04-15-2012, 03:05 PM | #1 |
307
Rep 2,612
Drives: F30 328i Luxury - Sport Auto
F30 Hidden Menu
EDIT: Here is the hidden service menu guide from my car:
Anybody found the hidden menu in the F30 yet and confident in using it? I'm talking about the one between the speedometer and revs as in my video of my E90 330d below, although the iDrive one would be nice too. Any owners out there willing to upload a video guiding us through it? EDIT: Here is the instrument test on my F30 which is even easier than the E90 to use!
Gone: 2006 BMW E60 520d SE 6MT Gone: 2009 BMW E90-LCI 330d SE 6MT Current: 2012 F30 328i Luxury 8AT On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!) Last edited by SomeRandomer123; 04-15-2014 at 05:27 PM.. Reason: Addition of video |
04-15-2012, 03:11 PM | #2 |
Rep 10,185
Press the start button without starting the engine ( Auto - no foot on the brake -Manual clutch not in) turn on the car
Press the cluster reset button for longer than 10 seconds The Idrive one should be similar to the E90 LCI procedure
BMW if you are reading, I need a job, Please. |
MARC20102.00 |
04-15-2012, 03:18 PM | #3 | |
307
Rep 2,612
Not too worried about the iDrive, yeah I assume it's the same if not very similar.
Gone: 2006 BMW E60 520d SE 6MT Gone: 2009 BMW E90-LCI 330d SE 6MT Current: 2012 F30 328i Luxury 8AT On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!) |
04-15-2012, 03:24 PM | #4 |
Rep 10,185
Only the fist 4 cluster functions are available without the unlock code being entered, so you should be fine
Test 02 is the system test which is probably like the one you have in the video Test 03 exits the tests
04-15-2012, 03:42 PM | #5 | |
307
Rep 2,612
Another question I do have regarding my E90 (and therefore probably the F30), if I go to menu 19 and unlock all the menu's by entering the total of the final 5 VIN numbers, can I mess things up? I would be interested to see them all and understand them but I will go without if there is a risk I can screw my car up!
04-15-2012, 04:06 PM | #6 | |
Rep 10,185
The F30 list of tests is different from the E90 one There are some youtube videos that show the all tests on the E90
04-15-2012, 04:19 PM | #7 | ||
307
Rep 2,612
04-15-2012, 05:42 PM | #8 |
Rep 1,879
Drives: 2012 F30 328i
Just curious here, what's the purpose of entering the hidden menu?
F30 328i Luxury w/ Mojave metallic, beige interior (timeline)
Note: Many PM me for links to the software needed to code. Please note that I do not have download links to this software. Your best bet is using the search function in the coding thread |
04-15-2012, 08:58 PM | #10 |
Rep 702
04-15-2012, 09:38 PM | #11 |
452
Rep 2,148
Drives: F87 M2 BSM MT
+1
04-15-2012, 09:40 PM | #12 |
Rep 1,063
In order to get the speed "V=xxx" on the cluster, you need to program the vehicle using NCSExpert software using a D-CAN cable.
Delivered --> '21 G01 X3 M40i, 8SA, Sunstone Metallic with Cognac Vernasca, 22Z, ZDA, ZDB, ZPK, ZPP w/ 4HA, ZPX, 2VF, 3AC, 4K1, 688, 6NW, 5DF
Past --> ?19 G01 X3 m40i, 15 F33 328xi, 8SA, '13 F30 328i, '08 E92 335xi, '95 E34 530i, '88 E30 M3 |
04-16-2012, 04:03 AM | #13 |
Rep 1,879
lol so it's pretty much useless for us then xD
04-16-2012, 09:49 AM | #14 | |
307
Rep 2,612
04-16-2012, 10:46 AM | #15 |
Rep 10,185
Troubleshooting of problems by the dealer without having to hook the car up to the dealer diagnostics system or when they cant hook it up )like out on the road or on a test drive)
04-16-2012, 10:47 AM | #16 |
Rep 10,185
I do, but not sure if it may be made public. Will ask the source
04-16-2012, 03:39 PM | #17 |
307
Rep 2,612
Righty! How the hell do you get this stuff?!?!
04-17-2012, 07:10 AM | #18 |
Rep 142
He has sources
Finally arrived: BMW F30 328i Sportline
Sport AT, Mineral Grey, Black interior, Alum w/ high-gloss black interior trim, Sports seats + Lumbar support, Harman Kardon sound, Nav system Prof, PDC (f+r), Rear view camera, comfort access, Xenon lights. |
06-26-2012, 02:59 AM | #19 |
/dev/random
31
Rep 353
iDrive hidden service menu
F30 with (professional) navigation
This implies that you have an idrive controller that can slide up and down Call up Start (main) menu • Push controller in up direction for at least 10 s • Rotate controller, 3 notches to the right • Rotate controller, 3 notches to the left • Rotate controller, 1 notch to the right • Rotate controller, 1 notch to the left • Rotate controller, 1 notch to the right • Press controller once • The Service menu is now added as the last submenu to "Settings" F30 without navigation, or with Business Navigation This implies that you have an idrive controller that cannot slide up or down The instructions are basically the same, but instead of pushing the controller in the up direction, which is not possible, you need to push the controller to the left and keep it there for 10 seconds. So the instructions become; Call up Start (main) menu • Push controller in the left direction for at least 10 s • Rotate controller, 3 notches to the right • Rotate controller, 3 notches to the left • Rotate controller, 1 notch to the right • Rotate controller, 1 notch to the left • Rotate controller, 1 notch to the right • Press controller once • The Service menu is now added as the last submenu to "Settings" |
06-26-2012, 05:54 AM | #20 |
Rep 4
Bluetooth pairing reset
Is there perchance a setting for resetting paired bluetooth devices/BT settings under the service menu? My BT link dropped a week ago and now i can't get any device (phone) paired to the car (it broadcasts PINs at regular intervals when i start the car but doesn't make a connection)...
06-26-2012, 11:12 AM | #21 | |
307
Rep 2,612
08-22-2012, 09:11 AM | #22 | |
9
Rep 23
Service Menu
diagnostics, f30, hidden, menu, obd |
