08-28-2013, 02:54 PM | #1 |
Rep 27
Help!!How to retrofit my new cluster into my F30
I had upgrade my basic kombi to the S6WAA Instrument panel with extended scope..
Problem is my guy try to retrofit but could find the new cluster detected in his computer to do coding, Anybody here had changed before.could u share with me the way and step to retrofit this cluster into my F30 328.. Help and reply is appreciate... |
08-28-2013, 07:43 PM | #2 | |
General
10545
Rep 41,224
08-29-2013, 01:12 AM | #3 |
Rep 27
Kombi
08-29-2013, 02:51 AM | #4 |
Rep 27
08-29-2013, 02:56 AM | #5 |
General
10545
Rep 41,224
With the Cluster Connected and Powered up, he read SVT, and there is no Kombi or DKombi or Kombi anything?
08-29-2013, 03:07 AM | #6 | |
Rep 27
BTW, we have added the optical cables and make the MOST ring. |
08-29-2013, 03:10 AM | #7 | |
General
10545
Rep 41,224
This Kombi is brand new or used?
08-29-2013, 03:35 AM | #8 | |
Rep 27
This 6WA Instrument Cluster is a brand new set. |
08-29-2013, 03:57 AM | #9 |
General
10545
Rep 41,224
There has to be something wrong at the hardware level. If the wiring was correct, this Kombi would appear in SVT.
01-27-2014, 11:15 AM | #10 |
47
Rep 66
Dear Shawn,
I am having a similar problem as Img76, and the ECU is not found even with 6WA in FA. Tried injected the CAF but no success. F31 328i 13-11-502 Psdzdata 51.1 6WA in the FA MOST Ring installed Only BKOMBI (but not DKOMBI) showing in the SVT HU CIC retrofited (should i restore it back to the original basic Head Unit before 6WA retrofit?) (With RACE-CHIP TUNE Box installed in the engine), should remove it before flashing the F6WA? Really hope you may share some idea. Many thanks in advance Last edited by Serpent720; 01-28-2014 at 10:18 PM.. |
01-29-2014, 12:11 AM | #11 |
47
Rep 66
Dear Shawn,
I am having a similar problem as Img76, and the ECU is not found even with 6WA in FA. Tried injected the CAF but no success. F31 328i 13-11-502 Psdzdata 51.1 6WA in the FA MOST Ring installed Only BKOMBI (but not DKOMBI) showing in the SVT HU CIC retrofited (should i restore it back to the original basic Head Unit before 6WA retrofit?) (With RACE-CHIP TUNE Box installed in the engine), should remove it before flashing the F6WA? Really hope you may share some idea. Many thanks in advance |
01-29-2014, 06:00 AM | #12 |
General
10545
Rep 41,224
Did you wire 6WA to the Most Bus?
01-30-2014, 12:33 AM | #14 |
General
10545
Rep 41,224
Retrofitted CIC and Race Chip shouldn't matter at all.
What happens when you Read ECU instead of Read SVT?
02-09-2014, 10:42 AM | #16 |
Rep 54
Hello,
I have similar problem with my f30, we tryed to retrofit 6wa cluster and it is not seen from impa or esys, this is unbelievable ! We added the most ring, bUt does not change anything.. Cluster is connected to the fem through pt can bus, it seems thant the fem does not handle 6wa cluster... I am working with inpa and you can see easily module connected amp. Cic. Trsvc... But 6wa cluster does not appear ! I suppose that fem is not compatible with 6wa cluster and should be changed ... |
02-09-2014, 11:43 AM | #17 |
General
10545
Rep 41,224
What does FEM ECU have to do with Kombi ECU?
When you connect with E-Sys, and "Read ECU" does new Kombi show in SVT?
02-09-2014, 03:06 PM | #18 | |
Rep 54
The entry point for diagnose, is the CAS and it does not see the high kombi.. E-SYS/INPA do not see kombi even with FA coded properly. Kombi gets some informations from the car, i.e kilometers, turn signal, high beam light... but does not work for benzin level, and tachymeter. Tomorow, i will check error with tool32 from FEM with 6WA instrument connected. |
02-09-2014, 03:14 PM | #19 |
General
10545
Rep 41,224
Ok. Good luck.
02-09-2014, 03:58 PM | #20 |
Rep 54
02-16-2014, 04:51 AM | #22 | |
Rep 54
Hello, I am using 50.4 data. retrofit done ! I swapped my FEM Middle line to FEM Max.. wired most ring to the Head unit and now i can see 6WA Kombi in E SYS or INPA: if you do not connect Most ring, you will not able to see kombi for coding: HeadUnit must have most ring : my business navigation comes without most ring ! (no matter i replaced by NBT) I don't know why, I was not able to see 6WA Kombi with my orginal FEM (middle line version)... with HU NBTconnected. for shawnsheridan, you are familar with cluster retrofit, i retrofited used kombi, and in eeprom, we changed vin to my vin car: but the red dot still there ! Cluster is running fine, we can reset service, can be coded... and in identification from kombi, we can see correct VIN Do i need to reset Vin using FF byte ? |
