Can only see half my contacts after combox retrofit?
04-25-2024, 01:24 PM | #1 |
Rep 1,022
Hi all.
2010 e91 lci, factory CIC, idrive. So I finally fitted a combox after years of putting it off. I have an older c10 cic firmware if it makes a difference, I coded the cic, media and kombi as per guide with change if date to 03/11 and added codes Bluetooth music works. But before I could see all my phone contacts, now I can only see about half with the second half all being “…”s Anyone had this? Wondering if it’s due to the combox or? Cheers Andy |
04-29-2024, 11:59 AM | #2 |
315
Rep 279
Drives: Green '07 & Arctic '08 335i's
COMBOX Firmware?
Hi Andy,
You could try updating the COMBOX firmware. My Android phone started behaving much more consistently after I did this. Here is a thread that has the newest version, however I could not get the new one to update, had to use one version older. You just put in on a USB in the armrest and select update from the car settings menu. |
04-30-2024, 12:07 AM | #3 |
Rep 1,022
I’ve seen that setting, I’ll confirm my software level but it’s probably old.
I need to add in the wiring for the USB (mine didn’t come with that stock so part way through that retro fit) Then I’ll give that a go |
04-30-2024, 11:01 AM | #4 |
315
Rep 279
Mine was also not 6FL from the factory. I found the OEM wire in a junkyard car and just plugged it into the COMBOX in the trunk for the update. I ran it later when I had time to remove the back seat and fish it through correctly.
05-03-2024, 12:49 PM | #5 | |
Rep 1,022
What route did the cable take? Cheers |
BRG_N54314.50 |
05-03-2024, 04:44 PM | #6 | |
315
Rep 279
I would second the OEM USB port, the one I pulled had actual metal in it! Last edited by BRG_N54; 05-03-2024 at 04:45 PM.. Reason: clarity |
05-05-2024, 07:11 AM | #7 | |
Rep 1,022
I’ve seen a lot that are 1.5m and I read those are too short for the proper routing |
