BMW E90 base audio upgrades
04-22-2023, 10:58 AM | #1 |
9
Rep 88
Does anybody know of any budget friendly mods to improve the base audio system in a E90?
I would love to go Bavsound or Bimmertech but those upgrades are pricey $$$ Anybody just replace the OEM 4" speakers with something quality? |
04-23-2023, 11:00 AM | #4 | |
Rep 3,676
I didn't click on each of ctuna's threads but there really are a ton of audio threads on here. If you want decent sound, you NEED to recode to hifi and start from scratch with a good amp and decent speakers. FWIW, I have the Bimmertech amp and I'm not impressed at all with it. Something like a JL XD600/6 and some MBQuart or used EPS or L7 speakers would be a good budget upgrade. Anything cheaper than that will probably not get you where you want to be. |
Ali-E90383.00 |
04-24-2023, 01:37 PM | #6 |
Rep 13,133
If you are a master at digging things up you could piece something together if you
know what your doing. Technic was good at that but the best he could do was around 750 and that was 10 years ago. |
04-24-2023, 11:28 PM | #7 | |
9
Rep 88
Any benefits going with a aftermarket head unit? |
04-25-2023, 02:00 AM | #8 |
Rep 3,676
Nope, aside from added features like nav and stuff. I would keep the factory HU. Use a remote coder like Alpinemss.com. They can do coding sessions for about $50 and then you'll have a better platform to start with.
04-25-2023, 11:07 AM | #9 |
Rep 13,133
The thing you have to be aware of with the base system is the Front door and Under
floor speakers are wired in parallel . To make a decent system you have to split this connection and use a multi channel amp such that one channel powers each major physical location. And all the stock speakers have to go. Do not make the change to Hi Fi until the rest of your system is totally planned and you have the parts , because it will drop the voltage out of the Head Unit to pre out levels. The instruction's are old but the concept is the same . Either recode to Hi Fi or use a DSP or DSP/amp to flatten the eq curve. Split the under seats out to there own channel . Use good speakers Buy the BMW tweeter pods for the front tweeters Use a good amp or amp DSP. Don't buy super cheap amp's that advertise ridiculous wattage and no distortion specs. Shoot for between 50 watts to 100 watts per channel with low distortion specs and match to decent to good speakers. Aftermarket Head units = Modern functions but increased integration problem's If you have Idrive it will be a can of worms to put one in or even worse. Last edited by ctuna; 04-25-2023 at 02:44 PM.. |
