BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic Maintenance: Wash, Wax, Detailing, Repairs > A little help with "eDrive" badge positioning (330e)
Extreme Powerhouse
      10-18-2021, 12:52 PM   #1
jaf30
Drives: F30 330e
I've recently had my '16 330e go in for a polish, and subsequently the "eDrive" badges on the C pillars were removed. Unfortunately the shop did not keep note of the exact positioning, so I'm in need of a little help!
If anyone with a 330e could make a quick sketch up with some accurate measurements I'd really appreciate it.
Thanks
      10-20-2021, 02:21 PM   #2
f30paul
f30paul's Avatar
52
Drives: F30 330e
Mine measures 50mm in from the edge of the black plastic trim around the window, and 70mm from the base of the badge to the bottom edge of the black trim at the window base/where the hofmeister kink ends, if your eyes continue that line across… hope that helps? Can sketch if clearer…
      10-20-2021, 03:13 PM   #3
jaf30
Drives: F30 330e
That's really helpful, thanks
I'll save you the trouble of a sketch and link this. I should have done this to start with!
View post on imgur.com
What would the measurements be for these? Thanks again - you're a star!
      10-20-2021, 04:28 PM   #4
f30paul
f30paul's Avatar
52
Drives: F30 330e
So A I had measured from the bottom of the E, and from the bottom left corner of the ‘e’ that is 50mm to the edge of the black trim. Your red line is correct, but again I measured 70mm high to the bottom of the E, not the top. Offside measurements the same, but on mine the 50mm measurement is from the bottom right point.
jaf302.50
      10-21-2021, 12:08 AM   #5
jaf30
Drives: F30 330e
Super!
I understand what you're saying!
Thanks again for this. Life saver
