Cylinder head cover gasket brand recommendation?
04-28-2024, 02:59 PM | #1 |
Rep 22
Hi guys,
I'm planning on replacing the head cover gasket on my 2010 330i while doing injectors + oil catch can. The part number is 11127544368 - there are quite a few brands that I've seen make this gasket. Given that this part is not the easiest to replace, I'd rather get one that lasts the longest. What is your recommendation for a particular brand? Is Febi Bilstein any good - they seem to make lots of parts and I got the impression that they are good quality. At the same time they are often the cheapest of any brand - which is a bonus if the quality is there! The brands I can see for this part are: Febi Bilstein topran DrMotor Ajusa elring victor reinz elwis glaser Appears from reading the Internetz that elring, Victor Reinz and febi are top choices with elring likely being OEM. Last edited by s5s; 04-28-2024 at 03:17 PM.. |
04-29-2024, 05:10 AM | #2 |
Rep 3,201
Drives: E92 325i MSport Coupe
I would recommend replacing the whole valve cover, not just the gasket. Often there are hairline cracks in the plastic and/or the PCV system is clogged/shot. My indy tells me he always does cover with gasket as he's replaced too many gaskets only to find the cover needs replacing shortly afterwards. Just a thought...
04-29-2024, 02:44 PM | #3 | |
Rep 22
04-30-2024, 02:33 AM | #4 |
Rep 3,201
What do you know of your car's service history? If it's been BMW serviced with long oil change intervals, there's a good chance the PCV system will be clogged. If you can afford it, I'd still say change the cover as well as the gasket...
04-30-2024, 07:20 AM | #5 | |
224
Rep 365
Drives: 2007 BMW 328xi E92 6mt swap
Today, 12:43 AM | #7 | |
20
Rep 38
I'm having some work done at a shop that includes pulling the cover and I asked about replacing it. Technician looked it over and said it'd be a waste -- mine's in perfect shape. I've got 140k miles, about 100k of that with the previous owners who followed the long oil change interval fwiw. I'd probably just replace it if I was doing the work myself, like I did on my old e46 cover. Sometimes paying a pro can actually save money.
'07 E90 328i 6MT Sport Pkg --- Sparkling Graphite Metallic --- Stock/Current Dynojet: 202whp/225whp
Full Suspension Refresh ● M3 & Manzo Arms, AKG Sub Bushings, Eibach F&R Swaybars, ProKit & Koni Yellows ● 17x8.5 245/40R17 ● 3.73 Diff ● 3SIM ● Kassel Tune ● Custom header-back exhaust ● MILVs incoming |
