N52 metal shavings in oil filter housing
08-01-2023, 04:57 PM | #1 |
Rep 13
Irregular shaped hole located at right of photo is crumbling around the edges and there are metal shards sitting in the oil filter housing. The oil cap has been leaking recently so I purchased a new cap to change it out and change the oil when I noticed the deteriorated edges of the hole along with metal shards sitting there. I think it’s called the oil-in hole. Any ideas?
08-02-2023, 09:24 AM | #4 |
Rep 50
That sucks. I DIY everything but this calls for a professional mechanic. Hopefully it's easy to fix with a new oil filter housing and a flush with cheap oil.
08-02-2023, 10:46 AM | #5 |
Rep 3,201
Drives: E92 325i MSport Coupe
+1 There's no way that alloy casting would 'crumble'. The only thing it does is act as an oil passageway.
08-02-2023, 11:10 AM | #6 |
175
Rep 189
Mmmh that's not too good, if you still have the old filter cut it and check inside the grooves
Any noises on cold start/codes? A long shot before rod bearings, that are not too common on N52s, could be stuck check valves letting pressure drop in the head on deceleration, wearing the aluminum chain tensioner and/or bearing ledges.. how is the intake cam looking through the oil cap, badly scratched? Last, are those particles magnetic? As the boys said, no way it's from that hole "crumbling" Try draining the oil and check for "forbidden glitter", if there's not it could be salvageable Last edited by PhaceN52; 08-02-2023 at 11:16 AM.. |
