SOLVED: N54 Oscillating throttle position/surge at steady speed
05-26-2022, 02:48 AM | #45 | |
Rep 72
Drives: BMW 335i
06-04-2022, 12:45 PM | #46 |
20
Rep 48
Apologies for delayed response.
I only flashed the once since I fixed problem previously. I just flashed to stage 0 as I know I'd blown a seal in my rear turbo and wanted them to spin as little as possible for the journey to the garage. But as soon as I got to the motorway on cruise control it was back with the oscillation... As you can see in earlier posts, nearly everything has been replaced, no boost leaks, holds vacuum as well as pressure.. Reference the post regarding engine codes and reduced power, this must be somthing different entirely. From my limited experience, I do beleive it is down to the throttle body, now being poorly managed by the DME due to the flashing issue. I come to this conclusion, at the AFR readings were in reaction to the throttle position variations. I would rule out wheel speeds sensors, as this would be present regardless of tune or number of times flashed.. Plus it occurs regardless of using cruise control, so that rules out cruise control being the issue. CC just maintains the parameters required to present the issue much better than manual throttle control. Hope this helps. Last edited by Wadger; 06-04-2022 at 12:52 PM.. |
06-04-2022, 01:37 PM | #47 |
Rep 12
I too am having this issue. It's only at light throttle while at cruising speeds. Under WOT or while running through the gears ot runs great. It's only while driving at a continuous speed.
I may try flashing back to stock and then loading MHD again. Hoping it's not my cam ledges. |
06-04-2022, 05:56 PM | #48 | |
Rep 3,669
06-05-2022, 09:53 AM | #49 |
Rep 1,544
It's 100% unrelated to flashing. This is just superstitious nonsense.
All the data im the binary file is checksum protected so if the contents of the flash don't match what was in the data exchange file then the car would not start. Writing back to stock then writing the OTS maps repeatedly isn't fixing anything. The cause of the oscillations are because of the catalyst and O2 sensor diagnostic routines. I have given the fixes for these problems to Wedge so I expect this will be fixed in the OTS maps in the next revision. This problem has been discussed in depth on other N54 forums and anyone running a custom tune is able to fix this themselves. |
06-05-2022, 10:50 AM | #50 | |
Rep 3,219
Many thanks for your input and help. |
06-05-2022, 11:46 AM | #51 | |
Rep 1,544
It can happen on catted cars that have bad O2 sensors or bad cats. The diagnostic routine manipulates the lamba target and looks for a proportional change in both up and downstream O2 sensors. It also looks at the lag in response along with a change in readings between the up and downstream sensors to work out how healthy the cat is. These tests only occur at cruising and sometimes idle conditions. Once the engine is put under load they stop. |
06-05-2022, 12:41 PM | #52 | |
Rep 3,219
Dave92N54528.00 |
06-05-2022, 05:56 PM | #53 | |
20
Rep 48
Can you advise the reason this would only present itself on certain occasions? I assume it always does it, just the severity of the fluctuations change? For example my issue was only noticeable(but maybe always present to a lesser degree) after flashing to stage 0,however I've experienced it on all stg2, stg2+ and stg0 maps regardless. And the only way I stopped it was doing the full write. Finally getting hybrids fitted and getting a wedge tune, so this should be covered in the new tune, just interested to understand in a little more depth. Thanks again for the detailed response, just what I was looking for. |
06-05-2022, 06:20 PM | #54 | |
Rep 1,544
They do also stop sometimes for a period of time which I assume is related to conditions that inhibit the starting of the routine. Most errors inhibit them and errors can periodically reset. |
06-30-2022, 04:25 PM | #55 |
Rep 1,165
Drives: 09 E92 335i 6MT
Everyone! Reflash your maps!
Anti-lag and map switching are now available! The common surging at low throttle input has been fixed as well!
09 E92 335i 6MT / Alpine White / Coral Red / VRSF 7.5" / VRSF DCI / VRSF Catless Downpipes / VTT Charge Pipe / Turbosmart RacePort Gen V / RB OEM Billet Turbos / CD919 Custom Tune / Bilstein PSS9s
TSilver335i39.00 lightmanek116.50 |
06-30-2022, 05:32 PM | #56 | |
Rep 3,219
Map switching is pretty handy, but Have you tried rolling anti lag? |
06-30-2022, 08:36 PM | #57 | ||
Rep 1,165
06-30-2022, 11:37 PM | #58 |
Rep 3,219
07-01-2022, 02:19 AM | #60 |
Rep 3,219
07-01-2022, 09:03 AM | #61 |
202
Rep 384
Does your car still accelerate a good bit when using antilag? With mine at 15psi the car accelerates almost like stock WOT, maybe it's tuned for stock turbos and doesn't work well with upgraded ones
07-01-2022, 09:42 AM | #62 | |
Rep 1,165
I was reading on *********** that they did set it up for all kinds of turbos depending on your map. I do also believe your tuner can tweak some of the tables for it as well.
lightmanek116.50 |
07-05-2022, 09:13 AM | #63 |
175
Rep 344
So for people who have been chasing their tails with this boost oscillation, it was an issue with programming in MHD?? Were custom tunes affected by this issue?
07-05-2022, 01:42 PM | #64 | |
Rep 3,219
RB1/2 Twins spin up fast with a lot less lag than singles, so it might not even feel much different |
07-05-2022, 09:45 PM | #65 | |
Rep 1,165
Read farther up in the thread. What i've gathered is it was related to the way MHD cleared the CEL for the downpipe codes. I'm guessing now checking the box for catless downpipes also disables the diagnostic routines that were responsible for the oscillations.
