03-25-2021, 04:50 PM | #1 |
Rep 417
Rear wheel bearing
Still not a month of ownership and the noise I am hearing at the back is probably a rear right wheel bearing.
And BMW being super cheap, they have a pressed in bearing and some fancy new axles without bolts... (I miss my E60 already). There is 1/2 a video on youtube where the guy disconnect most of the suspension to get the axle out of the rear hub and leaves it attached to the differential. 1- Is it better / possible to remove the axle only (without expensive BMW tool) and then press the bearing in and out? (I have a bunch of tools to press the bearing in and out.) 2- Will putting the axle back into the hub give me trouble? From the search on the web/forum people mainly get it done at the dealer or a shop.
'16 M4 bone stock
'13 335ix Msport BM3 stage1 - MAD FMI - FTP CP - Bilstein B4 (SOLD) '85 635csi M30 turbo race car (SOLD) |
03-31-2021, 12:27 PM | #2 |
Rep 417
I love replying to my own threads...
So yes it was the wheel bearing, and I never liked changing them as so much usually goes wrong. Shop next door removed the whole spindle and changed the bearing on the press. The axle in and out was a pain, glad I didn't do it. Car is now very quiet.
'16 M4 bone stock
05-13-2021, 10:58 AM | #4 | |
Rep 10,325
05-14-2021, 10:49 AM | #5 | |
Rep 417
Seems really low if you ask me, I still have the original wheel bearings on my '85 635csi and I never changed them on my 2 E60 and they both had above 240k miles. It would seem that there is some cost saving involved in newer cars, like the newer fridges...
'16 M4 bone stock
sdbwisc66.00 |
10-19-2022, 08:09 PM | #8 |
767
Rep 2,362
11-27-2022, 09:41 AM | #9 |
Old Member
125
Rep 81
How to Replace the rear hubs & bearing without removing the axel at the diff
If you are like me and are a DIY'er and found yourself on this posting trying to figure out how to do this Job.
Then did it. Here's the 10K foot view on how to replace the rear hubs & bearing without removing the axel at the diff in photos. In summary, pull the hub with a slide hammer & applying heat on the bearing with a torch is highly advised. Then get to slide hammering. Trust in the process. -sometime later. Once the Hub is out, press the bearing out. There a many videos on this process. This is the tool I used: https://a.co/d/5YH6n70 Now unbolt the upper to rear control arms and rear toe link. Articulate the wheel knuckle downward and pull out the axle. Carry on with the repair. Repeat on both sides for peace of mind.
Car Stuff
Ennoch2264.00 mike082802115.00 |
03-09-2024, 09:59 AM | #10 | |
Rep 430
How did you handle pressing the hub back onto the output shaft? |
03-09-2024, 11:11 AM | #11 | |
Old Member
125
Rep 81
My at-home DIY solution was simple and thought up on the fly, as I did not realize how much of a pain it would be to reseat the shaft. Process - Assuming you used the method of disconnecting the top control arms to drop the assembly forward. Clean the spindle shaft and apply a very thin amount of bearing grease to the shaft. Line up the spindle to the hub assembly. Reinstall the control alarms temporarily. You do not need to tighten the bolts all the way. The goal is to hold the assembly in place. With everything lined up and the hub assembly mostly where it should be. Use a 2x4 or other scrap wood wide enough to span the width of the hub bearing receiver (solid metal lip, not the bearing), then tap, tap, tap it in with a hammer striking the wood. After some tapping, threads will start to protrude. Once you have about two threads, you can thread the spindle nut on the shaft, then by hand, not power tools, tighten the nut, thus pulling the shaft all the way through. Done!
Car Stuff
03-09-2024, 11:59 AM | #12 |
Rep 1,004
not a fun job, did this last sunday. took the whole day and 3 trips to home depot/harbor freight. the bearing retainer clip was a pain, broke 2 snap ring pliers, also had to cut the remaining old bearing off with a cutoff wheel that was stuck to the hub. i used a n amazon bearing press kit to get the hub back in.
03-11-2024, 10:38 AM | #13 | |
Old Member
125
Rep 81
Yep. I agree. It is still a DIY garage-doable project. I bought the Harbor Freight ICON snap ring pliers kit. However, I should have just bought the largest tool they had in the store, as the kit's maximum size was just not enough. I rented the 5-pound sliding hammer puller from AutoZone because all the other bearing pullers kept deforming the hub. It still took 3 hours of whaling on the slide hammer, plus heat from a torch. Once the outer race was clean and clear, I used an eBay bearing press kit. Rinse and repeat on the other side because repairing in pairs is the way to go. Then beer. In hindsight - Buying a hydraulic hub puller and larger snap ring pliers would have made for much better use of time.
Car Stuff
03-12-2024, 08:35 AM | #14 |
33
Rep 80
this job sucks, if you don't get the new bearing in perfectly they can bind and you're back to the beginning... ask me how I know. Had to bring the knuckle to a shop to use a proper press and put the new bearing in.
Also, I tried using the axle nut to pull the axle through, did not go well, partially because i warped by bearing getting it in, but this tool helps: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
