05-11-2017, 01:09 PM | #89 | |
European Editor
10616
Rep 22,992
Dackel
06-06-2017, 07:37 PM | #91 |
Rep 42
FYI, just had the Whiteline 2-piece bushings (KDT917) installed, along with a bunch of other bits (M3 rear upper arms, new rear toe arms, M3 diff bushings, plus front end M3 lower arms and Dinan camber plates).
Performance is improved as you would expect per everyone else's feedback, no regrets. However, I'm posting this more as fair warning to those of you with northern cars getting up in age... the standard tricks to drop the subframe corner by corner and use sockets etc+heat to press out the old bushings ain't gonna work. Mine is 9 years old now, seen at least 7 Canadian winters, salt, and other abuse. The factory bushings were NOT coming out without a big fight. Wound up going to shop to drop subframe for the install, so I also did stainless brake lines at same time, as well as the diff bushings. In for a penny... There is no way I would have felt comfortable putting the kind of load required using a combination of jacks and jackstands. Shop said the front bushings came out pretty easily, but rears required putting the subframe on the press - no hand tools were going to get them out no matter how much heat etc was applied. If you have the press, why not use it I guess! One of the mechanics owns an E90 335i and he's decided when he does this job, he's buying a new subframe... yikes. Thanks for all who have provided advice in this thread - this is truly a great upgrade that I've been waiting to get to for more than a year. I would only add in that while you're in there, might as well put in an MPerformance LSD at the same time... Man that slope is slippery. |
04-22-2020, 05:43 PM | #92 |
Rep 537
Best Practice
I'm about to tackle the Whiteline 2-piece upgrades soon. As far as I can tell from these threads
1) I'll need a tool for the rears . Like https://www.1addicts.com/forums/show...ight=rsfb+tool 2) It is possible to push out the fronts with a large socket, heat, and the weight of the car to push them out. Mentioned here. https://www.1addicts.com/forums/show...3&postcount=50 Can anyone provide me a better description of the process in for #2? What size socket? where do you place it? and the safe way to apply the pressure to the bushing. Pics would be helpful for this if anyone has them. Thanks in Advance |
04-24-2020, 04:01 PM | #93 | |
European Editor
10616
Rep 22,992
You will need a on the car press like these... I am not sure of the M3 bushings size... but they are big... like three inches in diameter or so. When you have your new bushings, you can figure out the size. You might even need a larger C-clamp part to be able to press out the old bushings. From what I remember the tech telling me... the front ones were easy to do... but the rear ones were a real PITA. Astro Pneumatic Tool 7897 Ball Joint Service Tool and Master Adapter Set https://www.amazon.com/Keywords-5-se...f=sb_s_sparkle Dackel
05-30-2020, 09:30 AM | #94 |
Rep 1,995
Drives: '13 128i, '23 iX M60
My M3 bushings have arrived!
I’ve wanted to do this and replace the stock RFTs for a long time, but waited because I did not want to replace new tires. 7 years later, I’m ready for new tires and figure the bushings are going first. My dealer is going to do the install for $800, which I think isn’t too bad. Got the bushings for $273. You mention SS brake lines, do you have a recommended version? Will the dealer replace the oem with non oem? What does the 1M /M3 use? After the bushings are installed (next week), I’m getting 215/45/17 and 255/45/17 PS4S tires.
2023 BMW iX M60 BSM
2013 BMW 128i 6MT MGM/CR. M-sport/Premium/Cold, HK, Xenons, BMW SSK and PE. ED 7-12-2013 SOLD: '07 E90 6MT BSM/Terra, '18 F31 Sunset/Oyster, '21 Polestar 2 http://www.1addicts.com/forums/showthread.php?t=897862 |
06-24-2020, 06:05 PM | #95 | |
Rep 1,233
