Yellow transmission light
02-15-2024, 08:15 AM | #1 |
Rep 47
Hey guys i’m hoping for some help i get the yellow transmission light only when the car is off and in park, never has popped up when the car is driving. No slipping or shifting issues whatsoever. i have gotten an over torque code before after flashing an mhd tune. But otherwise it drives fine
02-15-2024, 09:29 AM | #2 | |
Rep 3,732
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
02-15-2024, 12:01 PM | #4 |
Rep 3,732
If you are getting the yellow gear symbol on the dash, it means transmission issue. What are you scanning it with? Most scanners won't show TCM codes, that's why you need the XHP app....to read the TCM codes.
02-15-2024, 12:03 PM | #5 |
Rep 47
iqraceworks
Scanning with Bimmerlink. I have the thor adapter. Doesn’t show anything stored. i’ll get xhp when i’m home but i doubt it’ll show any difference. Bimmerlink is pretty good |
02-15-2024, 12:06 PM | #6 |
Rep 47
iqraceworks
There’s an aftermarket gear selector installed as you can see, which by the way i hate. I have the oem one. when i pull the cover off to swap them out i’m going to check for loose wires / unplugged cables |
02-15-2024, 12:22 PM | #8 |
Rep 3,732
Aftermarket gear selector?
02-15-2024, 12:24 PM | #9 |
Rep 47
iqraceworks
yeah it’s like an amazon shifter. my bet is there js a loose wire in there and the car doesn’t know if it’s in park or not. Keep in mind it only does this when the car is completely off |
02-15-2024, 12:27 PM | #10 | |
Rep 3,732
If so....I'd say you know what the problem is. Also...it's an Auto, why did you replace the shifter? Got of pic of it?
02-15-2024, 01:20 PM | #14 |
Rep 6,319
I have something similar when my shifter is disconnected and car turned off or I open door. But mine will show an actual shifter icon in the dash and mine is a DCT. But it doesn't throw a code so maybe it's related to that Amazon shifter thing.
Jonnyweninger6.00 |
02-15-2024, 01:45 PM | #15 | |
Rep 47
Yes, it’s only when i open the door it pops up. no codes are stored so i’m not worried but it’s just annoying and i want to solve it |
02-15-2024, 02:12 PM | #16 |
Rep 3,732
Can you jump fine a nice used OEM shifter for cheap and put that in? What does the Amazon shifter gain you?
02-15-2024, 02:14 PM | #17 |
Rep 47
