Audio Table of Contents: Upgrading? Start HERE!
02-26-2012, 05:30 PM | #23 | ||
Rep 3,201
Oh, and Google's look service said:
03-28-2012, 01:06 PM | #24 |
ghey
484
Rep 2,041
The site still has malicious code; I rebuilt my PC yesterday and prior to having AV installed on it, went to the link, and was greeted with "You have 8 viruses" etc etc.. KAV is now installed; and I get a big fat warning message:
-- ACCESS DENIED -- The requested webpage cannot be provided. In the requested object at the URL http://www.musicarnw.com/start-here-your -car/ a threat has been detected: object infected HEUR:Trojan.Script.Generic Message generated on: 11:07:03 AM
21 G05 > 20 G05 > 17 G30 > 14 F30 > 08 E90
03-28-2012, 08:53 PM | #25 |
Rep 1,300
Just tested the site as well and got the same results,
Brian
Black Sapphire, Black w/Burrwood Trim & Shifter, 162's, Mtec H8 AE's, DS1 HID 6000K |
03-29-2012, 08:50 AM | #26 |
Rep 3,201
Manually ran our automatic security service last night - for some reason it was not initiating - cleaned off numerous malware instances. Apologies to all. We are looking at new hosting providers with enhanced security. All is clear now.
03-29-2012, 03:40 PM | #27 |
ghey
484
Rep 2,041
It sounds like you probably just need to change some passwords.. more than likely they were successfully brute forced via ftp and that's how the files/content is getting uploaded.. or you've got some CMS system that allows remote injections to put in malicious code from an outside source; i.e. an sql injection or a php array that's not structured correctly and is calling up HTML/Code from an infection source. Did you examine any of the files that it found to see what exactly they were doing and where they were getting the source data from?
04-19-2012, 08:35 AM | #29 | |
Rep 4,121
08-03-2012, 10:58 PM | #32 |
Rep 6
Thanks for great information
I decided I wanted to upgrade my 335i HD radio system and found this site. I have spent a couple of hours reading the content in this site and I have found it to be extremely helpful. You guys are obviously very good at what you do and know these cars inside and out! I now feel well armed to go ahead with my plans. I love the idea of no damage or cutting factory cables - let's do OEM quality work! I'm 56 years old and have been a professional engineer for 32 years - I'm a good judge of quality technical information and there's lots of it here! When I was in high school I worked as an installer in a local car stereo shop. Back then, (1970's) every job was a hack it seemed and the sound quality was never good, just loud... My how things have changed! Thanks again for offering this very special knowledge up to the rest of us!
08-11-2012, 10:11 AM | #33 | |
Washed Weekly
Rep 155
Quick question on the JL Audio XD600/6 - you mentioned it is a direct replacement for the HiFi amp - I understand it is a 6 channel but how would the underseat subs be run? I am looking at replacing amp, speakers and underseat subs and 1 amp for all would be ideal.... Cheers Edit - My I have purchased an E90 2nd hand. I cannot see a centre channel and it does not have Logic7 - trying to work out what I have.... Last edited by Zoo Tv; 08-11-2012 at 10:18 AM.. |
08-11-2012, 12:19 PM | #34 |
Rep 13,121
Hi Fi is 6 channels so is the xd600/6
The channels match up exactly in number and It also fits in the same area as the
stock Hi Fi amp if you remove the Hi Fi amp mounting bracket. So the subs run off two of the 6 channels just as they do in the stock setup. The xd 600/6 is about 5 times the power per channel. If you are going to ask questions its better to start a separate thread as this was intended to be an informational thread I think . Someone need to start separate sticky's for Subs and Processors and maybe a sticky for the MS-8 . Last edited by ctuna; 08-12-2012 at 01:08 AM.. |
08-14-2012, 02:37 PM | #35 |
Rep 14
I just want to add an amp to the OEM subs and eventually change them out too. There are some nice smaller amps out there that will do the job for now. I have one on my HD.
08-22-2012, 01:17 AM | #36 |
Rep 4
HHELP Hey guys im having a problem with my radio im pretty sure i have the logic 7 system in my car it all started when i had a bad battery replaced it then was using blue tooth and the sound went out got home checked all of the fuses none was blown car made a funny sound while checking fuses started the car and the sound was back then a few days later started the car radio was off turned it on and no sound and the usb option icon isnt there and notice keep popping up saying the sos call doesn't work then off then on and the sos button blinks green what is going on with my car is this some thing i can fix myself or do i have to take it in?????
08-23-2012, 07:50 PM | #37 | |
Rep 3,969
As to your problem, I'm no expert but it could be an issue with one of the devices in the MOST fiber-optic loop. Not sure if this is something you can self-diagnose...
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
08-24-2012, 01:29 PM | #38 |
Rep 842
I suggest removing the negative cable at the battery and then re connecting it to reset the radio.
2021 G05 X5 ///M50i / Phytonic Blue / Cognac Vernasca
iStep 03/2023.50 |
10-31-2012, 01:35 PM | #39 |
Rep 10
Drives: E90 07' 328i
just what i was looking for!
11-14-2012, 12:52 PM | #40 |
31
Rep 389
Drives: 2009 Bmw 328i w/ XDrive
I see the head unit section is pretty bare, so i have a quick question. does the car need rewired if you relocate the Stock headunit and replace it with a double din on a hifi system?
thanks Last edited by Dominus; 11-14-2012 at 01:04 PM.. |
11-17-2012, 12:02 PM | #41 |
Rep 4,121
True, that section is bare as it is a disfavored option, however the EXACT link you need is posted in that section.
11-18-2012, 12:12 AM | #42 |
31
Rep 389
Technically only the rellocation thread and dynavin threads are listed. Perhaps i should be more clear.
after relocating the head unit can i use the existing speaker wires and the stock amp with an aftermarket head unit on a Hifi system? My local audio shop tells me that my whole car will have to be rewired in order to install a double din. |
11-18-2012, 12:29 AM | #43 |
Rep 13,121
Domminus find another audio shop.
Or learn enough to do it yourself. No reason you can't use the existing wiring unless you are exceeding the current capacity of the wires. Most people don't rewire here. They may run another set of wires for the doors if they want to mount the crossovers in the trunk. If you believe in the Monster wire theory from Home stereo you might want to rewire but its not required. If you are not running any amps the shorter route would be splicing into the existing wiring , haven't seen anybody do that though. http://www.e90post.com/forums/showthread.php?t=138949 There are side effects putting in an aftermarket Head Unit is part of the reason its not done more I think. If you have the L7 System you will need to run wires to the trunk for amps maybe(Amp Input signals) . I am not sure if the car is pre wired for analog to the trunk with the L7 stereo. Last edited by ctuna; 11-18-2012 at 01:04 AM.. |
11-27-2012, 08:56 AM | #44 | |
31
Rep 389
Perfect just the answer I was looking for thank you. I just was unsure of the input signal difference between stock and aftermarket. I would def be doing a relocation though.
Again thanks Quote:
