BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Fsc code Generator
ARMA SPEED
      02-22-2014, 06:01 AM   #1
Yahoo38
Yahoo38's Avatar
Netherlands
94
Drives: F30 320I
Fsc code Generator
Hello,
I have seen on the internet that there is a fsc code generator for navigation systems.
Is there somebody who has some information on this or even workt with it.
I am very interested how its works.
The fsc code from BMW is very expensive so if i can save a buck it is Always welcome.
Appreciate 10
      02-26-2014, 07:40 PM   #2
v12
Drives: F10
It costs thousands. What are you trying to accomplish?
      03-01-2014, 11:41 PM   #3
MikeVictor
Australia
211
Drives: anything given a chance
He's likely looking for it to do a Nav update is my guess.
      03-02-2014, 01:18 AM   #4
Steve33
Steve33's Avatar
50
Drives: 2018 SQ5
This one is 70 pounds if this is what you're speaking of...
http://bmwcoders.com/forum/showthrea...=7112#post7112
Appreciate 4
      03-03-2014, 06:55 PM   #5
Dr.Ho
42
Drives: F30 320d (328d)
FSC DIY
Originally Posted by Yahoo38 View Post
Hello,
I used this one on my 2012 F30 with CIC, one week ago:
FSC Generator Download
Password: "Eintracht_Frankfurt"
It generates the FSC in three steps. But you have to change the "year-parameter" in the batch-file to a later map (e.g. 2016 - or even later - instead of 2014), then it works perfectly.
The Default 0x06 for 2014 does not work, but 0x09 does!
In adition, you'll need an ENET cable and a working EDIABAS intallation (32-bit - It does not run on 64-bit Windows!)
Look for the intruction Video on Youtube:
Appreciate 10
      03-03-2014, 07:01 PM   #6
v12
Drives: F10
That person is selling a FSC code for 70 not the generator. Last time I looked, NBT FSC generators were still pretty expensive just like CIC generators were when very few people had one/ them.
Where it the OP?
If you are looking for a FSC code (activation code) to upgrade your maps, which it sounds like what you were after, contact me or others for one. They are inexpensive for NBT and close to free for CIC (of free if you do it yourself, thanks Dr.Ho).
Appreciate 3
      03-04-2014, 07:47 AM   #7
dirksterzel
dirksterzel's Avatar
Germany
Drives: F30 328i xDrive
Appreciate 3
      03-12-2014, 02:21 PM   #8
Kapitein Iglo
16
Drives: F31
anyone knows if this also works for NBT?
      03-13-2014, 10:23 AM   #9
Kapitein Iglo
16
Drives: F31
thanks for the info!
Does this also generate the certificate, needed by E-Sys?
      03-13-2014, 02:54 PM   #10
Dr.Ho
42
No, it only generates the FSC Code, needed to upgrade the maps. Sorry.
      03-14-2014, 04:11 AM   #11
josehp603
Drives: 2013 BMW 335i M Sport Package
Will this generate codes for any Maps? I ask because I want to use this to generate the codes for BMW North America Premium 2014, but on the text file included in the download "Using and installing FSC.txt" it has listed upt to BMW North America Premium 2013, but not 2014 . Hopefully it is just the txt file which is not updated.
      03-14-2014, 12:04 PM   #12
Kapitein Iglo
16
Drives: F31
Unfortunately, not working for NBT
      03-14-2014, 01:04 PM   #13
Dr.Ho
42
It should work. I also had to use a "later" code than the 2014 0x05. I used 0x09 for the 2014 Map.
So, try 0x09 or higher for the second parameter in the Batch-File.
      03-14-2014, 05:04 PM   #14
Frogman
Drives: 2012 F30 328i
I assume you have the NBT and not the CIC HU, right?
If so, you need to version of the SWID_reader that reads the DE (not 1B) FSC.
      03-14-2014, 05:10 PM   #15
Frogman
Yes, it will generate for any version of the map, You just have to supply the region code and map sequence number for the map you want to install.
For CIC:
The North American Premium region is 0x2d
North American Premium 2014-1 is map code 0x07
I don't know what they are for NBT based systems.
      03-15-2014, 01:05 AM   #16
josehp603
Thanks guys. I will try to generate the FSC and let you know how it goes.
      03-15-2014, 04:06 AM   #17
josehp603
I was able to generate a working code. This works! I installed the North America Premium 2014-2 without any problems.
I used 0x2D and 0x08 in my fsc.bat file:
c:\EC-APPS\fsc a.hex 0x2D 0x08 > code.txt
Thanks for the FSC Generator!
      03-15-2014, 11:19 AM   #18
Kapitein Iglo
16
Drives: F31
In the meanwhile I have found a SWID_READER version that does work flawlessly
Will try the code in a few moments :-)
      03-31-2014, 05:39 PM   #19
crypticc
78
Drives: e92 M3 DCT + Comp
Hi - I have this s/w (the SWID reader) and one-stop ENET cable. Car gives me an IP address that I put in EDIABAS.ini alongside interface = ENET.
But for the life of me I can't get a connection in that or any other tool for that matter.
ODB cable is fine but of course is no good for this purpose. e92 car but am told CIC connection needs this cable.
please advise if you can on software setup..
Chris
      04-03-2014, 04:19 AM   #20
Yahoo38
Yahoo38's Avatar
Netherlands
94
Drives: F30 320I
Thx all,It works!!!
I updated the map to europa 2014.
      04-07-2014, 02:05 PM   #21
carconvert
26
Drives: 2012 328i Luxury Line
needs some minor tweaking but it works like a charm
      04-16-2014, 01:02 PM   #22
Mariuss
Czech_Republic
31
Drives: 2020 530ex
Avast says the FSC_Generator.exe is infected by Win32:Malware-gen. Anybody else seeing this?
