09-29-2010, 07:45 PM | #1 |
1770
Rep 7,652
✚WHEELSTO | Alufelgen SF-71 - In STOCK Special!
Alufelgen SF-71 wheels The SF-71 carries an aggressive concave face, sharp edges and an unique spoke profile. The face of the wheels was designed with the maximum possible spoke concavity while still allowing clearance for BBK. Based on the wheel size (8.5F and 9.5R), back spacing, offset and brake clearance, this is the maximum concavity a certifiable cast wheel can have. The concavity is deep and clearly pronounced and requires an elevated center bore due to the deep profile. The spokes are extended to the edge of the wheel to provide a cleaner and distinguishable look and are accentuated with a small outer lip and an attractive machining between the spokes. Features: - Deep concavity to match the aggressiveness of the E9X - High quality low pressure casting for extra strength and peace of mind - Durable finish in multiple colors Sizes and Specifications: - 19 - 8.5 | et20 | bore: 72.6mm | weight: 26.4lbs - 19 - 9.5 | et20 | bore: 72.6mm | weight: 27.0lbs Color: Metallic Silver | Hyper Black | Titanium Gunmetal | Matte Black Retail Pricing: $1299/set SPECIAL: $899/set Most Colors are in STOCK! While Stocks last~! Some additional pictures: How to Order or Get More Information: Call: 312.880.7767 Email: info@wheelsto.com PM the WheelSTO Crew: Julius ● Julius@WSTO Dave ● Dave@WSTO Support ● WheelSTO WheelSTO Wheel & Tire Package Program WSTO also offers wheel and tire packages. Please Let us know what your favorite tire is, when asking for price quotes . If you are not sure, just let us know and we can make some suggestions for your intended use! WheelSTO uses a Hunter Road Force balancer to ensure your setup is perfectly balanced. Each order includes a printout showing the accuracy. Ask Your WheelSTO Rep about our FREE Mount and Balance Program Today!
alufelgen, sf71, wheelsto |
