08-23-2022, 03:32 AM | #1 |
27
Rep 85
We finally have alternative icon headlights for f32!
€ 1.515,35 24%de DESCUENTO | Faros delanteros para BMW F32 2012-2019 F82 M4 GTS, luces LED DRL, lentes de xenón Hella Hid H7, accesorios de coche
https://a.aliexpress.com/_vqJJLT Well, it seems that someone has finally decided to make them, they look very good. They are not cheap, but if the light projection is good, I would be encouraged to buy them... Let's see if anyone dares! |
08-23-2022, 01:39 PM | #2 | |
14
Rep 103
08-24-2022, 10:39 AM | #5 |
Rep 1,387
I'd love to see some customer photos and possibly a video.. I'm presuming they loose full adaptiveness? The other clone/copies AKD do for F30's loose adaptiveness
I'm considering them as I need some down time on my OEM icons which I need a few weeks with modifying them. |
08-24-2022, 10:45 AM | #6 |
Rep 1,387
ah never mind.. having properly translated all of their product photos it's a xenon headlight with mods, this will be why they have disclaimer about the headlights already being opened and having visible glue on them.
08-24-2022, 04:53 PM | #7 |
88
Rep 352
I'm so surprised there isn't more of an aftermarket options for our headlights, it's disappointing.
I'm having to open mine up and modify it |
08-25-2022, 06:51 AM | #8 |
Rep 1,387
This is the video demo they've sent me of the headlights https://streamable.com/9ljg3h
They've used LED housings and frankensteined the xenon ballasts into them.. I appreciate it's a lot of effort they've gone to but I wouldn't personally be dropping £1500 on a frankenstein build lol. This also confirms that the adaptive light splitting feature won't work or anywhere nearly close as OEM sadly. |
08-25-2022, 06:56 AM | #9 | |
Rep 1,827
08-30-2022, 07:52 AM | #10 | |
Rep 1,387
You'll need to get someone to fit you an addressable solution, it would require a an out of headlight module to sequence it too. |
08-30-2022, 10:14 AM | #11 | |
Rep 1,827
08-30-2022, 07:57 PM | #12 | |
Rep 1,387
LED strips for the job require either 5V or 12V power fully regulated (anything under will flicker, anything over will burn it out instantly). I believe the turn signal wire that goes into the plug produces around 6-7V's as I tapped this to trigger my modules turn signal mode. |
11-22-2022, 04:36 AM | #13 |
Rep 2
Tip: You can get them cheaper on alibaba.com, 750 USD.
https://www.alibaba.com/product-deta...634053352.html I'm also very excited about these, and would consider to try them out. Would love to get some impressions, pictures or videos from costumers. |
11-22-2022, 10:09 AM | #14 |
Noob
70
Rep 255
yea im really glad we finally have an aftermarket solution for the LCI headlights for our 4 series cars, I love U shaped DRL's unfortunately the halo's look too dated now. Has anyone bought these and tried these out state side?
FBO, MHD Stage 2+ E20, Xhp Stage 3
11-23-2022, 04:34 PM | #15 |
88
Rep 352
I think there are a few different versions out there.
There is a Frankenstein xenon version, there appears to be an actual LED version and I think I have also seen some halogen ones?!? If someone can take the bullet and try some and review for the community that would be super helpful |
11-26-2022, 04:05 AM | #17 | |
70
Rep 208
They do look great though identical to oem looks wise |
11-28-2022, 07:50 PM | #18 | |
88
Rep 352
There are definitely different versions in the Chinese market. Looks like the ones you have are the first ones. I think since then there may have been changes already? I can't be sure but thats the gamble. On Ali express there are several reviews one the xenon Frankenstein ones with positive feedback/review |
11-28-2022, 09:06 PM | #19 | ||||
113
Rep 339
They are all made by the same factory but sold by many different sellers on AliExpress and other channels Reason why you don't see them on eBay and Amazon yet because they aren't "ready" there are still many small issues yet to be fixed. If they sell it on eBay and Amazon there will be massive return and they know it Anyway just wait a little longer before buying them. It's tempting but you will be stuck with it like me. |
BMW BRAD214.00 |
11-29-2022, 12:49 PM | #20 | |
88
Rep 352
12-11-2022, 04:27 PM | #21 |
Rep 1,387
I was actually talking to Marius last week who does a lot of headlight installs and coding.. I'm in middle of modifying my icons and needed a new module coding onto the car, I got chatting to him about these and he's had customers with both the xenon frankstein version, plus the actual LED projector versions.
From what I recall he said the main issue was for US customers, as nearly potential customer cars came with xenon adaptives. These knock offs aren't adaptive, they don't have the same build spec and you would have to go as far as retrofitting the correct camera system to get there if they did so happen to be adaptive. He also said they came with a built in FLE module (ballast module) which is the main suspect for faults and them not working. I would presume this means it's not really possible to code the headlights to the car ECU rendering them pretty useless. On a positive note hopefully I can find the manufacturer for these as I could do with spare internal trim parts lol. I had to buy a second set of icons to cut open for my most recent project.. |
Squibby199669.50 |
12-21-2022, 07:16 PM | #22 | |
88
Rep 352
I'm pretty serious about giving one of these a shot depending on a few factors and need to speak to someone who has had real life experience with them* |
