09-17-2020, 10:08 AM | #1 |
Rep 1,125
Drives: 2015 BMW 435i Xdrive MSport
Who makes the rotors and pads for the M Performance Brake kit?
Does Brembo make the rotors and pads? I'd like to know for future reference so I'm not stuck buying the rotors from BMW. The dust on pads suck but they bite in my opinion.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
09-17-2020, 11:42 AM | #2 |
Rep 1,072
You can buy drilled and slotted rotors for the m performance kit for 140 an axle from power slot brakes from Amazon with free shipping.
Zimmerman I believe manufactures the official BMW ones however.
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
09-17-2020, 12:43 PM | #4 |
Rep 1,125
Never even heard of JURID. I guess that just leaves the rotors.
09-17-2020, 02:03 PM | #5 |
127
Rep 283
Jurid are a high end German brake component manufacturer and have been turning out top line brake parts for many years.
The main factory is in Glinde Germany, factory uses very high spec machinery indeed to manufacture said bits lol, my shop has used Jurid for many years for brake components for my more discerning customers, for the rest I use TRW or Apec which are still excellent quality, but Jurid are top line and you would be very surprised just who they make OE parts for. Last edited by bellguy; 09-17-2020 at 02:11 PM.. |
Boostedphil698452.50 |
09-17-2020, 02:38 PM | #6 | |
Rep 1,125
09-18-2020, 05:01 AM | #7 |
59
Rep 129
I have read on here that the Hawk 5 brake pads are dust free and very very good,,, I still have the OEM filthy factory set as my car is on lease still.
https://www.hawkperformance.com/hps-5-0
(OO-(lllll)(lllll)-OO)
09-18-2020, 06:12 AM | #8 |
127
Rep 283
I myself would say Brembo are the OE manufactures for our BMWs, but if you want another option then Jurid will definitely not disappoint you.
Boostedphil698452.50 AndrewC198910949.00 |
09-18-2020, 08:40 AM | #9 |
Rep 833
Drives: BMW F36, E36, E93
No, these rotors are actually really made by BMW. But since the calipers are Brembo you could take Brembo rotors and matching Brembo pads
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
09-18-2020, 09:30 AM | #11 |
Rep 1,125
I really didn't think BMW made their own rotors!
09-18-2020, 10:17 AM | #12 |
Rep 833
Not all rotors are made by BMW, this information is only valid for the "performance" parts.
Such Fun
09-18-2020, 10:33 AM | #13 |
Rep 1,125
Oh, makes sense. I really like the rotors that came with the M Performance kit.
08-21-2022, 07:43 AM | #16 |
Rep 468
Been down this road. The rotors with the M Performance BBK are Brembo dimpled/slotted and non dimpled/slotted rotors made for BMW and can be had aftermarket from a Brembo rotor reseller https://eeuroparts.com/product/brembo/1647938KIT.
https://eeuroparts.com/product/brembo/3054204KIT My complaint and $0.02 with the MPBBK brembo rotors is they're not directional so the inner vanes and dimples are not directionally different from left to right side of the car which may effect hard braking cooling. Also the pads that come with the MPBBK stop well but are very dusty and noisy. I went with StopTech directional drilled rotors and Hawk 5.0 street pads with no regrets. Also I weighed the Brembo rotors and they are actually about a pound heavier than the StopTech drilled rotors which surprised me seeing the Brembo rotors have aluminum hats. |
08-21-2022, 09:04 AM | #17 | |
Rep 1,125
johnung4552.50 |
08-21-2022, 09:16 AM | #18 |
Rep 468
08-21-2022, 10:02 AM | #19 | ||
Rep 5,409
Front 370mm x 30mm and Rear 345x24. Separate Left and Right part numbers because they all have directional internal vanes for optimal cooling. Also photo of part numbers for Hawk 5.0 pads. They have the best bite by far without the sticky black dust of the BMW pads. |
Boostedphil698452.50 Runner340369.50 |
08-21-2022, 10:39 AM | #20 | |
Rep 468
128.34140L 128.34140R I know some folks with the grey 4 piston front Brembo/BMW sport brake calipers with 340mm x 30mm rotors will swap out the stock 1 piston rear calipers for some used F8x rear 2 piston blue calipers and paint the grey fronts to match. Actually a pretty good setup without breaking the bank. Also a good setup for someone running 17" wheels up front. The front 370mm x 30mm rotor and caliper setup require a minimum 18" wheel for them the fit. |
08-21-2022, 11:57 AM | #21 | ||
Rep 5,409
G2USA Caliper Paint is a great solution to a color change. Hawk 5.0 pads are the most noticeable difference and biggest bang for the buck with any sized F3x brakes. |
