03-12-2019, 01:17 AM | #1 |
Rep 479
Hawk HPS 5.0 Review
Hello all, I figured I would write up a review to help others with the tough decision of what brake pad to use. To start, I have the base 335i grey Brembo/Bosch set up. I originally had the OEM pads and rotors, but it was time for new pads, so I figured I would do rotors as well. As the title reveals, I chose Hawk Performances HPS 5.0 pad and paired them with Zimmerman blank rotors. I installed the set today and have done about 25 miles with them. Following Hawks recommended bedding procedure, the pads were properly “broken in”. I will list some features I believe were important to my decision on what pad to use in hopes that someone with the same questions I had will find this useful. I purchased these pads with spirited street/ daily driving use in mind. The car has not seen a track day or HPDE, and I do not have plans to attend either any time soon. If there is anything I am missing or any other questions about install or my opinion on this set up, please do not hesitate to ask.
Dust- Since the pads have only been on for the day, I could not measure the amount of dust compared to OEM. I will Update in one week on the dust levels. I have black wheels so It will be an easy measure. Noise- After install there was a slight “friction” noise that could be heard in the cabin but has since subsided after the rotors zinc coating has worn off. Prior to bedding, the brakes made no noise. After the bedding procedure, the brakes began to squeal at lower speeds under light braking (slowing to a stop light from 10 mph to 0mph). When braking harder or at higher speeds, there is absolutely no noise. This may be due to the break in period. I will update as time goes on. Pedal Feel- Comparing the pedal feel to the worn OEM set up, there is a substantially better feel when considering pedal softness. The pedal feels much firmer than before and leaves you feeling more confident when pressing the brakes. Previously, the brake pedal felt borderline “squishy” but that is now gone. This could simply be due to the substantial amount of pad difference on all four corners, but I am pleased with it. Braking- As of right now the initial bite compared to OEM has decreased very minorly, but it is not a bad thing in my opinion. The brakes now feel more gradual, rather than jolting you. There feels like plenty of stopping power behind the brakes at the moment. Although I have not beat on them yet, the few miles I have driven have not made me disappointed. When testing the performance out on a “medium” level today, it felt to me as if these pads had better stopping power than OEM on the end of the braking distance. By this, I mean that after a while on a long-distance braking (applying medium pressure to the brakes to gradually slow you down from 65mph to 10mph) the OEM pads seemed to fade a bit, these did not feel that way. Rotors- The Zimmerman rotors felt like the same weight as OEM. The only different I noticed were the OEM rotors caps seemed to have rivets on them where as the Zimmerman’s appeared to be a single cast. I am not sure what difference this makes. The Zimmerman Rotors are also Zinc plated, I will monitor the amount of corrosion that forms on the hats as this is a known issue with the OEM rotors. Other notes- Driving in traffic was definitely smoother. The sudden bight of the OEM pad is gone making it easier to come to a complete stop or handle stop and go situations. There is still the jerkiness of the transmission, though that can be somewhat controlled through modulating the throttle. The initial bite was a big decision in my mind when I was looking at what pads to decide. Although I liked the initial bite, I have come to realize it has made for a rather unsettling ride. Where the OEM pads would have a great initial grip and fall off at the end, these seem to be the opposite by having less initial bite but following through with braking power all the way through the stop. While it has not even been 24 hours, I cannot give a complete overview of the pads at this point, just my initial thoughts. I will update in one week on any changes, and then in 1000 miles of use after that. Part Numbers- Front HPS 5.0 Performance Brake Pad Set: HB765B.664 Rear HPS 5.0 Performance Brake Pad Set: HB825B.649 Front Brake Rotors (340x30) – Pair: 34116792223ZKT Rear Brake Rotors (330x20) – Pair: 34216864899ZKT *Disclaimer* I am no expert on braking, nor am I a professional mechanic. All of this above information is merely opinion, based off feel and not actual data. Please take into consideration that what I may feel is good braking, could feel like terrible braking to others. The same could be said with pedal firmness, noise, and dust. My opinions are solely based on street application and potential spirited driving situations. These pads are not recommended for track use. |
alexng72147.00 itsalwayscheese1.50 crogers50.50 White43572.50 karapet8567.00 rambalu8078.00 speedster7731.50 Skyhigh1924.50 |
03-18-2019, 11:25 PM | #2 | |
Rep 5,409
One of the reasons that I bought the Hawk 5.0's over other pads is that they heat up much quicker than most of the other aftermarket pads. Some of them claim low dust but brake poorly and take a long time to heat up. Usually first thing on a cold morning after stopping just 1-2 times, my Hawk 5.0's are right up to operating temperature and optimum braking. I'd suggest that you change out your rubber hoses for stainless steel brake lines. I got StopTech for about $100 for the set. I've done this on a few cars. It makes the pedal responsiveness much more solid. Hope this helps. |
10-14-2020, 02:28 PM | #5 |
Rep 479
I used the blanks. I do not recommend Zimmerman if you are after a "clean" look. The Zimmermans functioned well and took hard braking like a champ but they formed a layer of brow/yellow ish rust even though they were zinc coated. This happened in the span of 3 months and by the time winter was done, they looked horrible for a "luxury car". I now use stoptech (centric) blank rotors with a black painted hat. I could not recommend them more, even though they are more money.
10-14-2020, 11:09 PM | #7 |
Rep 3,748
Hawk HPS 5.0 my second choice after akebono.
TK335iMSPT299.00 |
10-15-2020, 12:59 AM | #8 |
Rep 479
10-15-2020, 05:45 PM | #9 |
Rep 3,748
it's been a long while that I had Hawk pads.... The best way to describe Akebono is that it is very similar to Hawk pads as reviewed on here minus less brake dust the last time I had them both but different cars. And yeah akebono comes with sensor in the box.
10-15-2020, 05:51 PM | #10 |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
So I bought Akebono OEM replacements for my base silver brake setup (Front part # EUR 1880 and rear part # EUR 1610) which worked great. Just as good as OEM without the dust. I have not tried them on the track or with any aggressive driving.
This setup is getting placed with M4 calipers, R1 Concepts Carbon Geomet slotted rotors and Hawks 5.0 pads. Looking for to this setup. The car is a daily driver but will see track events through the year. If the Hawks produce more than the Akebono, then I am going to switch back to them and keep the Hawks for track only. But I have seen a few people say they aren't great for track (depending on skill level and driving technique). |
Logicoeur993.50 Onizukachan1137.50 |
10-15-2020, 06:09 PM | #11 | |
Rep 3,748
casualDIYer447.50 |
10-16-2020, 12:25 AM | #12 | |
Rep 3,958
I installed stainless steel lines but when I cut open the older stock lines to inspect the lining, there's steel lining in there already. Pedal feel is about the same to be honest. |
10-16-2020, 12:27 AM | #13 | ||
Rep 3,958
You can get by with M3/M4 pads and stock powertrain. If you want to run back to back sessions or in the advanced group, you'll probably want more track oriented pads than even the M3/M4 pads. |
10-16-2020, 10:19 AM | #14 | |
Moto Lover
187
Rep 591
I will run whatever pads that produce less dust for daily (between Akebono and Hawk) and will most likely run Pagid pads for track days. |
1bad14-F3030.50 |
10-16-2020, 10:59 AM | #15 |
Rep 417
Thank you for the detailed review, I am going to do mine this weekend. I am pairing them with Brembo's 2-piece rotors.
I also picked up some stainless steel lines from ECS this morning, they are having a 10% off on StopTech products, came out to be less than $100 before tax. Will change them if the pedal feels soft after the replacement. |
10-16-2020, 02:11 PM | #16 | |
Rep 5,409
AK415196.50 |
10-16-2020, 02:13 PM | #17 | ||
Rep 5,409
1bad14-F3030.50 |
10-16-2020, 02:15 PM | #18 | |||
Rep 5,409
casualDIYer447.50 |
10-16-2020, 02:20 PM | #19 | ||
Rep 5,409
Race pads are a whole different animal. Talk to Dave Zeckhausen at Zeckhausen Racing. He's a pad guru. |
1bad14-F3030.50 |
10-16-2020, 04:25 PM | #21 | |
Moto Lover
187
Rep 591
Amazon just delivered my Hawk pads. Just gotta wait for my rotors from R1 concepts to come in and I'll be set on my braking system! |
johnung4552.50 |
10-23-2020, 11:15 PM | #22 |
9
Rep 47
I recently replaced my stock pads with Hawk 5.0s and I'm very happy with the out come. As the OP said, the pedal feels more linear then it did with stock pads and would recommend to anyone looking for a sportier street pad.
