02-19-2020, 08:03 AM | #1 |
17
Rep 15
Coding the vehicle sound generator VSG01
I have the new VSG noise in my i3s-20 that make a sound like a space-shuttle at low speed.
The idrive menu option has been hidden on eu models but I managed to enable it with bimmercode. VSG_HMI_MENUE = aktiv (0x01) I want the sound to be off and but every time i start the car it defaults to on Does anyone know how to set the VSG noise to default off ? Can the whole vsg01 be removed in VO? maybe wav file removed/replaced ? |
02-20-2020, 04:23 AM | #2 |
Rep 2
You can set the value "Tuning mode" to "yes" with the bimmer code in expert mode, then the pedestrian protection is always completely switched off, in the normal menu you switch the pedestrian protection to on, so that no bulb appears in the display, and still the pedestrian protection is permanently switched off by the value of the variable "Tuning mode".
I have tried the different values for a longer time to get the right one, because I didn't want to have the annoying sound or the annoying bulb in the display. Greetings from germany.
BMW i3 60Ah REX - 11/2015 - ionic silver - fully loaded - wheel 430 summer F/R 5,5x20 175/55 - wheel 428 winter F/R 5x19 155/70 - SCC-spacers F15/R20 mm per wheel - H&R springs - retrofit: apple carplay + wireless charging
02-26-2020, 02:21 AM | #3 |
17
Rep 15
I'm not talking about the pedestrian protection system warning noise.
I talkning about the vehicle sound generator that has a speaker outside the car and sound like a spaceshuttle at lowspeed (0-30km/h). It's called "Audible Pedestrian Protection" in the idrive menu |
02-27-2020, 03:12 AM | #4 | |
Rep 2
The sound I mean is the "Audible Pedestrian Protection" ("spaceshuttle at lowspeed"). Please follow my procedure, then this sound is switched off. When I wrote "pedestrian protection" I meant the "Audible Pedestrian Protection".
03-05-2020, 09:42 AM | #5 |
17
Rep 15
10-07-2020, 12:03 PM | #10 |
Rep 1
My wife just got the 2020 version in the US. It's her 3rd i3 and the first one with this VSG pedetrian system. I've tried to disable it in the following ways:
- make menu item active (cannot find menu item option anywhere, neither in VSG nor HUD settings) - changed wav file (tried all wav files, none are silent) - changed it to tuning mode (sound still playing) - changed the Table value (tried all 16 settings, plays slightly differently, but never goes away) Any other ideas? |
11-23-2020, 12:15 AM | #11 | |
Rep 422
2023 I4 40 Msport White/red interior 19"Rims
2023 Ix 50 MSport Hraphite Gray.Oyster interios 22" Rims Retired 2020 X7 MSport 40i 2020 I3s Bev |
12-03-2020, 08:15 PM | #12 | |
Rep 8
12-10-2020, 01:56 AM | #13 | |
Rep 906
Does anyone know what the other VSG settings like Baureihe, Start-up Sound, or Antrieb do? I messed around with it and couldn't hear much of a difference.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World Last edited by capt_slow; 12-10-2020 at 02:02 AM.. |
12-13-2020, 10:06 PM | #14 | |
Rep 906
HU_NBT/3001/VSG_HMI_MENUE->aktiv (enables menu in iDrive) VSG/3000/VSG Configuration_7_7_15->aktiv (saves last setting) From what I can tell through experimentation, Tuning Mode only lowers the volume of the sound, but otherwise doesn't do much. Played around with other settings and couldn't make VSG do any other cool things. I do know that Wave File 4 sounds like a pissed off ghost.
2020 i3 Rex: Capparis White, Giga World |
12-17-2020, 12:58 AM | #15 | |
Rep 422
thanks for summarizing...any additional discoveries ?
12-17-2020, 01:00 AM | #16 | |
Rep 422
12-17-2020, 01:05 AM | #17 | |
Rep 422
12-20-2020, 04:09 PM | #18 | |
Rep 906
Here are all my VSG and relevant NBT settings, you need to code both NBT and VSG. VSG/3000/Start-up Sound -> yes VSG/3000/VSG Configuration 7_7_15 -> aktiv VSG/3000/Wave File -> Wave File 4 HU_NBT/3001/VSG_HMI_MENUE -> aktiv
01-02-2021, 01:14 PM | #19 |
Rep 1
I was able to mostly silence this annoying sound
Here's what I was able to code on my 2020 i3:
VSG/3000/Start-up Sound -> yes (was NO) VSG/3000/VSG Configuration 7_7_15 -> aktiv (was NICHT AKTIV) VSG/3000/Wave File -> Wave File 4 (was Wav file 1) VSG/3000/Tuning Mode -> YES (was no) HU_NBT/3001/VSG_HMI_MENUE -> aktiv (was NICHT AKTIV) I still have that wailing ghost sound when the car goes in reverse. I'm actually good with that because I feel like it is necessary when backing out of parking spaces. The noise is still there when the car is in drive but it is significantly quieter.' Thanks to everyone who posted above. |
01-09-2021, 09:49 PM | #20 |
Rep 5
Unplug the front and rear speakers...
Just wondering...anyone try unplugging the front and rear speakers?
I’ve never coded with Bimmercode - or anything else for that matter. I’ll likely jump in and try for things like auto folding mirror settings, etc. Are the code settings easy to change with the app? Does anyone have any further updates to completely turn off the sound in drive and reverse? Thanks |
01-10-2021, 08:29 AM | #21 |
13
Rep 22
The VSG is not just a speaker. It's a smart device that receives messages from the car's network telling it what sound files to play. If you unplug it (it's in the front right corner of the car just behind the bumper) the computer trying to communicate with it will likely detect a fault.
01-12-2021, 04:41 PM | #22 |
Rep 422
I coded the feature to manually turn it off but dont like doing this all the time, i still get the little triangle message ...soo i un plug both speakers...silence again!!
