03-02-2021, 03:46 AM | #1 |
the senate
16
Rep 25
Drives: 2016 435i
best catted downpipe?
currently planning to get the CG Precision catted downpipe as I want one that doesn't throw a CEL - the Fabspeed one is really expensive.
What are your thoughts on the CTS Turbo catted downpipe? It is like half the price of the CG Precision one. Anyone know if it throws a CEL? What about the (new?) VRSF? It looks like VRSF doesn't have the extra downpipe brace that the others have. |
03-02-2021, 06:04 AM | #2 | |
Rep 3,958
03-02-2021, 10:09 AM | #3 |
24509
Rep 191,503
Active Autowerke, CG precision and Fabspeed are the top 3. They perform the same, sound very similar, and guarantee no CEL guarantee. All three fit without any issues.
You have a very high chance of getting a CEL with all the other brands. If your car is not tuned with bm3, I recommend you get one of the three brands mentioned. It won't matter which one.
03-02-2021, 10:37 AM | #4 |
M340i
408
Rep 1,010
Drives: BMW M340i
They are all the same. Some just charge more.
03-02-2021, 11:29 AM | #5 | |
Rep 7,634
And yes, every single other brand that i am aware of has been reported to give a CEL. If you don't care about that or the emissions aspect then any catted should reduce the smell. Just depends on what you need to get out of it. |
superherorockstar63.00 johnung4552.50 |
03-02-2021, 11:52 AM | #6 | |
32
Rep 90
Thanks |
03-02-2021, 04:19 PM | #7 | |
Rep 3,958
03-02-2021, 06:05 PM | #8 |
Rep 7,634
03-02-2021, 06:12 PM | #9 | |
Rep 417
After reading about the smelly side of the downpipe, I am leaning towards catted. But I definitively want to run stage 2 in the future at the track. |
03-02-2021, 06:28 PM | #10 | ||
Rep 1,934
03-03-2021, 10:51 AM | #11 | ||
24509
Rep 191,503
the catted downpipe is compatible with a stage 2 map. if you are using a flash tune like boootmod3, it won't matter which catted you get as bm3 hides the CEL. If your car is using a piggyback or stock, you need to get one of these 3 brands mentioned for a no CEL guarantee.
03-03-2021, 04:11 PM | #12 |
Rep 417
I understand, thank you for the clarification.
'16 M4 bone stock
'13 335ix Msport BM3 stage1 - MAD FMI - FTP CP - Bilstein B4 (SOLD) '85 635csi M30 turbo race car (SOLD) |
03-04-2021, 08:37 AM | #13 |
63
Rep 126
Fwiw I have had the AA catted installed for about 2 months no tune and no cel. Performance has been great sounds about 10-20% louder than stock. The up shift fart sounds are a bit more defined. I highly recommend it. I got mine from Mike at Xph
03-04-2021, 09:09 AM | #14 | |
24509
Rep 191,503
we use the Active's catted downpipe on the shop's 340 as well, one of the best mods we have gotten so far
03-05-2021, 01:49 AM | #15 |
the senate
16
Rep 25
Drives: 2016 435i
Thanks everyone that responded - I am tuned stage 1 with bootmod3 right now. Would it be crazy to spend $1k for an AA or CG Precision downpipe? I would like less smell & emissions. And I think they would also lengthen the life of the secondary O2 sensor?
If they're both the same I'll get AA since it's $30 cheaper. Maybe mike@x-ph.com can give me a little discount code? Last edited by nitro_boss; 03-05-2021 at 02:03 AM.. Reason: more info |
03-05-2021, 09:45 AM | #16 | |
Rep 7,634
03-05-2021, 09:45 AM | #17 | |
24509
Rep 191,503
Check your inbox
nitro_boss16.00 |
03-05-2021, 12:46 PM | #18 | |
Rep 1,125
Drives: 2015 BMW 435i Xdrive MSport
I believe AA does not have any in stock currently, probably because HJS cats are hard to come by because of the pandemic.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
03-05-2021, 01:21 PM | #19 |
Rep 5,394
You get what you pay for with catted downpipes. Not only do you risk having to deal with constant check engine lights, cheaper catted downpipes run cheap cats. Those cats don't live long behind a turbo generating a ton of heat, especially one that has overrun (i.e., pops/burble/crackles). If the overrun is set to an aggressive setting, it will melt the cats very quickly, even the cats used in the higher quality catted downpipes.
Expect to pay $1,000+ for a quality catted downpipe. If you go cheap, you'll end up spending more in the long run.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
alohasurftoad3132.00 |
03-05-2021, 01:48 PM | #20 | ||
Rep 5,410
03-05-2021, 01:55 PM | #21 |
Rep 4,218
GESI maybe, which is high quality as well
Mods: Yes.
03-05-2021, 02:58 PM | #22 |
32
Rep 90
435i, catted, cel, downpipe |
