Studio RSR
BMW 3-Series (E90 E92) Forum > E90/E92/E93 Marketplace (For Sale / Trade / Wanted) > Private Owners For Sale / Trade / Wanted > Cars for Sale > 2007 E90 335i M-sport 6 MT RWD
      04-13-2024, 03:57 PM   #1
Gadgetsystem
Drives: Bmw 335i
BIMMERPOST / Classifieds
Asking Price:
USD 7,500.00
Item Interest
2007 bmw 335i 6 speed rear wheel drive with 108,xxx mileage will go up since its my daily
Ive done a lot of maintenance since buying it and installed upgraded parts. Currently it is fbo with mhd stage 2 plus.
Bosch Spark plugs & precisionraceworks coil packs
Burger motor sport cold air intakes
Replaced oil pan gasket since it was leaking
Replaced Oil cooler/oil filter housing gasket
Replaced radiator and coolant hoses
Arm motorsport catless downpipes
Arm motorsport 5 inch front mount intercooler
Vrsf charge pipe with hks blow off valve
Secondary cat delete
Brand new bmw dme since it failed and cylinders 1-3 were misfiring fixed the issue
Mhd tune stage 2+
Vargas turbos and clutch single flywheel paired with unsprung 335is
Replaced drivers side front and rear wheel bearings
Ecs tuning adjustable coilovers
Currently has forgestar f14 super deep concave fronts are 245/35/19 and rears are 265/35/19 little bit of rubber at full lock and I would recommend changing the tires since they were rubbing pretty bad with the previous owner of the wheels (no tire pressure monitors)
transmission fluid changed out for redline and so was the differential
I have a original bmw lsd differential with a rebuild kit and fluid that I never installed.
Still has original water pump,valve cover gasket and injectors are older index cylinder 6 is the only one with index 12
      04-23-2024, 10:47 AM   #2
Gadgetsystem
Drives: Bmw 335i
Bump
      05-07-2024, 07:49 PM   #3
Gadgetsystem
Drives: Bmw 335i
Bump
