The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > CC-ID Error Code List
      03-06-2012, 02:07 PM   #1
Elliott@DetailAddict
Drives: E90
Post CC-ID Error Code List
BMW CCID Code List
Instructions for use:
  1. Use your BC Stalk to enter the "Check Control" menu.
  2. Scroll to the desired error and hold the BC Stalk selector in until a CC-ID # is displayed.
  3. Use this list to identify the error. ("Find..." command in your Browser is recommended)
Active Cruise-Control
  • ACC 158 Active Cruise Control Disabled, Sensor Error
  • ACC 238 Active Cruise Control Disabled, Hill Descent
  • ACC 441 Cruise Control Deactivated
  • ACC 442 Vehicle may Roll Away
  • ACC 443 Vehicle Rolling Away
  • ACC 483 Active Cruise Control Temporarily Disabled
Crash Safety Module
  • ACSM 76 Crash Safety Module
  • ACSM 434 Seat Calibration Required
Active Front Steering
  • AFS 70 Servotronic Failed
  • AFS 273 Active Steering Fault
  • AFS 321 Active Steering Deactivated
Trailer Module
  • AHM 4 Trailer Parking Light Left
  • AHM 5 Trailer Parking Light Right
  • AHM 6 Trailer Indicator Left
  • AHM 7 Trailer Indicator Right
  • AHM 8 Trailer Brake Lights
  • AHM 9 Trailer Fog Light
  • AHM 75 Trailer Electrics Failed
  • AHM 90 Trailer Reverse Light
  • AHM 403 Trailer Rear Light/Numberplate Light
  • AHM 404 Trailer Left Indicator/Brake Light
  • AHM 405 Trailer Right Indicator/Brake Light
  • AHM 406 Trailer Electric Brake Failed
  • AHM 423 Trailer Coupling Lock
  • AHM 449 Trailer Coupling Electrics Failed
Dynamic Drive
  • ARS 10 ARS Roll Malfunction
  • ARS 11 Steering Malfunction
  • ARS 12 Dynamic Drive Failed
  • ARS 204 Dynamic Drive Disabled
Car Access System
  • CAS 14 Door Open F/R
  • CAS 15 Door Open F/L
  • CAS 16 Door Open R/L
  • CAS 17 Door Open R/R
  • CAS 18 Bonnet open
  • CAS 19 Boot open
  • CAS 21 Ignition Problem, Depress Brake to Start
  • CAS 22 Starter Problem, Engine cannot Restart
  • CAS 38 Wrong Remote Key
  • CAS 40 Press Brake to Start
  • CAS 65 Change Key, Key Battery Low
  • CAS 66 Remote Control/Key Fault
  • CAS 67 Remote Control/Key Battery Discharged
  • CAS 68 Remote Key Stationary Function Battery Low
  • CAS 186 ELV Steering Lock Fault. Engine cannot be restarted
  • CAS 187 ELV Steering Lock Active. Move Steering Wheel to Restart
  • CAS 205 Remote Key not Present
  • CAS 206 Engine Start on next Press
  • CAS 208 Comfort Access Deactivated
  • CAS 209 Remote Key in Vehicle, Locking not possible
  • CAS 217 No Remote Control
  • CAS 303 Depress Clutch to Start
  • CAS 335 Ignition Switched On
  • CAS 347 Position R/N/D Not Possible
  • CAS 348 Engage Park Before Leaving Vehicle
  • CAS 349 Engage Park Before Switching Ignition Off
  • CAS 413 Steering Column Unlocked
Convertible Top Module
  • CTM 267 Rear Window Drive
  • CTM 268 Luggage Compartment Position
  • CTM 270 Convertible Top Not Locked
  • CTM 271 Convertible Top, Vehicle Speed
  • CTM 272 Convertible Top Failure
  • CTM 401 Roof Mechanism Failure
  • CTM 416 Luggage Compartment Partition
  • CTM 432 Roof Drive Overload
  • CTM 445 Vehicle Not Level
  • CTM 516 Roof Operation Cancelled
  • CTM 518 Convertible Top Not Locked
  • CTM 519 Roof Operation Not Possible
  • CTM 558 Roof Position Detection
  • CTM 559 Roof Drive Overheated
  • CTM 560 Roof Operation Not Possible
  • CTM 561 Roof Emergency Operation
  • CTM 562 Roof Unlocked
Dual Clutch Gearbox
  • DKG 538 Gearbox Malfunction
  • DKG 539 Gearbox Malfunction 5-7
  • DKG 540 Gearbox Malfunction P
  • DKG 541 Gearbox Malfunction Manually Release Parking Lock
Digital Motor Electronics/Digital Diesel Electronics
  • DME/DDE 25 Preheating, Please Wait
  • DME/DDE 26 Cruise Control Defective
  • DME/DDE 27 Engine Oil Level Low
  • DME/DDE 28 Engine Oil Level Below Minimum
  • DME/DDE 29 Engine Problem, Power Reduced
  • DME/DDE 30 Engine Problem, Stop Engine
  • DME/DDE 31 Engine Problem, Increased Emissions
  • DME/DDE 32 Fuel Cap Open
  • DME/DDE 33 Engine Problem, Reduce Engine Load
  • DME/DDE 39 Engine Overheat, Stop Engine
  • DME/DDE 49 Particulate Filter Malfunction
  • DME/DDE 148 Brake Light Control Failed
  • DME/DDE 182 Oil Level Sensor Malfunction
  • DME/DDE 212 Engine Oil Pressure, Stop Engine
  • DME/DDE 213 Battery Not Charged
  • DME/DDE 220 Battery Discharge Rate High
  • DME/DDE 229 Battery Charge Low
  • DME/DDE 247 Battery Monitoring Failed
  • DME/DDE 257 Engine Temperature Too High, Drive Moderately
  • DME/DDE 304 Check Battery Condition
  • DME/DDE 305 Check Battery Terminals
  • DME/DDE 306 Battery Charge Low
  • DME/DDE 367 Engine Temperature Too High
  • DME/DDE 400 Engine Oil Level High
  • DME/DDE 427 Engine Oil Pressure Low
  • DME/DDE 448 Fuel Filter
  • DME/DDE 450 Automatic Start Deactivated
  • DME/DDE 492 AdBlue Reserve Low
  • DME/DDE 493 AdBlue Reserve Critical
  • DME/DDE 493 AdBlue Reserve Empty
  • DME/DDE 506 AdBlue Fluid Incorrect
  • DME/DDE 584 Transport Mode Active
Dynamic Stability Control
  • DSC 24 DBC Dynamic Brake Control Brake Assist Failed
  • DSC 35 DSC Failed
  • DSC 36 DSC/DTC Deactivated
  • DSC 42 DSC Control System/Ride Height adjustment
  • DSC 50 Runflat Indicator Failed
  • DSC 63 Tyre Failure
  • DSC 71 Brake Pads Worn
  • DSC 74 Brake Fluid Low
  • DSC 184 Dynamic Traction Control Active
  • DSC 215 Dynamic Stability Control
  • DSC 236 Brake and Stability Systems Failure
  • DSC 237 Stability Systems Failure
  • DSC 328 Brake Pad Wear Sensor
  • DSC 330 Hill Decent Control not Available
  • DSC 331 Hill Decent Control Active
  • DSC 332 Hill Decent Control Deactivated
  • DSC 333 Hill Decent Control not Possible
  • DSC 334 Run Flat System Requires Standardisation
  • DSC 336 Dynamic Stability Control
  • DSC 352 Brakes Too Hot
  • DSC 353 Brakes Overheated
  • DSC 354 Start Assist Inactive
  • DSC 364 RPA Initialisation
  • DSC 382 DSC Restricted, Brake Pressure Sensor
  • DSC 384 DSC Puncture Detected
  • DSC 431 Brake Loading Too High
  • DSC 608 Tyre Pressure Loss, Front Left
  • DSC 609 Tyre Pressure Loss, Front Right
  • DSC 608 Tyre Pressure Loss, Rear Right
  • DSC 608 Tyre Pressure Loss, Rear Left
Corner Brake Control
  • DSC/CBC 42 Brake and Driving Control Failure
Tyre Pressure Control
  • DSC/RPA 50 Tyre Monitoring Failure
  • DSC/RPA 63 Tyre Puncture
X Drive Control
  • DXC 350 4X4 System Failure
  • DXC 351 4X4 and DSC Failure
  • DXC 369 4X4, DSC and ABS Failure
  • DXC 370 4X4, DSC, ABS and EBV Failure
Dynamic Damper Control
  • EDC-K 43 Dynamic Damper Control Failed
  • EDC-K 180 Dynamic Damper Control Fault
Electronic Gearbox Control/Sequential Sports Gearbox
  • EGS/SSG 103 Gearbox Overheating- Drive with Care
  • EGS/SSG 104 Gearbox Overheating- Reduced Output
  • EGS/SSG 105 Gearbox Overheated - Stop Vehicle
  • EGS/SMG 168 Transmission Malfunction
  • EGS/SMG 169 Transmission Position N
  • EGS/SMG 170 Transmission Malfunction Reset
  • EGS/SSG 171 Transmission Failsafe Active
  • EGS/SSG 172 Transmission Malfunction
  • EGS/SMG 173 Transmission Position D Only
  • EGS/SMG 174 Transmission Position P Only
  • EGS/SMG 175 Transmission Malfunction, Position P
  • EGS/SSG 178 Transmission in Neutral, Engage Parking Brake
  • EGS/SSG 179 Transmission Malfunction
  • EGS/SMG 203 Transmission Position in N
  • EGS/SSG 248 Brake Signal Malfunction, Gears May Be Selected Without Brake
  • EGS/SSG 250 Brake Signal Malfunction, Gears May Be Selected Without Brake
  • EGS/SMG 251 Transmission Position P
  • EGS/SMG 252 Transmission Malfunction
  • EGS/SSG 254 Transmission Malfunction Emergency Program
  • EGS/SSG 255 Malfunction R,N,D Only With Engine Running
  • EGS/SSG 287 Clutch Overheated
  • EGS/SSG 288 Transmission Malfunction, Failsafe Activated
  • EGS/SSG 289 Transmission Malfunction, Failsafe Activated
  • EGS/SSG 290 Transmission Malfunction, Journey May Be Continued With Care
  • EGS/SSG 291 Transmission Malfunction, Failsafe Activated
  • EGS/SSG 292 Transmission Malfunction, Re-Select Gear
  • EGS/SSG 293 Press Brake and Select Neutral to Start
  • EGS/SSG 302 Park Not Engaged
  • EGS/SSG 307 Transmission Malfunction, Multiple Failures
  • EGS/SSG 322 Transmission Teach-in Active
  • EGS/SSG 323 Clutch Teach-in Active
  • EGS/SSG 325 Transmission in Neutral
  • EGS/SSG 326 Transmission in Drive
  • EGS/SMG 363 Transmission Overload
  • EGS/SMG 365 Transmission Failsafe
  • EGS/SMG 366 Transmission Fault, Failsafe
  • EGS/SSG 368 Transmission Failsafe Active
  • EGS/SMG 394 Gear Selector Lever
  • EGS/SMG 398 Engine Bay Cover Open
  • EGS/SMG 399 SMG State Undetermined
  • EGS/SSG 419 Drive Malfunction
  • EGS/SSG 420 Transmission Malfunction
  • EGS/SMG 446 Launch Control
  • EGS/SMG 557 Rolling Possible, Secure Vehicle
  • EGS/SMG 565 Gearbox Position P only Available when Stationary
Electro Hydraulic Brake
  • EHB 439 Parking Brake Overload
  • EHB 452 Release Autohold
Electronic Height Control
  • EHC 45 Level Control System Failure
  • EHC 245 Level Control System Failure
Electric Fuel Pump
  • EKP 216 Fuel Pump Fault
  • EKP 309 Fuel Pump Malfunction
Parking Brake
  • EMF 48 Parking Brake
  • EMF 51 Parking Brake Overheated
  • EMF 52 Parking Brake Failed
  • EMF 53 Automatic Hold Malfunction
  • EMF 54 Parking Brake Malfunction
  • EMF 55 Parking Brake Release
  • EMF 56 Parking Brake
  • EMF 57 Parking Brake
  • EMF 58 Parking Brake
  • EMF 201 Automatic Hold Disabled
  • EMF 210 Parking Brake Failed
  • EMF 211 Parking Brake Failed
  • EMF 239 Parking Brake Failed
  • EMF 240 Parking Brake Failed
  • EMF 241 Parking Brake Failed
  • EMF 242 Parking Brake Failed
  • EMF 243 Parking Brake Failed
  • EMF 253 Parking Brake Failed
  • EMF 395 Parking Brake Malfunction
  • EMF 402 Apply Foot Brake
  • EMF 410 Parking Brake Malfunction
  • EMF 465 Parking Brake Failure
  • EMF 480 Parking Brake Malfunction
  • EMF 481 Parking Brake Malfunction
  • EMF 482 Parking Brake Failure
Electronic Power Steering
  • EPS 73 EPS Inoperative
  • EPS 385 Steering Assistance Failed
High Beam Assistant
  • FLA 374 Main Beam Assist Defective
  • FLA 375 Main Beam Assist Not Active
  • FLA 376 Main Beam Assist Not Active
  • FLA 377 Main Beam Assist Sensativity
Footwell Module
  • FRM 87 Right Rear Light Failure
  • FRM 88 Dipped Beam Left Failure
  • FRM 89 Dipped Beam Right Failure
  • FRM 111 Number Plate Light Left Failure
  • FRM 113 Sidelights Switched On
  • FRM 114 Rear Fog Light Failure
  • FRM 115 Reverse Light Right Failure
  • FRM 116 Indicator Rear Left Failure
  • FRM 117 Reverse Light Left Failure
  • FRM 118 Rear Light Right Failure
  • FRM 119 Indicator Front Right Failure
  • FRM 120 Dipped Beam Left Failure
  • FRM 121 Dipped Beam Right Failure
  • FRM 122 Indicator Front Right Failure
  • FRM 123 Rear Light Right Failure
  • FRM 124 Indicator Right Failure
  • FRM 125 Indicator Rear Right Failure
  • FRM 126 Fog Light Right Failure
  • FRM 127 Side Indicator Left Failure
  • FRM 128 Left High Beam Failure
  • FRM 129 Rear Fog Light Failure
  • FRM 130 Right High Beam Failure
  • FRM 131 Parking Light Left Front Failure
  • FRM 132 Front Right Side Light Failure
  • FRM 133 Right Rear Light Failure
  • FRM 134 Right Brake Light Failure
  • FRM 135 Centre Brake Light Failure
  • FRM 136 Left Brake Light Failure
  • FRM 137 Number Plate Light Right Failure
  • FRM 138 Fog Light Left Failure
  • FRM 196 Indicator Front Right Failure
  • FRM 197 Indicator Front Left Failure
  • FRM 231 Light System Failure
  • FRM 256 Headlight Leveling System Failure
  • FRM 259 Window Anti-Trap Deactivated
  • FRM 261 Window Anti-Trap Failure
  • FRM 345 Brake/Tail Light Failure Right
  • FRM 346 Brake/Tail Light Failure Left
  • FRM 371 Number Plate Light Failure
  • FRM 372 Brake Force Display Light Failure Left
  • FRM 373 Brake Force Display Light Failure Right
  • FRM 378 Sidelight/Daytime Lights Defective- Left
  • FRM 379 Sidelight/Daytime Lights Defective- Right
  • FRM 380 Turn Signal Lights Defective- Left
  • FRM 381 Turn Signal Lights Defective- Right
  • FRM/ALC 295 Adaptive Cornering Lights Failure
  • FRM 437 Parking Lights On
Gear Selector Switch
  • GWS 393 Gear Selector Position
  • GWS 467 Gear Selector Malfunction/Locking
Luggage Compartment
  • HKL 422 Luggage Compartment Lower Lid
Hybrid
  • HYBRID 569 Drive Malfunction, Stop
  • HYBRID 570 Drive Range Low
  • HYBRID 571 Drive, Only Forward Crawling Speed is Possible
  • HYBRID 572 Drive, Only Forward and Reverse Crawling Speed is Possible
  • HYBRID 573 Gearbox Malfunction
  • HYBRID 574 No Braking Energy Reclamation
  • HYBRID 575 Refueling- Wait
  • HYBRID 576 Refueling Only Possible When Standing
  • HYBRID 577 Refueling Possible
  • HYBRID 578 Fuel Filler Flap Open
  • HYBRID 579 Fuel System Malfunction
  • HYBRID 585 High Voltage System Malfunction
  • HYBRID 586 High Voltage System Malfunction
  • HYBRID 587 High Voltage Battery Low
  • HYBRID 588 High Voltage Battery, Switch Ignition on to Charge
  • HYBRID 589 High Voltage Battery Charging
  • HYBRID 590 Vehicle Ready
  • HYBRID 591 High Voltage Battery Charging Aborted
  • HYBRID 606 High Voltage Battery Output Restricted
  • HYBRID 607 High Voltage Battery Regeneration Required
Intergrated Chassis Management
  • ICM 474 Driving Performance Control Failed
Instrument Cluster
  • IKE 13 Radio Key in Lock
  • IKE 41 Service Due
  • IKE 55 Parking Brake Active
  • IKE 60 Speedometer Failure
  • IKE 62 Vehicle Speed Limit Exceeded
  • IKE 78 Vehicle Speed Limit Exceeded
  • IKE 79 Low External Temperature
  • IKE 165 Low External Temperature
  • IKE 167 Reset Clock
  • IKE 185 Gear Indicator Failed
  • IKE 275 Low Fuel
  • IKE 279 Driver's Seat Insecure
  • IKE 280 Passenger's Seat Insecure
  • IKE 281 Service Due
  • IKE 282 Instrument Cluster
  • IKE 283 Instrument Cluster
  • IKE 284 Service Overdue
  • IKE 285 Service OK
  • IKE 286 Fuel Low / Range
  • IKE 301 Seatback Monitoring Failed
  • IKE 308 Parking Brake Applied
  • IKE 999 Instrument Cluster Fault
Junction Box
  • JB 164 Windscreen Washer Fluid Low
  • JB 166 Engine Coolant Level Low
  • JB 183 Windscreen Wiper Malfunction
  • JB 207 Central Electronics Failure, Stop Vehicle
  • JB 415 Battery Discharge Rate High
  • JB 430 Transport Mode Active
Longitudinal Dynamics Management
  • LDM 1 Active Cruise Control Disabled, Poor Conditions
  • LDM 2 Active Cruise Control Disabled, Poor Signal
  • LDM 3 Active Cruise Control Failure
  • LDM 59 Active Cruise Control Disabled, Parking Brake
  • LDM 69 Active Cruise Control Disabled, Speed too Low
  • LDM 85 Active Cruise Control Disabled, Hill Descent
  • LDM 176 Active Cruise Control Disabled, Sensor Error
  • LDM 177 Active Cruise Control Malfunction
  • LDM 199 Cruise Control Failed
  • LDM 246 Active Cruise Control Disabled, Speed too Low
  • LDM 276 Engine Speed Too High
  • LDM 277 Active Cruise Control Disabled, Gear Selection
  • LDM 278 Engine Speed Too Low
  • LDM 337 Dynamic Cruise Control Failure
  • LDM 338 Dynamic Cruise Control Deactivated, Parking Brake
  • LDM 339 Dynamic Cruise Control Deactivated, Excessive Braking
  • LDM 340 Dynamic Cruise Control Deactivated, Poor Conditions
  • LDM 341 Dynamic Cruise Control Deactivated, Gear Selection
  • LDM 342 Dynamic Cruise Control Deactivated, Speed Too Low
  • LDM 453 Cruise Control Short Range Sensors Disabled
  • LDM 454 Cruise Control Short Range Sensors Soiled
  • LDM 469 Cruise Control Deactivated, Sensors Soiled
  • LDM 478 Cruise Control Deactivated, Radio Astronomy Intervention
Electric Sunroof
  • MDS 260 Sunroof Anti-Trap Deactivated
  • MDS 262 Sunroof Anti-Trap Failure
Multiple Restraint System
  • MRS 46 Fasten Seat Belt
  • MRS 91 Fasten Seat Belt
  • MRS 92 Front Passenger Seat Belt Pretensioner Fault
  • MRS 93 Driver's Seat Belt Pretensioner Fault
  • MRS 94 Rear Left Seat Belt Pretensioner Fault
  • MRS 95 Rear Right Seat Belt Pretensioner Fault
  • MRS 97 Multiple Restraint System Fault
  • MRS 106 Rear Left Side Airbag Fault
  • MRS 107 Rear Right Side Airbag Fault
  • MRS 108 Driver's Airbag Fault
  • MRS 109 Passenger Airbag Fault
  • MRS 181 System Check Failed
  • MRS 266 Rollover Protection Malfunction
  • MRS 389 Fasten Driver's Seat Belt
  • MRS 390 Fasten Passenger's Seat Belt
  • MRS 391 Multiple Restraint System
  • MRS 392 Fasten Seat Belt
  • MRS 612 MRS Acceleration Sensors
Night Vision Control
  • NVC 356 Night Vision Failure
Park Distance Control
  • PDC 195 Park Distance Control Failure
Reversing Camera
  • RFK 424 Reversing Camera Soiled
  • RFK 425 Reversing Camera Failure
  • RDC 139 Front Left Tyre Pressure
  • RDC 140 Rear Right Tyre Pressure
  • RDC 141 Rear Left Tyre Pressure
  • RDC 142 Check Tyre Pressures
  • RDC 143 Front Right Tyre Pressure
  • RDC 144 Tyre Pressure Monitoring Fault
  • RDC 145 Tyre Pressure Monitoring Deactivated
  • RDC 147 Tyre Puncture Detected
  • RDC 149 Tyre Pressure Monitoring Failure
  • RDC 192 Tyre Pressure Monitoring Deactivated, System Initialising
  • RDC 265 Check Tyre Pressures, Mismatch
  • RDC 327 Tyre Pressure Monitoring Deactivated, System Initialising
Sensotronic Braking Actuation
  • SBA 601 Braking System Malfunction
  • SBA 602 Braking System Malfunction
  • SBA 603 Braking System Sensor Malfunction
  • SBA 604 Braking System Failure
Seat Module
  • SIMO 436 Seat Position Detection Fault
Telecommunications Module
  • TCU 296 SOS Deactivated, Check Phone
  • TCU 297 BMW Assist Deactivated
  • TCU 298 BMW Assist Not Possible
  • TCU 299 SOS Call System Failure
  • TCU 300 BMW Assist Deactivated, Check SIM.
Time to Line Crossing
  • TLC 435 Lane Departure Warning Fault
Video Switch
  • VSW 428 Side Camera Defective
      03-06-2012, 02:37 PM   #2
hsleiman
hsleiman's Avatar
Lebanon
Drives: 11 e90 335xi PPK 6MT
Very nice stuff, should be a sticky. Thank you.
      03-14-2012, 03:06 PM   #3
Drives: E90
Thanks for the thread move update Jason
      09-28-2014, 12:28 PM   #4
E92Moe
Drives: 2007 e92 auto
Was searching for a Full List if it exists - I am Getting CC-ID-19 anyone know what this is?
      07-07-2015, 12:15 PM   #5
rcconf
Drives: 2006 325i
Thanks for the list.
      03-17-2022, 07:01 PM   #6
Lucian009
Drives: '08 335xi cpe, '09 535x wgn
2008 bmw 335xi  [0.00]
2009 bmw 535 xi  [0.00]
Thank you very much for this list, and I know this is 7 years later, but does anyone have a list with the Service codes as well?
