11-01-2008, 10:15 PM | #1 |
Moderator
675
Rep 4,737
Some E92 M3 Suspension Torque Values (Official BMW Specs)
UPDATED: Official BMW Specs!
Thanks to the help of a BMW tech and PencilGeek! FOR REFERENCE ONLY! USE AT YOUR OWN RISK! 20 ft lb KW camber plate torx Last edited by rzm3; 12-11-2009 at 11:35 AM.. |
11-01-2008, 11:21 PM | #2 |
Rep 6,107
good info ... last picture, is it the rear part of the car ? is the 25ft-lb for the bolt that holds the rear shock ?
11-02-2008, 08:21 AM | #5 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
Excellent! Thanks for the very useful post. Appreciate your efforts.
11-02-2008, 11:10 AM | #6 |
Moderator
675
Rep 4,737
11-06-2008, 08:52 PM | #7 |
Rep 1,973
DUDE!!!! You kick ass. I've been looking for this info forever! Where did you get the values from? Do you have torque specs for the rear install?
MDCT ... so you can drive and eat a hamburger at the same time. |
11-06-2008, 09:10 PM | #8 |
Moderator
675
Rep 4,737
The last picture is the rear install. Couldnt really figure out one of them, but it was very tight, so tighten as much as possible.
11-06-2008, 10:24 PM | #9 |
Rep 1,973
So how did you come up with these values?
11-07-2008, 12:14 AM | #11 |
Rep 1,973
11-07-2008, 01:18 AM | #12 |
Rep 10,407
When is the darn full shop manual going to come out? We should not have to go through such measures to get torque values. Thanks indeed for the very useful post. Most thoughtful.
11-17-2008, 12:12 PM | #16 |
Rep 1,973
Nice, rzm3 ... now you can update your original post with the top nut torque specs.
01-15-2009, 02:25 PM | #19 |
256
Rep 2,091
Does anyone know what torque to tighten the front strut hat nuts (the ones that hold the front strut to the strut tower)?
2012 Audi R8 V10TT| 6MT| Suzuka Grey
2015 Ferrari 458 Speciale| Rosso Scuderia 2020 BMW X7| Mineral White 2024 718 GT4 RS | Arctic Grey |
12-17-2009, 06:43 PM | #20 |
Rep 91
What does “64 Nm or 47 ft-lb” refer to?
OK, I’m a bit confused here. In the second diagram it shows “64 Nm or 47 ft-lb” pointing to the top of the strut assembly, yet it looks like the next diagram shows 37 Nm or 27 ft-lb pointing to the nut which goes on top of the shock. What does the “64 Nm or 47 ft-lb” actually refer to? Is that shaft of the EDC shock supposed to be tightened? I thought the shaft just spins in place and the bolt (37 Nm or 27 ft-lb) on top of the strut is what you are actually worried about tightening.
This might be obvious, but I need some direction here |
12-17-2009, 08:04 PM | #22 |
Rep 91
Yes, I know which is front and rear. So the bolt on the top of the front strut is 47 ft-lb then?
I guess I was confused by those last couple of posts [I]PunjabiM3 Does anyone know what torque to tighten the front strut hat nuts (the ones that hold the front strut to the strut tower)? rzm3 34Nm [/I] |
