Just installed Lux 5.1. Now have some questions.
01-16-2011, 02:14 PM | #1 |
Rep 117
I just installed Lux 5.1 for the angels and GP-Thunder for fogs on my 08 E90 335i. Looks great! Very happy with the results (see pics). I installed without removing the wheel or jacking up the car. I just turned the wheels out. It was a simple install. I did run into 1 issue where the wire on the Lux was crimped too tight during assembly and the wire fell off from the connector. I had to go buy a new connector to replace the faulty one.
I have had the Daeos angel eye harness installed for about a year now. It works great but does give me a front left parking light error when the headlights come on in auto. The error goes away within a few seconds so its not a big deal. After I installed Lux I get the error randomly while driving. This only happens in auto mode when the headlights are on. Anyone else have this problem? BTW: Sorry for the bad pics and the dirty car. It was raining and I took them with an iphone. |
01-16-2011, 03:44 PM | #4 |
Rep 2,854
they're visible during the day depending on your angle and which way the sun is shining.
they don't look nearly as bright and defined as some pics lead one to believe. still looks 10x more oem than the LED solutions i have seen, though... |
01-16-2011, 03:46 PM | #5 |
Rep 117
01-17-2011, 01:07 PM | #8 |
Rep 5,842
Drives: 2006 325xi
with the problem you are having, it sounds like it might be an issue with the wiring harness you have. If there was a problem with the LUX angel eye then i would expect you to have error messages all the time, not just in auto. My guess is that the harness might not be correct, or if there is a resistor that the resistance may be too low - causing the error.
01-17-2011, 03:13 PM | #9 | |
Rep 117
The LUX are AWESOME BTW. Much better than stock. I'll have some better pics up soon. |
01-17-2011, 03:28 PM | #10 |
Rep 1,523
Ive heard that the DAEOS are known to cause errors on certain model years. As for the Lux 5.1s, I installed a set last week. My only problem is that the right side appears slightly brighter than the left.
2002 Laguna Seca Blue E46 M3 6MT 2017 White C63 AMG Coupe 2002 Oxford Green E46 M3 6MT - Sold |
01-17-2011, 03:37 PM | #11 |
Rep 117
Weird. Mine are the same brightness on each side. Is there a way to install them wrong (ie. upside down)?
02-09-2011, 11:07 PM | #12 |
Rep 1,065
Drives: RB PWRED E90 N54 6MT
what's the major difference between Lux 5.0 and Lux 5.1?
RB Turbo/Procede V5/Vishnu PWM Meth Injection Kit/Vishnu DCI/AR Catless DP/AE Performance Exhaust(Sold)/Helix FMIC/Forge DVs/Rixster Vent Boost Gauge/Wavetrac LSD/KW V3/ACT Street Clutch Kit
02-10-2011, 10:35 AM | #13 |
Rep 117
02-10-2011, 11:06 AM | #14 |
469
Rep 4,938
LUX 5.1 is just the newer version. The color of 5.1 is slightly cooler at a 6500k and is a bit brighter as well.
03-21-2011, 08:10 PM | #17 |
Rep 437
looks sharp. im waiting for lux 5.1 myself. are you running stock xenons? the match looks pretty close. I might upgrade to mtec d1s 6000K and mtec 4350K fogs. I heard thats a good set up with the lux. anyone else have any other thoughts?
03-21-2011, 09:25 PM | #19 |
Rep 117
Yeah stock xeons. Lux is great. I'll take some daytime shots with the fogs on hopefully tomorrow.
03-23-2011, 09:05 PM | #20 |
Rep 241
I'm just about to do some coding on my car and I was told that angel eyes could be coded as DRL I will not need any harness thi feature is available on 08+ . I will give you an update next week when I'm done with the coding
03-23-2011, 10:41 PM | #21 |
Rep 117
Yep. I coded it and took the harness off. Got one for sale now cheap.
daeos, lux, lux 5.1 |
