?1b file submitted
Thank you
File Type: zip 1b file.zip (863 Bytes, 4095 views)
      02-12-2018, 02:51 AM   #13
Dtype
36
Thank you
Do you have emulator or is cic script activated?
      02-12-2018, 09:09 AM   #14
hsm74
cic script activated. made it from another city. he no longer supports me. I gave you $ 100. want money again..the CIC I bought for retrofit was dismantled from an american car.... I even downloaded another country map. I tried the FCS code accordingly. but he does not accept anything.I did not do.
I'm sorry for my bad english
      02-12-2018, 05:17 PM   #15
Dtype
36
You need to use some software like fstools or dr. Gini and do check fsc command before input your code in the cic
      02-13-2018, 05:49 AM   #16
hsm74
I do not know how to do this. I just read the 1b file. I entered the resulting code into CIC. do you have a forum you can recommend to me?
Thank you
      02-28-2018, 10:17 AM   #17
Xrailer
Drives: Bmw
Good
      03-29-2018, 05:49 AM   #18
amrkiss
Drives: Bmw f31 320d
Hello!
Please help me! I would like to generate by date. My car made 01-august 2013.
I know the vin number. If i ll choose 15 of may, or 16 of august, will be working?
The navigation software is 2013-2.
Thx Adam
      03-29-2018, 04:14 PM   #19
Aus335iguy
Aus335iguy's Avatar
Australia
650
Originally Posted by amrkiss View Post
Hello!
Thx Adam
The answer is in the posts above please read carefully.
      04-05-2018, 06:37 PM   #20
dsjr2006
Drives: '01 E39 540iA, '09 E90 M3
2010 BMW 335i  [0.00]
2001 BMW 540i  [0.00]
Works perfect. Thanks!
E90 M3 DCT LCI | E90 LCI N54 M-Sport(retired) | E90 Technical Docs download: http://j.mp/bmwe90docs *good read, very detailed.
      04-06-2018, 06:00 AM   #21
dpaul
Drives: 2009 E90 335xi, 2011 E93 M3
Any chance of new links that don't require payment?
EDIT:
Oops, nevermind - found the googledrive link in http://www.e90post.com/forums/showthread.php?t=1461515
Thanks Jagaer!
      04-07-2018, 06:05 AM   #22
theglennster
Drives: E92 335D M-Sport (+RaceChip)
Thumbs up Many Thanks
Hi Jagaer
This is awesome work Many thanks for the effort put into this, it works like a dream.
What files do you require to help you populate your database ? Do you want the 1b hex or the generated code?
I owe you a beer or two...
