Are you driving a 325i with 3 stage intake manifold?
01-03-2011, 08:00 PM | #1 |
44
Rep 210
I upgraded to the 330i 3 stage intake manifold on my 2006 325i and have the following issue.
1. The throttle surges on and off between 2,000 and 3,000 rpm under Wide Open Throttle... Simply put, at 2000 rpm, when I romp on the gas full throttle, and let it climb from 2000 rpm to redline the car fluctuates throttle drastically between 2000 and 3000 rpm, then at 3000 rpm, all systems go, and the car performs beautifully, Is something wrong with my car, or is this a tuning issue... My issue has been resolved! Using the Bavarian Technic tool, I was able to reset all the adaptations on my car, specifically the intake manifold adaptation. Once this was reset, the surges are GONE! I have tried OE Tuning and Active Autowerks. Both tunes do this at 2000 RPM WOT. The issues are similiar with both tunes, although the characteristics of each tune are different. Does yours do this too? P.S. the car is screaming fast, but I like to shift early and don't like how I don't get real consistant power until 3000 RPM...
M Performance Suspension
01-03-2011, 11:41 PM | #2 |
making his own parts.
41
Rep 142
Nope... and the issues your experiencing are due to the butterfly valves opening and closing when your DME is not expecting it to.
IMHO... 3 stage manifold is a waste. It would probably work better if you got a 330i DME or a tune with a 330i program... or... put back your wide-open 325i manifold, because i don't know about everyone else but I only race in the higher rpms with a wide-open throttle.
For Sale: Jet Black pre-LCI front bumper/hood/trunk lid, oe tail lights, 2 oe 16 inch rims w/ good tires. PM w/ offers. |
01-04-2011, 02:34 AM | #4 |
Old Geezer
366
Rep 1,193
Drives: 08 E92 N53B30
My experience with the manifold swap may not be relevant since I have N53B30 but the tuner where I had my car done is also tuning N52s ( the guy is in tuning business 20 years and does only BMW). The only problem I had with the swap was when I had 330i (N53B30O0) software installed. The engine completely lost power and I had to reinstall the original software. I took my car to DS Motorsport in Germany and now I have completely different car. It was expensive but worth every penny. I have more power than 330i and the car is very smooth. I posted the dyno charts in another threads.
01-04-2011, 08:59 AM | #5 |
Choppin' Broccoli
Rep 49
Why aren't the tuners using the 330 software as a baseline? or are they? You would think this would be fairly straightforward tune.
BudVlad, any details about why your tune was so successful? |
01-04-2011, 09:35 AM | #6 |
44
Rep 210
Sickly Fast...
The car is sickly fast with the three stage intake manifold. And because under normal circumstances one would not be Wide open throttle under 3000 RPM anyway, I think I will live with the issues. The car is WAY TO FAST to go back to a single stage intake manifold... no thanks!
01-04-2011, 10:15 AM | #7 |
Rep 1,192
Drives: 2009 BMW 328i Wagon
I'm not sure what is wrong with your car, but I definitly would stay on the tuner to get it right.
01-04-2011, 10:28 AM | #8 |
Old Geezer
366
Rep 1,193
The tuner has 20 years of experience with BMW tuning (he doesn’t do any other makes). The tune wasn’t just a re-flash it was done on dyno.
01-04-2011, 01:27 PM | #9 | |
just another bmw douche bag
195
Rep 3,640
I think this mod may need some careful dyno tuning to work right. While the 330 software should work just fine, I have a feeling that the tuners flashing 325's to 330's aren't copying everything over from the 330 software - they are probably only using timing and fuel maps from the 330, and not the valvetronic/vanos settings which are a huge part of where the 330 gets it's power. |
01-04-2011, 01:34 PM | #10 | ||
Rep 2,740
Wrong. the 330i DME tune requires a 3-stage manifold. Which is why you have such a huge difference in power from 325i (3.0L) to 330i (3.0L). Quote:
01-04-2011, 01:35 PM | #11 | |
Rep 3,879
01-04-2011, 03:01 PM | #12 | |
41
Rep 142
.. I'm still not sold on the manifold's "big power" difference/benefit other than creating more usable torque at the lower rpms. Really, a fully an optimized 3.0 liter N/A race motor should be making at least 100 hp per liter. It just needs a competent tuner to figure out how to make the engine breath (and should anyone reach that level, I'm sure its not going to include a manifold with valves taking up room in the manifold). Last edited by allmotorh22; 01-04-2011 at 03:20 PM.. |
01-04-2011, 03:24 PM | #13 |
Old Geezer
366
Rep 1,193
Unfortunately loading 330i software in the 325i ECU doesn’t work. I found out the hard way. Tuner convinced me that he can overcome the VIN coding. He managed to load the software but the car ran like on a limp mode.
01-04-2011, 03:34 PM | #14 | |
44
Rep 210
Your not sold because your not driving one
01-04-2011, 03:54 PM | #15 | |
41
Rep 142
no, I'm done with race motors. Its so nice to drive something with manners. But... I do want to see someone figure it out. It seems that budvlad is the closest with 248hp getting 10+ hp more than a stock 330i, that said I think it could be better. (@bud, do you have access to a dynojet? good for a dyno to dyno comparison). Anyway i'm sticking to bolt-ons till we can get our stuff straight. Check out skywagon's gains by just deleting the primary cats 15hp on a dynojet (185->200)! http://www.e90post.com/forums/showthread.php?t=272261 http://www.e90post.com/forums/showthread.php?t=273360 look familiar dimsum?
01-04-2011, 04:13 PM | #16 | |
Rep 3,879
01-04-2011, 04:26 PM | #17 |
195
Rep 3,640
Hopefully, we'll know more info this weekend, when I finish installing the 3-stage manifold on my car. I have the old manifold out, but broke one of the crankcase breather hoses (stoopid bmw makes them out of plastic instead of rubber), so a new one is on order.
So I've been driving around in this the last couple of days.. not so comfortable with 500 lb/in springs! |
01-05-2011, 08:41 AM | #18 | |
175
Rep 222
With what a 330i is making with the stock compression and cams, I don't believe there is too much left on the table in terms of improvement. |
01-05-2011, 12:05 PM | #19 | |
41
Rep 142
It doesn't... It doesn't add compression (like a turbo), nor does it add cam duration (the way the engine breathes) to achieve PEAK power... if it doesn't help with those aspects, then why is everyone concentrating on the 3 stage manifold? (I know why, because monkey see monkey do...)
01-05-2011, 12:57 PM | #20 |
195
Rep 3,640
because all of those things (minus compression) add flow through the motor. Adding more air will give you the ability to make more power. The 3 stage manifold adds more flow. you can get more power out of many cars by adding an intake and exhaust, without touching compression or valve lift. Everyone knows this. Adding the manifold is another way to increase flow.
Valvetronic adds both lift AND duration (though not separately). When valvetronic increases lift at the valve, it also increases duration at the same time. You are basically taking the base cam profile and applying a modifier to it, like base lift and duration X 1.5 at part throttle, and X 2.0 at WOT (just an example). it's variable, not stepped like VTEC is. The 330i runs more max lift+duration than the 325i, so changing the valvetronic program is like changing the camshaft on a regular car. |
01-05-2011, 01:11 PM | #21 | |
41
Rep 142
now we are getting somewhere... and again, this will take a competent tuner (not a manifold) to extract this feature out of the DME and thus, the most power output of this motor.
For Sale: Jet Black pre-LCI front bumper/hood/trunk lid, oe tail lights, 2 oe 16 inch rims w/ good tires. PM w/ offers. Last edited by allmotorh22; 01-05-2011 at 01:19 PM.. |
01-05-2011, 01:22 PM | #22 | |
195
Rep 3,640
actually, the way the manifold works, it adds power in both low and high rpm situations (at least according to the documentation). Either way, I don't really care about anything over 5000 rpm anyway, I don't race this car, and 99% of my driving is below 5000 rpm. Another poster here picked up over 20 ft/lbs of torque, with the manifold+tune, and that's what I'm going for. I want more low and midrange power for around town driving, and hopefully a bit better mileage too. If I want only high rpm power, I'll go drive my honda :P
Both AA and OE said they can modify the valvetronic programming, but at this point, it's not very impressive. We can just hope that they figure it out with more time, since they just got started working with the N52. In the meantime, I'm going to just swap the manifold and see how it goes. If I feel a noticeable difference, I'll go ahead and get the car dynoed again. I already have a baseline from when I had the pbx installed. Quote:
