06-22-2023, 07:24 PM | #1 |
Rep 16
Intelligent battery sensor
Hey everyone,
i scanned my DME with my scanner and it threw a Cd8f01 code LIN IBS sensor missing. i check my battery terminal and it looks like the IBS is connected properly to the negative terminal along with the cable that runs to the rear wiring harness. i ordered a oem replacement off of ebay and just installed it, cleared the code but it still shows IBS LIN SENSOR MISSING. What should I try now? |
06-23-2023, 03:26 PM | #2 | |
Rep 1,595
Did you check all the wiring going to the IBS for continuity? Ohm the wires out.
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
03-26-2024, 02:23 PM | #3 |
Rep 16
*********SOLVED*******
there is a small red cable that runs off of the red terminal. it fits onto a pronge. ensure that it is attached to your + terminal on your battery. if the IBS on the negative terminal is still functioning properly this should fix it and remove the code. |
fe7565556.50 |
