03-11-2023, 11:09 AM | #1 |
Rep 17
Hey every one,
my first post, here, I've searched in the forum a lot but no luck so far, hope you can help. I damaged my F31 by trying to upgrade the AC controls panel from IHKA to IHKA3 controls. initially the new panel worked partially, and it's display showed only the fan related part but couldn't control the temperature. then I coded IHKA: KLIMA_SG_ART => ІНК_2Z, which didn't help. then I found a post saying that if I swap the controls connector cables order : KL30, KL31, LIN -> LIN, KL30, KL31 It would make the controller talk to IHKA. but once I made the change and connected the controller, every thing went OFF : * the horn not working * head-lights controller don't control the head-lights anymore * signals and wiper stalks don't work * steering wheel controls don't work * horn does not work * radio and ac controls panel lights are off and don't work * wipers are alway on * and tins of error codes also reading CAFD in e-sys is failing with timeout error I'm lost and have no direction, checked all the fuses and nothing is blown, any help is much appreciated Edit: I’ve already restored the original connector cables order, but still the same issue |
03-11-2023, 06:00 PM | #8 |
Rep 1,607
Need to post your error codes from ISTA+ and your control tree. Will help to narrow down the problem...which now could be numerous issues like a blown fuse, bus (LIN, CAN) communications, ECU firmware corruption, etc.
Could try to Esys-code (not program) your IHKA with your factory FA. But, if the IHKA is not communicating with the rest of the car, you can't code it and can't see the CAFD either. So, check in ISTA and see if you can get the IHKA to respond as an ECU before going any further. Clear the codes while there.
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
03-12-2023, 05:35 AM | #9 |
Rep 17
Hey i dont have ISTA, only e-sys, so i will try to code with the original FA first and update you
Here are the codes, clearing them didnt help: Car Scanner ELM OBD2 DTC report Selected brand: BMW VIN: WBA3K11010F854971 ============1============== 244800 Raw code: 244800 ECU: Engine control unit Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear ============2============== CD9401 Raw code: CD9401 ECU: Engine control unit Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear ============3============== 244800 Raw code: 244800 ECU: Engine control unit Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear ============4============== CD9401 Raw code: CD9401 ECU: Engine control unit Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear ============5============== D35448 Raw code: D35448 ECU: DSC/Traction control Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear ============6============== 801C20 Raw code: 801C20 ECU: CAN gateway Status: Test failed, Test failed (current drive cycle), Pending, Confirmed ============7============== 480143 Raw code: 480143 ECU: Suspension/Dynamic management Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear ============8============== D01734 Raw code: D01734 ECU: Suspension/Dynamic management Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear ============9============== D01736 Raw code: D01736 ECU: Suspension/Dynamic management Status: Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear ============10============== D35448 Raw code: D35448 ECU: ABS/DSC Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear ============11============== 030350 Raw code: 030350 ECU: Car access system Status: Test failed, Test failed (current drive cycle), Pending, Confirmed ============12============== 030352 Raw code: 030352 ECU: Car access system Status: Test failed, Test failed (current drive cycle), Pending, Confirmed ============13============== 030410 Raw code: 030410 ECU: Car access system Status: Test failed, Test failed (current drive cycle), Pending, Confirmed ============14============== 80408C Raw code: 80408C ECU: Car access system Status: Test failed, Test failed (current drive cycle), Pending, Confirmed ============15============== 8041B6 Raw code: 8041B6 ECU: Car access system Status: Test failed, Test failed (current drive cycle), Pending, Confirmed ============16============== D90C07 Raw code: D90C07 ECU: Car access system Status: Test failed, Test failed (current drive cycle), Pending, Confirmed ============17============== D90C0A Raw code: D90C0A ECU: Car access system Status: Test failed, Test failed (current drive cycle), Pending, Confirmed ============18============== D90C0D Raw code: D90C0D ECU: Car access system Status: Test failed, Test failed (current drive cycle), Pending, Confirmed ============19============== D90D17 Raw code: D90D17 ECU: Car access system Status: Test failed, Test failed (current drive cycle), Pending, Confirmed ============20============== D91E42 Raw code: D91E42 ECU: Car access system Status: Test failed, Test failed (current drive cycle), Pending, Confirmed ============21============== D91E46 Raw code: D91E46 ECU: Car access system Status: Test failed, Test failed (current drive cycle), Pending, Confirmed ============22============== D91EBF Raw code: D91EBF ECU: Car access system Status: Test failed, Test failed (current drive cycle), Pending, Confirmed ============23============== D91EF0 Raw code: D91EF0 ECU: Car access system Status: Test failed, Test failed (current drive cycle), Pending, Confirmed ============24============== E12C35 Raw code: E12C35 ECU: Dashboard/Instruments cluster Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear ============25============== 804875 Raw code: 804875 ECU: Central module (in driver's footwell) (FRM) Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear ============26============== E59441 Raw code: E59441 ECU: Central module (in driver's footwell) (FRM) Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear |
03-12-2023, 05:49 PM | #11 |
Rep 1,607
When you tried to re-code with the factory FA your IHKA ECU, did the ECU coding option show? If yes, then your IHKA ECU is visible to the car.
Not sure what the generic "test failed" means. Can the car see that ECU? ISTA error codes would be more specific and helpful...now that there may be numerous unrelated or secondary domino-effect errors listed. Until you get ISTA, could try to clear the errors with ESys using the "external transmitter", and run the the very bottom command (of the available commands).
03-13-2023, 02:33 AM | #12 |
Rep 17
I cleared the codes, but they keep coming back.
The errors list i get from regular obd scanner, so not sure what they mean by „test failed“ IHKA is not visible at all now I’m working on getting ISTA but no luck yet, still trying to get a working link. I suspect IHKA was blown because of the cables order, do you think disconnecting it will help with the FEM controlled modules? |
03-13-2023, 04:09 AM | #19 |
Rep 537
ahmad327 Try to VO code FEM module. Just right click on FEM and hit button CODE. But like you see IHKA is not responding not coming up maybe die
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
ahmad3273.00 |
03-13-2023, 04:53 AM | #20 |
Rep 1,607
[QUOTE=ahmad327;29929936]
I’m working on getting ISTA but no luck yet, still trying to get a working link. Go to the DIY coding forums and look for PSzData etc thread and ask Shawn there for ISTA.
ahmad3273.00 |
03-13-2023, 05:15 AM | #22 |
Rep 1,607
Try this thread for ISTA . Some threads are not active
https://f30.bimmerpost.com/forums/sh...16911&page=105
