02-21-2024, 05:11 PM | #1 |
Rep 1,387
LCA recommendations that aren't poor
Apart from Lemforder, which other brands can be trusted on control alarms? Lemforder is proving difficult to track down.
I run Millway monoball bushings and almost came to selling them after 5k miles, felt the noise was getting too much on 20" wheels and KW V3's.. however when I had my car up on a ramp today I spotted the front left ball joint has failed, it's moving quite a lot creating the audible clunk I have been experiencing. TRW were recently outed for moving their production to Asia which has seen poor quality ball joints, IIRC they were failing only a few thousand miles in. Meyle, Febi and Napa are some of the other brands I'm seeing in UK stores but I don't hear many people in our cars running them, I don't need to be paying over on HD bushed arms like Meyle offer though, the stock bushing will be binned and my Millway's pressed in.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
02-26-2024, 12:06 PM | #2 |
Rep 499
TRW is the OE for BMW. Not sure about this production being moved to Asia but why not just buy from FCP or Turner and get lifetime warranty and stop worrying about it?
alohasurftoad3139.50 |
02-27-2024, 12:03 PM | #3 | |
Rep 1,387
Unfortunately we don't have FCP in the UK, it's either usually 1 year limited warranty on aftermarket OE parts or 2 years through dealers. Would love for an FCP equivalent to pop up here though, sounds like you guys get a quality deal through them. In the end I pulled the trigger on MEYLE-HD arms, the quality is super nice and they come with a limited mileage 4 year warranty with supposed claims of being superior to OE; which based on TRW right now is true I guess
2015 435i - 401whp
02-27-2024, 01:35 PM | #5 |
Rep 1,844
if you're able to return arms, just buy TRW and look at country of origin on the box, you may still get Germany made stock. If its Malasian made, then return them. As far as companies like VAC using lemforder arms, the biggest failure point for Malasian made parts is the bushing, not the metal arm... so I doubt VAC wouldn't use TRW or other OE manufacturer made arms if they're replacing the bushing either way.
I priced out OEM arms, and they're expensive, but I'd be willing to spend that if all the OE options were worse in quality. Incase you're getting the TRW/Lemforder/ZF Malasian dilemma from M539 Restorations' E92 control arm video, even he went OEM since the OE options didnt fit the bill.
02-27-2024, 03:15 PM | #7 |
Rep 499
How long did your TRW last and how did you determine they were failing?
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo |
02-28-2024, 04:18 AM | #8 | ||
Rep 1,387
Unfortunately the packaging is long gone but I do remember a bit of a man hunt in 2022/23 for the remaining German made TRW arms, I believe pretty much all are now gone though. From what I recall it's the ball joint that prematurely goes bad on their new arms, the main bushing is what gets replaced with a monoball usually. If it was the main bushing then I wouldn't be too fussed as it would be getting thrown away. Just a little over 13 months (unlucky 13 ironic) - I had a wooden clunking sound which I had previously related to failing ball joints on the arms, my oem ones lasted to around 80k which may seem a little lower than average but they were ran on coilovers, so about right in my opinion.
2015 435i - 401whp
danb19792016.50 |
02-28-2024, 08:31 AM | #9 | |
Rep 1,844
ah didn't realize the ball joint was the failure point. well, I don't know if it's worth anything, but if I was in your place I'd buy OEM. I just find having to go back and change control arms often due to failure not worth the headache/labor costs that you would otherwise pay by going OEM instead of OE.
fortythirtyfive649.00 |
02-29-2024, 08:48 AM | #10 | |
2017
Rep 2,195
I've used Moog for years now (as well as Meyle / Meyle HD) and never had any issues; had more issues with OEM BMW and Lemforder unfortunately (albeit that was on previous E39s and an E65) You'll get Moog via your local motorfactors and Autodoc; TRW on Autodoc too... Meyle HD is good as said above; but I know Sreten of M539 Restorations fame doesn't like Meyle at all... He's obviously fallen foul of bad parts... Lemforder are going this way too and he's not impressed! If you can get them, go Moog IMO - good warranty on their parts too
03-05-2024, 05:34 PM | #11 |
Rep 1,387
Had the Meyle HD's installed yesterday with my Millway monoballs swapped into them.
God knows why I didn't blame the old arms for the looseness and knocking long before, esp as my original set of OEM arms went at around 80k with similar symptoms. Anyway time will tell as to how they hold up but the build quality is fantastic and the garage seemed happy enough with them. Everything is dead silent now, super tight and drives like a dream.. to think I was about to bin the monoballs off for being too noisy Hopefully this answers another issue I had which was the left front wheel often rubbed on fast speed turns, I can only presume the arm wasn't that "stable" letting it move a bit too much (it was this side that had failed).
2015 435i - 401whp
danb19792016.50 |
03-06-2024, 03:31 AM | #12 | |
2017
Rep 2,195
My F31s superb now with all new suspension; even though there was no play, original 2015 rubber parts were starting to show their age!
03-06-2024, 06:04 AM | #13 |
Rep 1,387
It's amazing what a slight refresh can do, it reignites that spark when driving it again!
2015 435i - 401whp
danb19792016.50 |
03-06-2024, 07:11 AM | #14 | |
2017
Rep 2,195
The F31 didn't drive or handle badly at all; far from it. The 18" forged 405Ms and Goodyear tyres made a huge difference when I fitted them in terms of turn in feel and all round driving But you could just feel that there was something amiss when it came to the all out handling, more so on rough B roads/country lanes and the ones I know very well local to me Driving them now really highlights the new suspension; looking forward to sticking the summer 405Ms back on in the very near future as I think they'll be the icing on the cake
