02-25-2022, 06:23 PM | #1 |
Rep 2
F30 335i Logs - Stuttering, Rough Idle, Power loss
Hey all,
I'm pretty sure I know the gist of what's wrong (big ass boost leak), but I wanted to get some other eyes on it if possible just to verify. I somewhat recently installed the charge pipe, so that's my first go-to on the list to inspect as I didn't have issues before. It's due for spark plugs and coils, and I have some NGKs on the way. Car:
Issues:
Logs: https://datazap.me/u/barkalow/stutte...=1&data=4-6-25 There are two logs, the first is a slimmed down easier to read version and the other is the full logs. You can switch between them at the top left of the graph. Things I noticed in the logs:
Anything else look out of place to a more trained eye? |
02-25-2022, 09:46 PM | #2 |
1299
Rep 3,541
The part throttle stuff doesn't tell you much. Do a wot pull.. 2k up to at least 6.5k in 3rd or 4th.. or both. The deviation you're seeing there is normal btw.. means nothing. Part throttle always has knock and timing changes.. normal
I had a stumble issue at idle and it was bad under light throttle below 3k.. was a spark plug that was physically broken.. it can be so many things.
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
boost, leak, logs, n55, stutter |
