05-06-2024, 01:41 PM | #1 |
Rep 54
Hey guys, a redbull I had rolled under the seat and I guess from overnight pressure/climate changes exploded and leaked into the subwoofer under the passenger side. All speakers in the car sound fine besides that sub obviously, sounds very broken… is it as easy as swapping it out or taking it out and cleaning it? Or is there a different component under there that I could have damaged? Any advice is appreciated, I should be able to just do the work myself, trying to avoid the dealer pricing…
05-06-2024, 02:34 PM | #2 |
103
Rep 284
I guess your sub got some wings now that are flappin' around!! Sorry, couldn't resist!!
What kind of audio system do you have? Base? Hifi? HK? Based on that, replacement of the floor sub is easy, just a few screws to remove the cover, and a few more to remove the driver, and maybe a pry tool since it's usually sealed into the back box with some adhesive. You can find replacement drivers here in the classifieds, or facebook marketplace for cheap. Or maybe this might be the ideal opportunity to put some Earthquake underseat subs that you can easily buy from Amazon: https://f30.bimmerpost.com/forums/sh...ght=earthquake
2017 430ix Gran Coupe
NealfromNZ554.00 sodixm8.00 |
05-06-2024, 02:40 PM | #3 |
Rep 536
If it’s Harman Kardon it has its voice coil vents at the top of the speaker which is partly covered by the speaker grill.
If no liquid is gone in you’ll be ok. But you may need to clean the speaker wire connector as it might be submerged in redbull. Otherwise replacement time. You’ll need to unbolt the seat torx screws and move seat back out of the way. ( carefully not to over stretch or damage seat harness ). Also don’t unplug seat otherwise you could end up with airbag errors. Grill needs Torx t20 driver , two 10mm bolts to undo. Unclip the speaker harness and wire clips for front loom. Take out enclosure and keep as leave as possible to stop liquid going into side sill vent. The speaker enclosure is designed to vent liquid through a hole in the floor. No doubt you’ll need to wipe out that area under the speaker |
Arthurrs102.50 |
05-06-2024, 02:57 PM | #4 | |
Rep 54
05-06-2024, 02:58 PM | #5 | |
Rep 54
05-06-2024, 03:01 PM | #6 | |
Rep 54
05-06-2024, 04:31 PM | #7 |
Rep 536
Enclosure and speaker can come out together. But I’d take of the grill, sponge up any red bull sitting on the cone. And then take speaker out of enclosure. Use a pri tool for the first time as the woofers seal will need to be broken.
If you have base audio however just take the enclosure out as the smaller 6.5 woofer is glued in. |
sodixm8.00 |
05-06-2024, 07:20 PM | #8 | |
Rep 54
05-06-2024, 10:52 PM | #9 |
103
Rep 284
The purpose of the seal is to make the driver and enclosure an "airtight" enclosure. A very thin bead of silicone should be fine.
05-06-2024, 11:54 PM | #10 |
Rep 536
As above for base audio
For hifi or Harmon Kardon providing the seal around the woofer is intact it will seal again when torqued down. The top woofer is a Harman Kardon. You can see the seal ring around it which will continue to work. No need to seal the enclosure again. |
