325i e90 n52 coolant flange and oil filter housing leak
07-23-2023, 02:05 PM | #1 |
Rep 4,139
I’ve been putting off the oil filter housing too long and found a nice bit of coolant under the car. It’s low on coolant and dripping from circled picture. Can I top off and make it to the mechanic slowly who is about a 20 minute drive?
07-23-2023, 03:18 PM | #2 |
Parts Pro
65
Rep 135
Drives: 2007 BMW 328xi 6MT
Part number for metal flange upgrade (CRP Rein) CHC0609.
Part number for gasket is (OEM BMW) 11427537293-PRM part number for bolts are (OEM BMW) 11427540759KT1. You can top up and should be fine if not too bad. Bring coolant in case of low coolant warning. The DIY for both of these are easy and can be found on YouTube.
E90 328xi 6MT | Intake Scoops | K&N + Charcoal Filter Delete | DIY Dinan 3in | 3.25in + 3.5in piping | N54 Manifold | Ceramic Coated Headers | Secondary Cat Delete | Xdelete | 3.91 Diffs | 22RPD Tune
G35POPPEDMYCHERRY4998.50 |
07-23-2023, 10:33 PM | #3 |
Rep 4,139
thanks, I checked and still have AAA plus so will tow over.
Idk if I should do the belts and pulley. the oil filter housing has been leaking for a few months and the coolant soaked the belt up pretty good this morning |
07-26-2023, 12:48 PM | #4 |
Parts Pro
65
Rep 135
I would at least recommend the serpentine belt because if it slips, your engine could go
