06-25-2007, 01:46 AM | #1 |
#thatsanicemovebro
202
Rep 3,920
Drives: E92 M3 LSB/Black 6MT
Clutch drops and general MT questions - Help a noob!
I am a noob...at least when it comes to driving MTs...I have a 335 MT and would like to know everything wrong with something that I'd like to do before I would actually go ahead and do it. For that, I have a few questions, and as nooby as they are, having them answered would be greatly appreciated. I mean, how else would I learn?
Now, I know the 335 has a CDV, thus delaying the clutch engagement for noobs like me that would drop the clutch. Without it, I hear that it's easy to modulate the clutch and that shifts are more seamless. So, questions: 1- What is dropping the clutch? Is it the fact that you reengage the clutch while still giving the engine power? 2- For a 335i w/ a CDV (I know...all MT 3s have one..), would a quick shift from 1st to 2nd still produce a jolt, even if the clutch is completely engaged before flooring it again? 3- That nice little smell from the engine bay after some hard driving, might that be the clutch getting raped because of excess slip? 4- W/out a CDV, would a quick shift from x to x+1 still produce a jolt if the clutch is completely reengaged before power delivery? The fact that your driveline is not protected as much, does that mean you can't drop the clutch with fast shifts? Is the delete mod geared towards the normal drivers or for the eager ones? 5- What is the advantage of a CDV delete and what does the CDV do to protect the driveline at the expense of the clutch. 6- How bad is it to shift quickly, as compared to smooth shifting, with moderate clutch "riding" or slipping. 7- Is there any way to remove that jolt from 1st to 2nd shift (@ high RPMS) while still having a CDV? 8- What are the downsides to shifting @ high RPMS (ex. hard acceleration w/ 7000RPM shifts) and are these surmountable? 9- With revmatching, when you would press on the throttle while having clutch disengaged to match revs of the lower gear that you are shifting into, isn't that really really bad for the clutch? Is it better to blip? If I have more, I will post them. Really sorry for all this guys, but I've done a lot of research and have found a lot, but there are still these lingering questions in my mind. Help a noob out! P.S. Mods, I didn't know the best place to put this, so move it anywhere you think is better. Last edited by GewoW; 06-25-2007 at 02:37 AM.. |
06-25-2007, 04:53 PM | #2 |
#thatsanicemovebro
202
Rep 3,920
Anyone?
07-03-2007, 06:08 PM | #4 | ||||||||||
195
Rep 2,816
You are usually reengaging the clutch while still giving engine power...remember you bleed off one pedal as your are gradually/bleeding on the other pedel Quote:
You probably never want to "drop" the clutch at high RPM...even if you have a CDV installed. As I understand it, the benefits of driveline protection from the CDV is minimal compared to the benefits of removal (particularly longer clutch life). Quote:
"The Clutch Delay Valve (CDV) is a one-way restrictor installed by the factory between the clutch slave cylinder and clutch master cylinder, as shown in Figure 1. It "delays" the engagement of the clutch, much like old record players used a damped tone-arm to gently lower the needle onto the surface of a record. Because of this valve, no matter how quickly you lift your foot off the clutch pedal, the clutch engages the flywheel at a constant (slow) rate. In theory, it can save the driveline from shock, were an inexperienced (or immature) driver to dump the clutch at high RPM. But in practice, all it does is prematurely wear out the clutch and turn experienced drivers into people who, despite 20 years of practice, cannot shift gears smoothly. " Quote:
I am still trying to perfect my shift...as everyone is... The videos are quite helpful...especially in getting you to listen for immediate pitch changes (from the transmission) which signifies a clean shift vs. a sloppy shift where the pitch sounds like it is winding up and then down. All us noobs are so careful about damaging our manual trannys--which is a good thing. But I always remind myself that they are not made out of cotton candy...it's a fairly robust/strong unit. Just as long as I don't abuse the tranny ALL the time...sloppy shifts while practicing isn't going really hurt the car that bad. And if I need the replace the clutch prematurely...oh well...part of learning. Quote:
It seems that done properly, you can likely safely shift at high RPMs without much or if any added stress to your car's drive line or clutch. Quote:
=== Hope this is somewhat helpful and correct. Others have corrections to make to what I have said? |
07-05-2007, 08:45 PM | #6 |
AC
95
Rep 2,387
I am adjusting my driving style around this CDV, I am beginning to think they put this in to prolong the drivetrain from this crazy engine.
Your Supreme Leader
07-06-2007, 01:01 AM | #7 | |
195
Rep 2,816
I think it was more for protection for the idiots who would rev the engine to 4k+ and dump the clutch... |
