BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - Rockies / Midwest > 93 octane in Colorado Springs
      05-25-2013, 04:32 AM   #1
Neutrino45
Neutrino45's Avatar
62
Drives: XXX
Can I get 93 octane in Colorado Springs or Monument?
      05-25-2013, 03:06 PM   #2
richpike
Drives: MDX, LR4
Not sure about Monument, but the only place I knew of in the Springs was a place on 30th and Centennial. Unfortunately, they got bought by Phillips 66 and initially switched the 93 over to E85 (awesome!), but now they switched that to diesel
If you find a place, post it up please!
Rich
      05-27-2013, 09:23 AM   #3
Neutrino45
Neutrino45's Avatar
62
Drives: XXX
Damn, that sucks. Thanks for the reply.
      05-27-2013, 02:36 PM   #4
Evil///M
Professional Hitman
Evil///M's Avatar
Drives: R8 V10+ | Colorado Z71
just mix a little bit of e85 with 91
      05-27-2013, 06:53 PM   #5
Speedwagon
Speedwagon's Avatar
Drives: Sportwagon
Will the E85 eat up the fuel lines or the lining in the fuel system?
      05-30-2013, 03:36 AM   #6
Laguna Seca Blue
Laguna Seca Blue's Avatar
Drives: N54 E92 | N55 F15 | N55 E70
No, you'll be fine Just mix in a little to prevent timing drops if you're worried.
I didn't realize you could get 93 in CO. I've only seen 91. Isn't Octane a function of atmospheric oxygen concentration? If you brought CO 91 down to sea level it would be 93, correct?
E92 335i 6MT | Balloon White | Black Dakota Leather - Sold
PROcede Rev3 V5 | AE Quad Exhaust | BMW Performance Short Shift Kit | Gunmetal 19" M3 GTS Wheels | BF Goodrich g-Force T/A KDW 2 | AST 4100 Coilovers | Swift Springs F:280 R:560 | ER Charge Pipe | Tial Blue BOV | VRSF 3" Downpipes | VRSF 7" Intercooler
http://www.e90post.com/forums/showthread.php?t=782212
      06-02-2013, 09:24 PM   #7
MilehighM3
MilehighM3's Avatar
Drives: Harrop E90 M3
2009 E90 M3  [6.50]
No that's not correct. You only need 91 octane to get the effect of 93 at sea level due to the reduced oxygen content, so they say. However, when we used to get 93, every modded car I owned was much happier on the 93 than it was/is on 91.
      06-03-2013, 03:32 AM   #8
Ferruccio
Ferruccio's Avatar
Drives: 2010 335i
I live 5 minutes from the 30th/centennial station. Once I finally return to Colorado with the Flex Fuel kit, it's going to stink not having such close access to E85.
      06-03-2013, 07:21 AM   #9
richpike
Drives: MDX, LR4
Nice - we must live very close to each other. What does your car look like? I want to make sure I don't line up next to you at a light and embarrass myself
-Rich
      06-03-2013, 01:21 PM   #10
Ferruccio
Ferruccio's Avatar
Drives: 2010 335i
Unassuming black xdrive sedan that looks completely stock, with the piano caster 17 inch wheels
      06-03-2013, 02:46 PM   #11
richpike
Drives: MDX, LR4
Nice! We are basically twins then (black E90 LCI) but I'm not x-drive and have the style 287 wheels. You should plan on going to some of the bimmer burger nights and Bandimere/Pueblo MS - I bet that thing is a beast with x-drive and E85!
See you around town!
Rich
      08-28-2019, 01:31 PM   #12
KRAZSMILEZ18
Meat Missile
Drives: Bmw m235i xdrive
91+ e85
Rich
I'm running the jb4 map 2 which requires 93 octane and I'm running the 91 with 30% e85 and it works out perfectly! It's a fun, quick car for sure! 30% in these tanks are about 4.11 gallons. Hope this helps!
      02-09-2020, 11:43 PM   #13
Tnetics
Drives: 2011 335i xdrive
No, most gasoline can contain up to 10% of ethanol and this is disclosed on the pump. Also, the materials use in the fuel system for newer cars can withstand E85 without any issues. The stock fuel system is just not capable of delivering enough fuel to support E85 and higher horsepower, which is why it is recommended to upgrade the fuel system when using E85.
      08-13-2020, 11:34 PM   #14
Skrappy
9
Drives: 2022 BMW M8 Comp Convertible
I put over 100K miles on a car with a custom dyno tune for 93 octane and only ever put 91 in it. As noted earlier, because of the altitude and the lower pressures that can be achieved even with turbos, you don't need the octane rating up here. The gas companies know that, and that's why the don't supply 93 up here very often. Once you drive back down towards sea level you will start to see 93 again, and once you do, just fill up with 93 while you are down there.
