TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - Rockies / Midwest > Hello Colorado, Goodbye 2020
      12-22-2020, 03:02 PM   #1
IN54NITY
Major nutz
IN54NITY's Avatar
Drives: '09 n54 e92xi, 6mt, kw v3
2009 335xi  [8.89]
Still have my '09 e92 that I bought new.
107,570 miles. Only drove it about 300 miles this year with Covid...
Still pulls hard.
In the 11 years since I bought it from (now gone) Murray Motors in Denver:
Oil changes every 4k or so (sometimes more frequent)
HPFP @5k - warranty
Used Brembo BBK @ ~10k
Numerous brake fluid flush/bleed/replacements
New spark plugs every 10k or so
40k miles
Battery replacement
02 sensors replacement
1 walnut blast @ ~ 42k (oil catch install at that time too --> really helps, checked @85k, need to check again)
Between 50k and 60k miles
Fuel Injectors
VC (cracked) and gasket replaced
Alternator replacement (twice, but because original replacement also went bad )
Oil filter housing gasket replacement (same time as alternator, 'cause the alternator is a PIA, and helps to remove oil filter housing)
Trans & front/rear diff and TC fluid replacement (need to do again)
Right front half-shaft (CV joint) replacement
80k miles
Water Pump & thermostat replacement
Car has been trouble free since the water pump.
To do:
Front hub replacement
Possible left front half shaft replacement
Diff & Transmission fluid replacement
Possible walnut blast
Still like this car and enjoy working on it, even though engine bay makes if feel like you are working on a 10# of s#!t in a 5# bag.
KWs - Vorshlags - APEX EC-7s - "My garage" has suspension install pictures.
_____________________
      01-20-2021, 11:18 AM   #2
335dlci
Drives: 335d
Originally Posted by IN54NITY View Post
Still have my '09 e92.
Still pulls hard.
In the 11 years since I bought it new from (now gone) Murray Motors in Denver:
HPFP @5k - warranty
40k miles
Battery replacement
Fuel Injectors
80k miles
To do:
If you need any help. Im local
