06-26-2021, 06:29 AM | #1 |
64
Rep 113
BMW F32 435 Mtech Fancywide rear Diffuser
I would like to introduce you Rear diffuser for BMW F32 435 with Mtech rear bumper. No need to drill, easy installing bolt on. All mounts included. It is a aluminum diffuser, which looks great and easy to install (bolt on). Fits on BMW Mperformance bumper. Material: aluminum + magnesium 2,5 mm thickness All fasteners / screws / nuts included Extra folding Powder paint – color black Matt (polymer) Weight 3 kg 15% Discount for first 5 orders! Just use promo code: F32 in our shop.
06-26-2021, 04:26 PM | #2 |
Rep 1,934
No F30 love?
07-05-2021, 07:22 AM | #6 |
64
Rep 113
07-05-2021, 12:10 PM | #7 |
Grand Poobah
15
Rep 94
Pretty much just narrower outboard pieces, no?
It "looks" like the middle is fine, I just would need narrower outboard pieces, such that the resulting gap for the tips was 155mm. If that's potentially a thing, I'll buy one. Last edited by evilsaint; 07-05-2021 at 12:17 PM.. |
07-11-2021, 10:22 AM | #8 |
Grand Poobah
15
Rep 94
07-14-2021, 02:46 AM | #9 |
64
Rep 113
the distance length from fins is 11 cm.
I think that a pipe with a diameter of 10cm will fit there, or do you need more?
07-19-2021, 05:58 AM | #11 |
64
Rep 113
too much for this model. we could make a custom model for you if you're interested!
07-21-2021, 03:21 AM | #14 | |
64
Rep 113
you need to understand what shape is your exhaust
11-30-2021, 01:28 PM | #16 |
No 55mph
1623
Rep 8,479
Just outta curiosity - why does the Center section of the MTech version have 4 fins while the MPerf only has 2?
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
01-09-2022, 09:39 PM | #20 |
Rep 1,148
Not to derail this, those looking for f30 diffuser, this company makes them
https://www.aeroflowdynamics.com/col...ar-diffuser-v1 That being said, I reached to fancy wide and they basically said no go on f30, hence this post |
Logicoeur993.50 |
01-20-2022, 06:40 AM | #21 | |
64
Rep 113
05-07-2022, 02:06 PM | #22 | |
Rep 1,934
Pussiwillow522.00 |
diffuser |
