FORUMS
- 5
| Please visit one of the specific Bimmerpost sites above |
| 08-31-2007, 03:09 PM | #1 |
Administrator
Tutorial: Photographing moving vehicles
Found this a good read for some guidelines/tips:
http://www.morguefile.com/archive/cl....php?lesson=12 |
| 08-31-2007, 04:41 PM | #2 |
Its All About The Offset
Drives: 2011 E90 M3 ZCP Join Date: Feb 2007
Location: Where you come to vacation and go home on probation: Vegas
Good find
________ Marijuana test ________ MARIJUANA VAPORIZERS ________ Fix ps3 ________ Alarice live ________ Niccola Last edited by Vegas_Sirk; 09-19-2011 at 10:03 AM. |
| 08-31-2007, 06:41 PM | #3 |
FWIW, sticking stuff on the outside of your car will get the attention of the police. One of our guys heading down to Bimmerfest last spring had his camera stuck on the side of his car with a suction cup mount. The CHP pulled him over and told him to remove it.
| 01-29-2008, 06:47 AM | #5 |
Z4M CSL
You don't need to mount your camera to the car to get shots like that. You can just as easily hand-hold and shoot through an open window of the travelling car, or out the hatch.
The only advantage of mounting the camera, is that you could mount it lower on the car than you could reach, and get a lower perspective shot.
![]() - 19" CSLs w/ PSSs - TCK Carbon Roof - BMW Carbon Lip Spoiler - Gruppe-M Intake - H&S GT cat-back - KW Clubsports - AP Racing 6/4 pots - Pagid RS29 - Custom Recaro PP - Schroth Profi ASM - |
| 01-29-2008, 06:53 AM | #6 |
The Law.
For rig shots, the car should not even be on let alone driving 50+mph on the freeway. If your recording video, thats a whole other subject. But as far rig shots go, the engine should not be on because the vibration will cause the rig/camera to shake. Also, the car should probably be moving less then 5mph. Anymore is just overkill imo.
| 01-29-2008, 08:46 AM | #7 |
Just learn Photoshop!
Apple's market share is bigger than BMW's or Mercedes's or Porsche's in the automotive market. What's wrong with being BMW or Mercedes?
Join us: http://www.autofriendship.com |
| 12-12-2008, 12:08 PM | #9 |
![]() Drives: 335i E92 Montego Blue Join Date: Aug 2008
Thanks for posting, thats great!
| 01-25-2009, 09:48 PM | #10 |
1junkie
the link in first post isn't working for me
![]() Mod List: BMW Performance Parts: Front Bumper | Suspension | Exhaust | Gear Knob | Hand Brake | Steering Wheel www.M7M-Photography.com |
| 01-26-2009, 10:35 PM | #11 | |
Night Sh1ft
Drives: E90 M3 Join Date: Oct 2007
then again, if you dont have open roads, you cant be using a rig anyways...so I guess, +2
![]() Canon 14 F2.8 L II : Canon 50 F1.2 L : Canon 24-70 F2.8 L : Canon 70-200 F2.8 IS/L : Canon 5D Mark II : B+W Filters : Photo Whore |
| 02-02-2009, 08:51 PM | #12 |
Here are some more rig pics...
http://www.blog.spoongraphics.co.uk/...tography-shots And a small write up done by the guy that took em... http://mattwatkinson.com/blog/?p=60 |
| 03-29-2009, 01:48 AM | #13 |
Bootleggin' 'n Gunrunnin'
The original link is busted. Here is the corrected link:
http://www.morguefile.com/docs/Class...oving_Vehicles
Scott
2010 E70 X5 35d Alpine White on Black with Dark Bamboo trim ZAP | ZCW | ZPP | ZPS | ZRC | ZTP | 322 | 328 | 330 | 386 | 4AZ | 4UB | 655 | 6FL | 6NF 2008 Ducati 1098S Red naturally.... |
| 07-03-2009, 08:05 AM | #14 |
HALA MADRID!
what shutter speed are you guys using?
I have a 17-50mm 2.8, and been trying to use 1/25 and shots wont come right. Any suggestions?
![]() __________________________________________________ ____________ e90 M3, Interlagos Blue / M individual two-tone, ZCP, ZP2, ZCV, DCT, ED. |
| 07-14-2009, 04:13 PM | #15 | |
I'm new to the forums, but have been into photography for a while. It depends on what focal range you're shooting, but a general rule to follow, is 1/<focal range> at minimum. So..if you're shooting at 17mm, you should be ok but at 50mm your shutter isn't fast enough. To compound the issue further, if you're using a crop body sensor, you need to take your focal range times your crop. For instance. A Canon 50D has a sensor crop size of 1.6. So with a standard EF lens at 17mm, you're actually shooting at an effective range of 27.2mm, so your shutter still isn't fast enough. This doesn't take into account shooting from a moving car either, so you will want even faster for that. Might have to sacrifice some noise and bump up your ISO. |
| 08-20-2009, 01:23 AM | #16 |
Is twizted... But has no real bunny
I have never handheld a rolling shot using anything slower than 1/60th shutter speed... 1/25th is too long and the image becomes blurry and over exposed(depending on aperture settings)
here are a couple of mine at 1/60th handheld, out a window of a moving car at about 40mph. ![]() ![]() Edit: I also shoot with shutter priority, I believe it is Tv mode on the canon I use, I don't want to adjust aperture and shutter when I shoot my rollers due to the fact that I shoot in the morning or evening and the light is always changing. Now I am not saying you cannot do rolling shots on full manual mode, but I am suggesting that you save yourself some time and get in more shots instead of messing with the aperture and shutter settings after every 5-10 shots.
That bathroom is made of lead... Time can't get in there...
![]() Last edited by Twizted_bunny; 08-20-2009 at 07:07 AM. |
| 08-28-2009, 02:00 AM | #17 |
BEEP BEEP
TV MODE, AI SERVO, keep it 1/60 and up.
Sit in the rear passenger of a car, and stick your head out with the camera. Be safe.
![]() 2003 911 Turbo | K24/18G | Bone Stock Exterior |
| 09-25-2009, 05:17 PM | #18 |
![]() Drives: R56 Cooper S Join Date: May 2009
I really need to try this. I've been cheating with PS all along.
Anthony M. | european auto source (eas)
email: anthony@europeanautosource.com web: www.europeanautosource.com tel 866.669.0705 | ca: 714.369.8524 x25 | fax: 714.908.1796 Blog | Facebook | YouTube | Flickr | Twitter |
| 01-20-2010, 10:49 PM | #20 |
Image Guru
Great Thread!
| 09-24-2010, 08:23 AM | #22 |
![]() ![]() Drives: 2006 BMW 330i ZPP, ZSP Join Date: Dec 2008
| Bookmarks |
| Thread Tools | Search this Thread |
