Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > CIC map update issue
      05-31-2023, 05:44 PM   #1
P4w3l
Drives: 2010 E92 330d
Hi,
I have 2010 E92 330d with pro sat-nav. I just purchased map update through BMW UK, downloaded the newest 2024-1 Premium Europe West map and put the USB in the car (it is about 24GB in size, so seems right). I entered the activation code from BMW and the update started (it was saying USB 1/4 during update). After about 50 minutes it asked me to connect USB device 2. The whole map fits on a single USB flash drive, so what is it expecting me to connect? Do you have any ideas how to progress with the update?
I emailed BMW but I don't expect they will be particularly hasty coming back to me.
      06-04-2023, 04:29 AM   #2
BIOHazard87
Drives: 2012 535i F10 / 2008 550i E60
Did you use the USB port inside the glove box?
      06-05-2023, 08:51 PM   #3
lnxguy
Drives: 2009 335D
What's the folder structure look like on the USB stick?
'09 335D
      06-06-2023, 11:03 AM   #4
P4w3l
Yes, I used the glovebox USB. The structure look pretty standard, there is config.nfm file in the root folder and a single folder pkgdb, its contents in the screenshot attached. I think there is an issue with this verion of the map as 2023-2 installed without any problems.
      07-27-2023, 01:00 PM   #5
ile__
Drives: BMW 328i
Has this issue been solved? I'm having the same exact problem with the system instructing me to switch USB 2 even though all the files are in a single pkgdb folder.
EDIT: Did some googling. On mhhauto someone posted
" It's BETA version, we must to wait for USB version. "
Can anyone confirm?
Guess I will just get 2023-2 instead. Big upgrade to 2012 maps though...
      02-28-2024, 03:01 PM   #6
CawKuH
Drives: BMW e34 M50B25TU, F25 N57D30N2
I think you can not update directly from 2012 to 2024. You need to update to 2017 or something and only then to latest map.
