BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Vland GTS light behaviour
GetBMWParts
      05-03-2024, 11:28 AM   #1
doc.manhattan
Drives: '08 E93 335i
I just installed the set on my car and while everything works I'm a bit puzzled about their behaviour. If I have my lights set on Auto then they are completely dark, the dragonscales don't light even though the angel eyes on the front do. Is that normal?
      05-03-2024, 12:39 PM   #2
mobbinthesteez
23
Drives: 2020 BMW 440i Xdrive 6 speed
You might need to code in the rear lights to be daytime running lights, thats what I have done and they work when set to auto.
      05-03-2024, 06:31 PM   #3
ooshnoo
ooshnoo's Avatar
Drives: 2014 428i and 2018 X5
2018 BMW X5  [0.00]
2014 BMW 428i  [10.00]
Yes, that’s normal… DRL’s by default are only for the front of the car.
___________________
2014 F32 428i M-Sport
2018 F15 M-Sport
      05-03-2024, 06:35 PM   #4
andyb313
13
Drives: F32 440i RWD
You need to code rear DRL with something like bimmercode
And if you want the startup animation you need to make sure the light switch is on auto , and welcome light is enabled in the I drive
      05-10-2024, 07:50 AM   #5
doc.manhattan
The thing is that I have a EU-spec F33 LCI and I'm 99% sure that the DRL for the OEM taillights did light up during driving with the Auto light mode.
Which option in Bimmercode are we talking about exactly?
      05-11-2024, 02:26 AM   #6
mrpingu
Norway
194
Drives: 2018 F48 X1 xDrive 18D
If the car has 8TL option code it does that.
You are looking at the REM module in BimmerCode where you can change it.
      05-11-2024, 07:42 PM   #7
eff32fl
eff32fl's Avatar
1086
Drives: 2019 440i M Sport THP MPPSK
I found a thread that tells you what needs changed to enable rear DRL if you don't have the VO code 8TL enabled.
https://f30.bimmerpost.com/forums/sh....php?t=1302702
      05-12-2024, 04:25 AM   #8
mrpingu
Norway
194
Yes that solution is what I am refering to. It’s also available in BimmerCode easy mode.
VO-code is basically a template of several FDL-code settings. Also know as cheatsheets in the BMW-coding world. Bimmercode easy mode does the same, 1 setting might change several FDL-parameters. You can verify that by flip a switch in bimmercode easy mode and then go to the FDL-parameters in expert mode (if you happen to know them) and you’ll see the FDL has changed
      05-14-2024, 02:55 PM   #9
doc.manhattan
Thanks everybody for chiming in, got it working. Enabled the DRL option in Bimmercode and the tails light up properly now.
