FORUMS
- 5
| Please visit one of the specific Bimmerpost sites above |
| 07-21-2010, 03:26 PM | #1 |
Bmw needs to go back to
more simpler times. Key in the ignition, trans and oil dipsticks, and no other electronics, something like windows 7, which is an unbloated vista.
For most BMW problems start off by scanning your car with the BT Tool or Peake Research Tool. They contain the actual BMW codes as opposed to a generic OBII scanner. Pays for itself on the 1st scan. http://www.bavariantechnic.com/ OR
http://www.peakeresearch.com/ (less expensive, but does not reset battery info) |
| 07-21-2010, 03:35 PM | #2 |
Where'd my VTEC go?
Windows 7 is still Vista, just running more smoothly. If you want unbloated, you need to go back to WinXP
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: KW V2 | OEM Blacklines | M-tech rear | custom dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | BMW Performance rep spoiler Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
| 07-21-2010, 03:47 PM | #5 |
vrooommm
Drives: 2008 BMW E92 335i Join Date: Jan 2010
I say: let um put more stuff in... i like gizmos, gadgets and sh*t
BMW E92 - 335i - Spacegrau - Black Dakota - AT - BMW Performance style 313s (19) - BMW Performance suspension - M-aerodynamics - BMW Performance diffuser - considering: BMW Performance exhaust
| 07-21-2010, 03:53 PM | #6 |
I started this thread because so many people posts problems with their cars and alot of it has to do with the electronics. The e46 has 1,000 less things that can go wrong with it. I still love the car.
| 07-21-2010, 03:54 PM | #7 |
I'll take that too!
| 07-21-2010, 03:55 PM | #8 | |
General
![]() ![]() ![]() ![]() Drives: THE GUY YOU LOVE TO HATE Join Date: Mar 2009
trans dipstick is needed too since bmw has faulty auto transmission pan gaskets. |
| 07-21-2010, 04:51 PM | #9 |
^They have sensors for tire pressure which you can tell if they are low by looking at it, but then no sensor or dipstick for the transmission? Not only can the pan leak how about the hoses? It doesn't even have to leak a lot, just a little drip every other day.
| 07-21-2010, 05:06 PM | #10 | |
+1 You are not alone... i rather they invest the extra cost on the car on performance related items. sometimes i can't help but think they made all these "enhancements" just so that people will be required to take their cars to the dealership anytime something isn't working properly, and charging an arm and a leg while they are at it. |
| 07-21-2010, 05:18 PM | #11 |
![]() ![]() Drives: '08 335xi cpe - aero kit, 6MT Join Date: May 2010
I don't mind having an 'in car check' for the oil, actually like it...but give me a damn dip stick to check whenever it says my oil is low and I know it was fine the previous day.
- Joey | 2008 BMW 335xi | 2006 MINI Cooper S Vert | 2011 Ford Edge Limited | |
| 07-21-2010, 05:49 PM | #13 |
| 07-21-2010, 06:03 PM | #14 |
Philosopher-king
Drives: 2008 E91 Join Date: Apr 2005
Fabric sunroof, one door...
E91 6MT Alpine, Terra, Xenons, ZSP, ZCW, ZPP, PDC, CA, alarm, M shifter and M brake handle, Euro rear fog light switch, Euro aspheric mirrors, rear power outlets, Garmin nüvi custom cupholder mount, Lidatek, V-1 built-in remote display, tire pump, jack, floor mats.
| 07-21-2010, 06:22 PM | #15 |
Noob
Drives: 2006 MZ4C, 2013 Veloster Turbo Join Date: Oct 2007
BMW has two types of customers. Buyers who wants a sports car, and any luxury on top is just cherry. And buyers who wants a luxury car, and any sports on top is just cherry.
They are the two opposing forces at work here. On one hand, the Sporty buyers are the vocal buyers. The influencers. The elitist who all think what they want should be what everyone else gets. They're the type to write to BMW NA in a mass email campaign threatening to boycott BMW if they don't bring the E36 M3 over. They're the ones that tell all their friends and families that they must buy BMWs regardless of their situation and need. However they're the MINORITY. There's probably one sporty buyer for every 10 luxury buyers out there. And BMW knows it. So what do you do, when the VAST majority of your customer base probably don't know what an apex is from a hole in the ground? Simple. You build cars that are bigger, heavier, more luxurious, but with better engine and more technology crammed into the suspension and chassis than anyone has a right to shake a stick at. That way, the sporty buyers are happy that they get a car that handles like no other sedan does, while the luxury buyers get a car with dual comfort climate control that massages your back and shakes your d*ck when you pee. But that formula is not sustainable. With every feature added, and every inch increased and every pound heavier, it takes double the amount of horse power and suspension wizardry to keep the same "performance." So what do you do, again, if you're BMW? Well, formula is simple. You build bigger, faster, and more luxurious cars with more features, and come up with this "magical" entry level 1 series that weighs 200 lbs more than the last generation 3 series and call it the "sportier, lighter" alternative. Unfortunately that hasn't worked as well to BMW's advantage. And the last lightweight, sporty BMW built, BMW sold all but 1,700 units in 3 years, with a $10,000 incentive on top. They just couldn't give it away. So what does that say about BMW's customers again? So for those of you who wish BMW would go back to the "golden" age of building what made BMWs BMWs, those days are long gone. You're better off buying a Porsche. Or a Subaru if you need more practicality. Because BMW stopped building BMWs long time ago. They're now intent on building Lexuses that sort of drive like BMWs. |
| 07-21-2010, 08:52 PM | #17 | ||||
Yeah, eliminate a spare tire...great move.....i feel safe taking long trips. Quote:
If it was a bmw I would buy it! ![]() Quote:
Believe me, you won't even miss them.
| 07-21-2010, 10:34 PM | #18 |
Retired
Drives: Z4 s30i Join Date: Mar 2007
I had opne of those ! Isetta 300 - door in front... could barely make it up a hill !!! What fun we had. And, oh yes, it was made by BMW !!!
![]() M3 GTR - 1/5 scale - 4.2 HP w/ Collari hydraulic brakes - would you believe ~80 MPH on straightaway !! |
| 07-21-2010, 10:44 PM | #19 |
Philosopher-king
Yup -- the Isetta IS a BMW! First BMW I ever sat in.
I think I was 5 or 6 at the time. ![]()
| 07-21-2010, 11:15 PM | #20 | ||
Originally Posted by corneredbeast
An engine from a Z06 Corvette. A differential from a Vespa. Damn Quote:
| 07-21-2010, 11:17 PM | #21 |
Nice!!!
| 07-22-2010, 02:17 AM | #22 |
I don't trust the sensor either... I had a MINI Cooper before and the oil light never came on even the oil level was down to less than half... The MINI had a dipstick... I know I was lazy and I never checked because I never had a car which burnt oil before... There was one time I heard some funny noise from the engine and took it to dealer and they topped up 2.5L of oil... The guy asked me how long did I wait after the light was on and I told him the light never came on... from that time on, I checked the dipstick every once in awhile...
2011 1M VO stripper
| Bookmarks |
| Thread Tools | Search this Thread |
